Current Website Support
87
Contributors
11
Subscribers
You are Not Registered
Β£10
Β£15
Β£25
Β£50
Β£1
Β£3
Β£5
Β£10
    Followers
    Hobby King receiver clones
    by GARTH πŸ‡¨πŸ‡¦ ( Warrant Officer)
    πŸ“£
    Click To
    Follow
    15 Posts 14 Replies 1 Photo 6 Likes
    RNinMunich
    Fleet Admiral
    πŸ“ Hobby King receiver clones
    Country: πŸ‡©πŸ‡ͺ Germany
    Online: 11 seconds ago
    😊 View Profile
    πŸ’¬ Send PM
    I had realised that John, the acronym DEAC had simply revived some ancient memories of my early days in mobile and hand-portable radio engineering. Circuitry and components, early ICs etc, were moving on much faster than battery development could keep pace.
    Good to hear from youπŸ‘
    Pecker up old chap, with you in spirit. Best wishes, Doug
    The Bugs are on the run 😊 ❄️❄️❄️ Get out and run those Sea Trials!! πŸ˜‰ Cheers Doug
    onetenor
    Sub-Lieutenant
    Online: 1 year ago
    😊 View Profile
    πŸ’¬ Send PM
    I know that Doug I was responding to Westie LOL
    1
    RNinMunich
    Fleet Admiral
    😊 View Profile
    πŸ’¬ Send PM
    Mornin' John, I've used 'Generic' crystals with my ancient Sanwa 35 Meg set with no problems.
    I do find tho that the 'FM' crystals seem to give better range than the 'AM' crystals.
    Check the specs of your TX whether it is AM or FM.
    Cheers; Doug 😎
    DEACS!? My God, when did I last hear of them let alone see one😲
    We used to use them in professional personal VHF/UHF radios (Police and the like) some 45 years ago. 400mAh was good stuff in those days!
    Threw my last examples out about 10 years ago, they had some interesting and quite artistic crystal growths thoughπŸ˜‰
    Was just a brand name for NiCads.
    onetenor
    Sub-Lieutenant
    Online: 1 year ago
    😊 View Profile
    πŸ’¬ Send PM
    Does anyone know if a Sanwa Rx will work with Futaba Xtals. Both 35 mhz (planes only)πŸ‘πŸ€” More modern battery packs can replace the old DEACS so no probs there Westie.πŸ‘
    I too use Bang Good and also Gear Best Both excellent.πŸ‘
    Westquay
    Commander
    Online: 21 days ago
    😊 View Profile
    πŸ’¬ Send PM
    Colin, I first entered the world of proportional RC with a set called a Mini-Hex, in 1971. I bought it from the model shop in the arcade in Exeter. it cost a bloody fortune! 2 Function, essentially a copy of the Kraft set, but made in Belvedere, Kent. I still have it and as far and I know it still works, except the old DEAC battery pack is defunct, of course. it even came with it's own metal cased charger. Green frequency only, can't be changed!
    Colin H
    Captain
    Online: 3 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    Thanks jbkiwi, 2.4ghz isn't a problem, most of my vintage rx's are from the 60's through to the 80's. 27mhz and 40mhz. But it's good to have all the information I can get about all systems as I expect 2.4ghz will become vintage one day.
    Fair winds and calm waters, COLIN.
    jbkiwi
    Rear Admiral
    Country: πŸ‡³πŸ‡Ώ New Zealand
    Online: 7 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    The FSR6B will work with the FR Sky i6, i 10, T6 (which might be the HK-TR6A-V2), CT6B AND TH9X (which is the 'Hobby King' (FR Sky) 9x). I have bought the (Fly Sky) FSR6B and the FSR9B (8CH) and they both work fine on the 9x. Not sure what the difference between FR Sky and Fly Sky is, but it's probably just branding. I think Hobby King puts their own names on everything and modifies model numbers just to confuse everyone, like saying only their receivers match which is not true (perhaps in their product line but not in the real world) you just have to look around and take a punt.
    FR Sky make the TH9x (HK 9x) probably the 9XR for HK, the Taranis and a few others. Fly Sky seems to make the cheaper ones i6 (which I think has replaced the 6df) TR6a HK-6DF TGY 6X (hard to find the XR5000,- 7000 RXs anywhere for the 6x) etc.
    It might be worth a crack at the 6ch FS-R6B receiver as the matches mention a T6 TX, not much to loose and if it works, buy a bunch (check EBay, AliExpress and Banggood,-prices vary for the same items) like I did just in case HK dumps it and leaves everyone high and dry, as they have with a number of products. Now days you have to do lots of research and risk a few dollars to win, with all the B/S you get from suppliers,-not just R/C.
    1
    Colin H
    Captain
    Online: 3 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    Hi Bryan, I have found problems, even with matched crystals, the usual problem is that the some of the old rx's would not operate with a tx from a different manufacturer. I have acoms, futaba, Fleet and magregor as well as some unbranded tx's, but some of the models which I have aren't working with tx unless it's the same brand as the rx. This problem is mostly on the 27mhz models, although a couple of 40mhz systems have had the same problem. I always buy matched pair crystals. Even some am sets which never have a problem. So I thought if I can make a chart showing what is compatible with what.
    1
    Bryan-the-pirate
    Warrant Officer
    Online: 4 months ago
    😊 View Profile
    πŸ’¬ Send PM
    Colin I operate all the frequency ranges you mention. in the old 27 Mhz any 27Mhz crystal set work providing the receiver is on the same frequency. The same is true for 40 Mhz each channel will transmit to any receiver within range but you can't put a 27 into a 40 or visa versa. I tend to use half channels as these days I am unlikely to meet anyone using them. Ebay is a very good source of crystals.
    The 2.4 gig system work by binding with a receiver and will only obey a signal sent for it. Just like the old game Simon says if that transmitter hasn't given the command the receiver will not obey.
    I hope that helps Bryan
    1
    Colin H
    Captain
    Online: 3 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    Thanks Martin, I understand about binding 2.4ghz but what really is my problem is the Compatibility of older 27mhz and 40mhz setups, also which crystals will work in which setups. This is where the compatibility chart will help.
    Show 5 More Posts
