Active Users (22)
>> Home > Forum > Anything Website Related > Apostrophe problem ?
(979 views)
robbob
Forum Posts: 76
30th Oct 2016 22:07
mdlbt.com/24132
Why is it that whenever I use an apostrophe in my build blog text it appears as a bunch of seemingly random characters.
I can edit the posting to correct it and it then works, but why not in the original posting ?
It's quite, curious isn't it ?
Robbob.
Forum Posts: 110
31st Oct 2016 14:27
mdlbt.com/24146
Even the BBC has this problem, in the ticker tape on the their early morning news programme. Very annoying. Also, whilst on the topic, why in the build blogs does a capital I get used when it should be lower case?
robbob
Forum Posts: 76
31st Oct 2016 15:40
mdlbt.com/24147
Equally curious is the fact that in my original forum post the apostrophes in my last line "It's quite curious isn't it ?" appear correctly but used in a
blog text will appear as garbage that needs subsequent editing.
And I have also noticed the odd capitalisation of the letter 'I'
Robbob.
Fireboat
Forum Posts: 264
31st Oct 2016 16:08
mdlbt.com/24150
There is a technical explanation. Also it's something that is fixable. I simply haven't had the chance to do this as it would need to be fixed at the same time as all database queries. The website has lots!
When loading data into a database there are apostrophes already within the server code itself. To avoid it getting confused on what is code and what is the text it's copying in, it uses a backslash. Otherwise known as an escape character. You'll also see it in RSS feeds sometimes, similar principle there. It's likely what the BBC ticker tape is reading.
That said, queries can be designed differently, the editing scripts are different to the creation scripts for posts on here. All however need a revamp as technology has moved on quite a bit since the original server code was written. There is a new technology called SQL improved, which is much more secure than the old SQL and negates the need for escape characters (back slashes).
When will it be fixed? I can't say. Maybe these Christmas holidays. It's solid days of work to update the whole website to the new technology. The database is a fundamental part of every webpage, the mobile apps, rss feeds and the notification system.
Once things are upgraded I'll be fixing all past posts to ensure no more backslashes are around.
Ps. Don't mention emoji compatibility! That's a whole other headache to manage 😉
Stephen
robbob
Forum Posts: 76
31st Oct 2016 17:19
mdlbt.com/24151
Hi Stephen.
Thanks for the explanation even though most of it went waaaaay over my head.
I quite an advocate of correct grammar and punctuation (but not a pedant!) so I'll keep using the apostrophe but
I don't envy your task of fixing the problem.
I'll try to resist the urge to use emojis 😉 .......failed.
Robbob.
Forum Posts: 473
5th Nov 2016 06:50
mdlbt.com/24212
Rob its simple ( honest ) there are control characters within the code being used and the apostrophe is one of them. So when you use one the code "sees" it as a control not text.
Forum Posts: 1792
2nd May 2017 12:19
mdlbt.com/27991
Keep up the good work Stephen, you're doing a great job 👍 Imagine if you were using a German keyboard like I have to 😉 have to keep switching input languages, otherwise the apostrophe comes out as "~", just one example amongst many 😲
