261
11
ยฃ10
ยฃ15
ยฃ50
ยฃ5
ยฃ10
ยฃ15
ยฃ20
    Page 1 of 116
    Coming soon.
    Should have guessed you'd know all about that JB๐Ÿ˜‰ https://www.theguardian.com/world/2016/aug/30/new-zealand-town-oamaru-steampunk-capital-of-the-world I believe that Oamaru still holds the record for the largest convention, in terms of attendees! Were you there ? ๐Ÿ˜ Would LUV to see your costume ๐Ÿ˜‚๐Ÿคฃ Happy Steaming ๐Ÿ˜ฎ Doug ๐Ÿ˜Ž
    31 minutes ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    31 minutes ago
    Help identify
    1 hour ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    3 months ago
    by sidley70
    1 hour ago
    Pond Weed
    try dyofix lake shadow it's a concentrated food dye will not harm anything living in the pond except the weed we contacted one of the weed clearance company's would have cost ยฃ1000 just for them to come and look they told us to use it as most of the large golf clubs do if you look on their website there is a calculator to tell you how much to put in but I think you can only buy it by the kilo if you get any on cloths it will wash out as I have done it several times
    3 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง scout13 ( Leading Seaman)
    by Tall Paul
    3 hours ago
    by scout13
    Hints and Tips.
    I like your tip, it reminded me of the way I have used cycle spokes as drive shafts, the spoke nuts are usually plated brass so can be used in brass props by drilling out then silver solder the nut into the prop after removing the plating. Cheers Colin.
    6 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง Colin H ( Lieutenant Commander)
    6 hours ago
    by Colin H
    Prop size and speed
    9 hours ago by ๐Ÿ‡บ๐Ÿ‡ธ samc ( Leading Seaman)
    by StuartE
    9 hours ago
    by samc
    1 day ago by ๐Ÿ‡ฌ๐Ÿ‡ง pmdevlin ( Sub-Lieutenant)
    Cheap easy anchors
    2 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง DodgyGeezer ( Warrant Officer)
    Air Sea Rescue Launch 123
    2 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    by Will-I-Am
    Eastleigh ... visits
    2 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Tall Paul ( Petty Officer 2nd Class)
    Jun
    19
    2019
    Jun
    23
    2019
    by Tall Paul
    water is wet and so was I.
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Brianaro ( Petty Officer 2nd Class)
    by Colin H
    Aerokits Plans
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง donrecardo ( Able Seaman)
    by donrecardo
    by donrecardo
    4 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    Can anyone help please?
    5 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง andyhynes ( Leading Seaman)
    by andyhynes
    5 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    by Elsrickle
    Reversing Field-Wound motors
    Battery backup
    6 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Sub-Lieutenant)
    6 days ago by ๐Ÿ‡บ๐Ÿ‡ธ tgilchristjr ( Able Seaman)
    by tgilchristjr
    AERKITS SOLENT LIFEBOAT
    6 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง stuartbell3553 ( Recruit)
    by stuartbell3553
    by stuartbell3553
    Waveney class lifeboat
    6 days ago by ๐Ÿ‡ฟ๐Ÿ‡ฆ redpmg ( Petty Officer 1st Class)
    by Jerry1
    HAZELGARTH
    Help and advice please
    by Gren-York
    Another boat leaves the yard
    by GrahamP74
    SS Torrey Canyon
    9 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Airtrooper ( Recruit)
    by Airtrooper
    Have I been Demoted
    9 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง MouldBuilder ( Warrant Officer)
    by Scratchbuilder
    Vosper mtb 379
    10 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Boats ( Recruit)
    by Boats
    by Boats
    11 days ago by ๐Ÿ‡จ๐Ÿ‡ฆ Donnieboy ( Warrant Officer)
    21 days ago
    by Donnieboy
    12 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Fred ( Chief Petty Officer 2nd Class)
    by andyhynes
    by Fred
    13 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    13 days ago by ๐Ÿ‡จ๐Ÿ‡ฆ Ron ( Midshipman)
    by andyhynes
    Site glitches!
    14 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง mturpin013 ( Sub-Lieutenant)
    2 months ago
    by mturpin013
    Page 1 of 116
