259
6
Β£10
Β£15
Β£25
Β£50
Β£1
Β£2
Β£5
Β£10
    Page 1 of 110
    Soldering
    Many moons ago when I worked in the shipyards we used something similar on a much larger scale with the holes 2"dia these massive slabs of steel were used to bend bulb bar and hold plates flat for welding they were called dogging plates or tables depending on the size (I think dogging has a different connertation now a days) .the tables or plates were used with bars which were called dogs .good luck with the rest of the soldering😐😐
    6 hours ago by πŸ‡¬πŸ‡§ marky ( Sub-Lieutenant)
    by retirement-hobby
    6 hours ago
    by marky
    Thames Barge Plan Kitty
    Hi, Kitty was a plan by Richard Webb, he had a web site www.scalemodelboatyard.co.uk , sorely very long time not availlable. There exists more tsb plans , put > thames sailing barge model plans < into Google. I think you could choose something ..if you are thinking about RC model ... I would recommend some finished hull. There are also a number of other barge plans, such as Lady Daphne or Veronica. Model Veronica goes to buy as a kit from Traplet - https://www.sarikhobbies.com/product/thames-barge-veronica/. Β On the Internet are also reduced plans of other barges, but these must be adjusted for the construction of the model. Tom
    6 hours ago by πŸ‡¨πŸ‡Ώ tomarack ( Chief Petty Officer 2nd Class)
    by wmbc40
    6 hours ago
    by tomarack
    Shroud
    Yes - drilling small holes on circular surfaces is difficult. Do you have a small dremel-type drill with some disc cutters? If so, a light cut across the top of the tube would be easy to do accurately and would leave a small hole. If the cut was too deep it might weaken the brass tube, but for a static model that would be fine. The solder would flow into the cut and hide it completely. You could even do it with a triangular needle file. If the cut did not go completely through it would still help in centring the drill. The nice thing about drilling holes is that you then have 1/8" excess tolerance that you can cut the vertical wires to - they will slide up and down in the tube... You can also cut tubes precisely to shape, then join them temporarily with a bit of mains copper wire inside, making very neat joints. See pictures 5, 6 and 7 on this page -
    7 hours ago by πŸ‡¬πŸ‡§ DodgyGeezer ( Chief Petty Officer 2nd Class)
    19 hours ago
    by retirement-hobby
    7 hours ago
    New forum rankings.
    Hi Brianaro, "Someone has spent a lot of time building this website and put masses of thought into its content. Why? They can’t earn a fortune doing it, I guess they do it for the benefit and enjoyment of the users and visitors. It’s a shame this point has been missed and the reason we visit the site overlooked." This is exactly what I emphasised some days ago. But then; I suppose you didn't read it cos there were some Smileys in my post. Cheers Doug 😎
    7 hours ago by πŸ‡©πŸ‡ͺ RNinMunich ( Admiral)
    by rolfman2000
    7 hours ago
    Locating Clubs on 'Boats Clubs and Lakes'
    Agree Alan, It was a lot easier / quicker to find all sorts of things before. The Forum used to be categorised; Electrical Related, Site Related, Specific, Boat Related Non Modelling Chit Chat, for example. Now everything is in one 'bucket'. ☹️ Doug
    8 hours ago
    by ads90
    7 hours ago
    How can I expand the photos.
    Your are right Colin - tried it on my Android and the same as you. I am sure that they will come along with a fix shortly. Other than that the site is a 'good'un'. Alan
    8 hours ago by πŸ‡¬πŸ‡§ ads90 ( Chief Petty Officer 2nd Class)
    by Colin H
    8 hours ago
    by ads90
    2 day model boat show
    Ill be there hoping everything goes well. Looking forward to the event
    15 hours ago by πŸ‡¬πŸ‡§ dragon ( Chief Petty Officer 1st Class)
    May
    18
    2019
    May
    19
    2019
    2 months ago
    by nutrunner
    15 hours ago
    by dragon
    CNC boat kits...?
    Once the machine is set up, we run into the two classic workshop requirements - tooling and work-holding. We hardly need a powerful spindle or Dremel for cutting balsa, which is what I am going to start with. I am going to use an old brushed boat motor with a small chuck added. But I need an easy way to hold the workpiece. Here I am making up an experimental vacuum holder. It's sized to take a 4" x 36" sheet of balsa. I hope to slip a blank sheet in, run the machine and take out the equivalent of a die-cut kit sheet an hour later. Note the requirement for everything to be massive and rigid, so that items can be held exactly in a repeatable position without movement while the cutting forces are applied....
    17 hours ago by πŸ‡¬πŸ‡§ DodgyGeezer ( Chief Petty Officer 2nd Class)
    2 months ago
    17 hours ago
    Static Model Boat Builders
    Ive been in contact with Stephen, he has a lot on his p!ate. Bear with me in this process. Anyone else interested in Static Boat Building?
    19 hours ago by πŸ‡ΊπŸ‡Έ retirement-hobby ( Master Seaman)
    by retirement-hobby
    19 hours ago
    by retirement-hobby
    I PHONE APP
    Similar with me, using a PC with WIN 10, Firefox browser and T-COM t-online mail. I used to be able to be able to click on 'View online' in a Notification mail and was immediately logged in. Not any more 😭 Doug
    1 day ago by πŸ‡©πŸ‡ͺ RNinMunich ( Admiral)
    by RHBaker
    Turnigy Standard 9x transmitter
    Thanks. I will give it a try. If possible, could you tell me how your 4 channel switcher works. My next project has multiple additional features to deal with. Which one is compatible with the 9x. Thanks again.
    1 day ago by πŸ‡¬πŸ‡§ MouldBuilder ( Chief Petty Officer 2nd Class)
    ST200 info
    Still No leads on this someone MUST know something all info treated in the stictest of confidence
    1 day ago by πŸ‡¬πŸ‡§ Dave J ( Able Seaman)
    2 months ago
    by Dave J
    by Dave J
    Folding Bulwark????!
    2 days ago by πŸ‡¬πŸ‡§ Toby ( Chief Petty Officer 2nd Class)
    2 months ago
    by Toby
    by Toby
    Mystery Boat
    Up loaded 6 only one has come through will keep trying
    2 days ago by πŸ‡¬πŸ‡§ marky ( Sub-Lieutenant)
    by belliow
    by marky
    New Website Has Finally Arrived!
    Private messages bug should be fixed now Colin. Also... some faulty hyperlinks and pages redirecting to the wrong place. Think I've got to the bottom of that too. @John, are you trying to post in the media section or the forum? Stephen
    2 days ago by πŸ‡¬πŸ‡§ Fireboat ( Warrant Officer)
    by Fireboat
    by Fireboat
    What’s happened to the site??
    Well as usual somebody thought it be a good Idea to change the site and messed it up, I too was a sub lieutenant but now a master seaman with nothing lol
    2 days ago by πŸ‡¬πŸ‡§ Biscuit ( Master Seaman)
    by Biscuit
    soldering
    The beauty of this site is whatever the problem someone knows how to solve it.
    2 days ago by πŸ‡¬πŸ‡§ tidtug ( Petty Officer 1st Class)
    18 days ago
    by retirement-hobby
    by tidtug
    Aziz, Westerriff, Assurance Envoy for sale
    Hello Can you adise me of an asking price of the Westerriff, if its still for sale. Thanks
    3 days ago by πŸ‡¬πŸ‡§ barnet ( Able Seaman)
    by Davecounty
    by barnet
    Puzzled
    Colin, I hear you, I was a Fleet Admiral, but my fleet was a couple of sailboats and two tugs! Joe
    3 days ago by πŸ‡ΊπŸ‡Έ Joe727 ( Chief Petty Officer 1st Class)
    by Colin H
    by Joe727
    Display cases
    Thank You Dave, I will try this out as I too have not purchased any cases due to there high cost.πŸ‘ Regards Taffy.
    3 days ago by πŸ‡¦πŸ‡Ί taffy ( Leading Seaman)
    by Ravydave52
    by taffy
    Editing Models in Harbour
    Thanks for the 'fix' StephenπŸ‘ Basically I like the new site presentation. Well done, helluva lotta work has gone into itπŸ‘πŸ‘ Now time to celebrate with a nice single malt instead of the coffee? Can recommend a Lagavulin or a Jura 😜 I've been wandering about the new site for several hours and have noted a few points that may need some attention - Some nice features which seem to have disappeared ☹️ Some new/old ones which don't quite seem to give the expected result. Will send you a report (with +'s as well as -'s πŸ˜‰) when I've finished stooging about. Would be nice to have the 'Site Related' forum topic back to do that! More soon, cheers, Doug 😎
    4 days ago by πŸ‡©πŸ‡ͺ RNinMunich ( Admiral)
    by ads90
    Build manual/ instructions
    Hi, try this > https://docplayer.net/44439682-Building-a-model-thames-sailing-barge.html I can reccommend Model thames sailing barges at facebook https://www.facebook.com/groups/1036890286476399/ Tom
    4 days ago by πŸ‡¨πŸ‡Ώ tomarack ( Chief Petty Officer 2nd Class)
    9 months ago
    by kmbcsecretary
    by tomarack
    New Website Sneak Peak
    Hi. i have previously used my ipad but the new site loads but will not allow me to use any of the features, not even log in with face book .is this because i could not use the app before as my ipad version was to early and now its to early for the web site too. Im am sending this from my phone. Rogal.
    5 days ago by πŸ‡¬πŸ‡§ Rogal118 ( Leading Seaman)
    by Fireboat
    by Rogal118
    Model Slipway Tug AZIZ
    Just confirmation that this vessel has now been sold, and is soon to be returned to service. Many thanks to the new owner. Dave
    6 days ago by πŸ‡¬πŸ‡§ Davecounty ( Able Seaman)
    22 days ago
    by Davecounty
    by Davecounty
    Planking
    To make the hull water tight I use a product called z-poxy it's a 2 part product mixed in hardener and resin of the same amounts and I use a layer of fibber cloth and them the z-poxy smooth as best you can about 30 min. time to use and then let harden over night at least 24 hours and them you can sand and finish with filler if needed or some more coats of z-poxy sanding after each coat. Rick
    6 days ago by πŸ‡¨πŸ‡¦ Newby7 ( Master Seaman)
    by Davevand
    by Newby7
    Painting over epoxy
    On fibreglass you could use an etching primer which is a modified alkyd primer that produces a sound base coat on wood, steel, fiberglass, aluminum surfaces. but you should use an ordinary primer before the top coat. Halfords do a spray etch primer.
    7 days ago by πŸ‡¬πŸ‡§ mturpin013 ( Sub-Lieutenant)
    by simonricho
    by mturpin013
    Rigging a model barge
    Hi, here I put rope diameters (above mentioned) . Kathleen ropes - in attachment
    7 days ago by πŸ‡¨πŸ‡Ώ tomarack ( Chief Petty Officer 2nd Class)
    by Nerys
    by tomarack
    Anteo 2 Tug
    I didn't give it much thought when I said tap off 2x6volt in parallel. I will probably use small 4s lipo to power lights etc. Thanks fo pointing this out. Still a long way from installing ancillaries.
    10 days ago by πŸ‡¬πŸ‡§ Dick ( Leading Seaman)
    6 months ago
    by Dick
    by Dick
    Graupner Neptun
    Scale 1:87 HO Graupner Neptun older kit but not of any specific ship, just a generic coastal freighter with or w/o cranes. Inside is a Graupner 350 motor geared 3:1; speed control; using one 7.2v 2400 NiMH Found a post of some else’s work. https://www.modelboatmayhem.co.uk/Modellers/Mark_Wilkes/neptun.htm
    10 days ago by πŸ‡¨πŸ‡¦ Ron ( Midshipman)
    CS Mackey Bennett
    Hi Gdaynorm have you had a look on the Sairk hobbies web site at the plans https://www.sarikhobbies.com/product/cable-ship-mercury-mm782/ John
    11 days ago by πŸ‡¬πŸ‡§ JOHN ( Petty Officer 1st Class)
    by Gdaynorm
    by JOHN
    Page 1 of 110
