Valid 12 Months
    Speed controller
    13 Posts ยท 10 Followers ยท 8 Photos ยท 32 Likes
    Began 24 days ago by
    Lieutenant
    Latest Post 23 days ago by
    Able Seaman
    CHRISTOPHERH1
    Able Seaman
    ๐Ÿ“ Speed controller
    38 Views ยท 1 Like
    Online: 3 days ago
    ๐Ÿ’ต Gift Membership
    Hi shipmate!
    i`m no electrician but red wire to the positive tag on the motor and green to the negative tag,usually there is a red dot indicating the positive tag.
    esc looks like a home made jobby!
    LewZ
    Lieutenant
    ๐Ÿ‡บ๐Ÿ‡ธ United States
    44 Views ยท 1 Like
    Online: 1 second ago
    Bottom line is to go modern with the ESCs. Put the old ones on display, in a box, whatever. They are just not usable in a model boat. My first speed controller (circa 1972) was home made and had two 3 position switches. One had power resistors, and the other fwd, stop, and rev. It got quite hot controlling the 6-volt automobile heater fan motor.
    Florida๐Ÿ˜Ž, USA
    Lew Zee (LewsModelBoats)
    WolfgangB
    Warrant Officer
    ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    44 Views ยท 1 Like
    Country: ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    Online: 2 hours ago
    Hello, I also installed 2 mechanical speed controllers in the ocean tug "OCEANIC" Ware. Worked perfectly, but they were power guzzlers and they got hot. That's why I kicked them out. Here's a link to my controllers.
    https://youtu.be/H7adADtY6gE?si=xkxbMSdCsD7CvVGd
    GregHiltz
    Petty Officer 1st Class
    ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    45 Views ยท 1 Like
    Country: ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    Online: 19 hours ago
    Over here in Canada, we referred those rheostat friction controllers as Bob's Boards.
    They are simple, resistance type controllers, very inefficient, as voltage not used(partial throttle) gets burned off in resistance.
    Any of the modern ESCs are digital, and the circuitry allows any unused voltage to be returned back to the battery.
    The price of the newer Controllers and reliability makes them the way to go in my humble opinion.
    Colin H
    Fleet Admiral
    Online: 2 seconds ago
    If you're disposing of it, my vintage stuff collection would like to have it join the various oddments in the box.
    Fair winds and calm waters, COLIN.
    Colin H
    Fleet Admiral
    62 Views ยท 1 Like
    Good evening, the wires go to the sweep arms as in picture. I still have 3 in use from the 70's. Have a tendency to get hot.
    Doogle
    Lieutenant
    77 Views ยท 1 Like
    Online: 24 hours ago
    Cheers Doug, that makes sense ๐Ÿ˜Š
    ARL58
    Recruit
    ๐Ÿ‡ช๐Ÿ‡ธ Spain
    76 Views ยท 3 Likes
    Country: ๐Ÿ‡ช๐Ÿ‡ธ Spain
    Online: 15 hours ago
    I'd start "dry testing" it. Connect the servo to a suitable output of a RC receiver, apply power to it, and check if the wiper moves when acting transmitter's control. Check movement limits, too. It seems that the wiper can move 180ยบ, but 90ยบ should be sufficient.
    If all is OK, you can add a suitable motor and its battery (if different from the one powering the RC receiver). And check if the motor moves, and if speed can be controlled.
    Motor shall have the same voltage rating than the output of the battery (don't plug a 6V motor to a 12V battery)
    RNinMunich
    Fleet Admiral
    ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    79 Views ยท 4 Likes
    Online: 5 hours ago
    Hi Doogle,
    What you have there is a Varispeed Board from Bob's Models.
    Commonly known as 'Bob's Board'. Still have one in the cellar somewhere.
    Took it out of the Sea Scout my Dad built in the early 60s.
    ARL is not quite right๐Ÿค”
    The Red and Green wires, going to a Tamiya connector, go to battery + and - respectively.
    (Don't forget the switch and fuse!๐Ÿ‘)
    The motor wires are connected to the two copper wipers driven by the servo.
    Attached vid (link) shows how to assemble and wire up the board.
    As ARL says they are very inefficient as battery power is dumped into the resistive track at slow speeds. Which heats up the tracks.
    Max current is 8Amps if I remember rightly.
    Maybe Colin would take it off your hands, for a Bob๐Ÿ˜‰, to add to his vintage RC display?
    Cheers, Doug ๐Ÿ˜Ž
    Doogle
    Lieutenant
    78 Views ยท 3 Likes
    Thanks Fred and ARL, I'd taken the esc out originally as it wasn't wired in - the wires had been cut, but I don't like throwing stuff out. Thought I could bench test it if I knew what was missing ๐Ÿ˜•. A photo of the boat it came from ๐Ÿ˜Š
    Show 3 More Posts
