    Lesro Pilot Boat - bow finishing
    13 Posts ยท 6 Followers ยท 10 Photos ยท 23 Likes
    Began 4 months ago by
    Chief Petty Officer 2nd Class
    France
    Latest Post 4 months ago by
    Sub-Lieutenant
    ChrisF
    Sub-Lieutenant
    ๐Ÿ“ Lesro Pilot Boat - bow finishing
    39 Views ยท 1 Like
    Online: 10 hours ago
    Curve along the bow is only very slight, so you should be Ok. Better if you can do it in ply.
    I find large areas of balsa quite hard to sand even after attacking it with a saw!
    Building 6 Faireys at a scale of 1:12 and another in the pipeline!
    stotty1111
    ๐Ÿ‡ซ๐Ÿ‡ท France
    21 Views ยท 1 Like
    Country: ๐Ÿ‡ซ๐Ÿ‡ท France
    Online: 3 minutes ago
    Photos
    Steamed the front section of the lower ply piece, gentle bending seems to have it cracked(not literally), this afternoons work fitting perhaps!
    ChrisF
    Sub-Lieutenant
    45 Views ยท 5 Likes
    I was going to say you could probably do the skins adjacent the deck Ok but see that there is a bit of a curve to the bow itself which might make fitting the skin difficult as it's a compound curve.
    If you can you could just use balsa at the bottom then, like on my Huntsman 28.
    I did use balsa (block in my case) top and bottom on the Swordsman but afterwards thought I may have been able to do that by the deck in ply. Though looking at it there is flare and again a compound curve, so probably not.
    I then used Eze-Kote and lightweight cloth over the whole of the hulls to strengthen the balsa and tie it to the ply and provide a good basis for painting.
    stotty1111
    ๐Ÿ‡ซ๐Ÿ‡ท France
    28 Views ยท 2 Likes
    Ok, now mounted stringers etc, and, a change of mind, I think i will cover the bow section with the ply supplied, with the fall back position of using balsa if it doesn't work!
    I have some photos, i'll mount them tomorrow!
    flaxbybuck
    Lieutenant Commander
    Online: 9 hours ago
    I do like the way the gunwhales are set into the bow deck piece.
    Good work so far. Keep at it ! ๐Ÿ˜‰
    stotty1111
    ๐Ÿ‡ซ๐Ÿ‡ท France
    39 Views ยท 5 Likes
    Done a little more searching, the kit predates 1995 as the address / phone number on the box uses Rowells address in Christchurch and the tel. no. does not have a 1 after the first 0
    Some photos of progress to date!
    The intention is for twin electric power, 540's or 380's using a 'v' tail mix on my 9XR Pro.
    I do steering competitions here in Brittany / Pays de Loire and with 2 motors and the above mix I find control much simpler / easier.
    Fred
    Lieutenant
    48 Views ยท 1 Like
    Online: 5 hours ago
    I know that this not the Pilot boat, but I have been building the "E" Class Lifeboat, that has a laminated balsa bow it is a lot more easer than try to make it with ply
    stotty1111
    ๐Ÿ‡ซ๐Ÿ‡ท France
    42 Views ยท 1 Like
    Not from block balsa, I have some sheeting 10mm thick, my idea is to laminate some blocks and shape(roughly) with a belt sander.
    Nickthesteam
    51 Views ยท 1 Like
    Online: 22 minutes ago
    Balsa would be eadiest to work. Are you carving from block?
    stotty1111
    ๐Ÿ‡ซ๐Ÿ‡ท France
    54 Views ยท 2 Likes
    I think it's from the original design work / plans by Les Rowell.
    With the balsa, the idea was to replicate the solid bow area as per the Kiel Kraft stuff from long ago(my age shows!), but strengthened with resin either polyester or epoxy!
    Show 3 More Posts
