Active Users (10)
>> Home > Forum > Boat Specific Chit Chat! > PROBOAT RECALL 17
PROBOAT RECALL 17
(611 views)
Les-Forbes
24th Oct 2017 09:49
mdlbt.com/34914
This little brushless speed boat, with the supplied battery a 3S LiPo, has a run time of approx ten minutes. Could a stronger LiPo battery increase the run time.
Sorry. It's a Proboat Recoil 17.
24th Oct 2017 09:59
mdlbt.com/34916
Hi Les
If you mean a higher capacity then the answer is yes. However there may not be room for a larger capacity battery and in a small model it may be too heavy for the hull.
Can you post some pics of the installation and advise the actual capacity (eg 2200mA)?
Les-Forbes
24th Oct 2017 10:27
mdlbt.com/34920
Yes Dave, you might be right. It is a small boat and a larger and possibly higher rated battery, may upset the dynamics.
Thanks for your help.
24th Oct 2017 11:54
mdlbt.com/34923
Seeing the battery I would expect you could fit a larger capacity without lowering the waterline too much. If you can find the weight of the proposed battery try adding that amount of lead to the model to test. I'd use the existing battery plus a bit of lead etc.
I suspect the higher capacity will make for some interesting sailing so you may need your bike clips!
There could also be a heat problem so do check the motor esc after a short warp speed run.
Please post progress
boaty
Forum Posts: 42
25th Oct 2017 09:20
mdlbt.com/34944
Had a similar problem with a fast electric myself.
I put a bigger battery in which increased the running time but it did have detrimental effect on speed and😁 handling.
Quick way to check if a larger battery will affect performance is to weigh the existing battery, note weight then find out the weight of the bigger battery you intend to purchase.
Make up some ballast to the weight difference between the two batteries and put it in the boat with the original battery and see if there are any changes in performance as a result.
It will save you buying the larger battery if you feel the performance is less than what you expected.
Boaty
Dave Keech
Les-Forbes
25th Oct 2017 19:46
mdlbt.com/34979
Thanks Boaty. That's a good idea.
