Current Website Support
You are Not Registered
Valid 12 Months
    Login to Remove Ads
    Followers
    Vosper 46ft RAF crash tender
    by MartynB ๐Ÿ‡ฌ๐Ÿ‡ง ( Master Seaman)
    ๐Ÿ“ฃ
    Click To
    Follow
    7 Posts 6 Replies 0 Photos 6 Likes
    MartynB
    Master Seaman
    ๐Ÿ“ Vosper 46ft RAF crash tender
    Online: 4 days ago
    Thanks, thats very helpful.
    neilmc
    Warrant Officer
    Online: 3 hours ago
    If you decide to go for a permanently fitted shaft greasing tube you can buy them online and they are easy to install.
    Hopefully the link below will work
    https://www.ebay.co.uk/itm/203504999935?var=0&mkevt=1&mkcid=...
    https://www.ebay.co.uk/itm/203504999935?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338268676&toolid=10044&customid=CjwKCAjw4ayUBhA4EiwATWyBrrKzuB_JpMMF22ER9P3XoKMvSPfomit4gmA3fU0c8dspVZEtUF0roRoCkUsQAvD_BwE
    ๐Ÿ”—
    1
    Learning so much more with each reply to my posts. One day I may have a boat in the water ๐Ÿค”
    MartynB
    Master Seaman
    Online: 4 days ago
    Thats very helpful, thank you. I have never soldered anything so will go with option 1.
    ToraDog
    Lieutenant
    Online: 1 day ago
    I do not know when Oilite bearings came into play. It is possible, I would guess. If not, you have two choices. If the prop shaft is easily removable, then periodically removing it and greasing it with a light H2O proof grease will Probably be sufficient. If the prop tube is easiy accessible and you are good at soldering, then you could drill a hole, nearto but not at, the inboard end. The hole should be a proper fit for a piece of brass tubing (ie, this is assuming that the prop tube is brass) Insert your prop shaft so the piece of tube just touchs it, then back the tubing out just a hair. Remove youe shaft. Use care not to move the brass tube. Solder the brass tube into place. you then use the ube to apply oil or grease to your shaft. That is it in a nutsheel. When in doubt, use the KISS principal: Keep it simple Simon. i would use the first approach if you have any doubts. Best of luck.
    1
    MartynB
    Master Seaman
    Online: 4 days ago
    It was made by my dad i'm guessing in the 50's, would they have had oilite bearings then? I'll have to look at taking the shaft out and checking.
    Thanks
    ToraDog
    Lieutenant
    Online: 1 day ago
    It all depends... Are you using manufactured shaft tubes that have oilite bronze bearings( bushings to some), or are the shaft tubes just palin brass tubes?
    If the former, you need to do nothing. Oilite bearings/bushings are self lubricating. If the latter, then either greasing or oiling the tube is advised. This can be done by periodically pulling the shaft and lubricating it, or... soldering an oil/grease tube to the shaft log. Then you can add a piece of silicon tubing and periodically add oil or grease.
    3
    MartynB
    Master Seaman
    Online: 4 days ago
    Does the propshaft need to be lubricated in some way? If so how do I go about acheiving this, is it just getting some oil into the shaft and letting it run down inside? Any help appreciated thanks.
    1
