263
10
Β£10
Β£15
Β£25
Β£50
Β£5
Β£10
Β£15
Β£20
    Page 1 of 103
    Look for a simple balsa build
    Had to add another reply to add two websites...
    1 hour ago by πŸ‡¬πŸ‡§ DodgyGeezer ( Chief Petty Officer 1st Class)
    2 hours ago
    by gman3000
    1 hour ago
    CNC boat kits...?
    Ah well, grandmothers and eggs... 😌 Still, I did say that the collet was cheaper than 1 grubscrew - not 100... I found that mine worked first time, so you probably won't need the platform. You seem better equipped than I am for the rest of it πŸ˜‰ I can, however, report that holding balsa sheet in this way is very effective. It is a sheet of ply bolted to the base, with another sheet of ply 4" wide on top. The sides have hard balsa edges rising about 1/4 inch above the ply, which are held in with a spruce strip. A 4" sheet of yellow correx is there to provide a soft base for under cutting. If I cut outside the workpiece the cutter just goes through the balsa sides, so no damage done. 4" or 100mm sheets of balsa drop into the 1/8th recess on top, and are held by the side balsa, which is slightly sprung inwards. If necessary they can be packed around the edges, but the recess is sized to hold them tightly. They are firmly held against the cutter, do not move at all, and the workpiece can be removed and replaced precisely in the same position if necessary. If you want you can put a weight on top of the sheet during cutting to hold it perfectly flat, and move it when the cutter is going to go over it.
    2 hours ago by πŸ‡¬πŸ‡§ DodgyGeezer ( Chief Petty Officer 1st Class)
    3 months ago
    2 hours ago
    Noodle Jet Boat
    "....There were plans for a noodle boat in a fairly recent model boats mag..." Several years ago I drafted up an EeZeBilt RIB. This used foam pipe insulation (ready-split!) for the inflatable section, had a standard brushless prop and used a servo hidden in a dummy outboard to swing the outboard for use as a rudder. I never completed the boat, and did not publish the plans, but if there is some interest I will look at revisiting the idea. Here are a few pics of what the boat was to look like:
    8 hours ago by πŸ‡¬πŸ‡§ DodgyGeezer ( Chief Petty Officer 1st Class)
    by Shopper
    8 hours ago
    Seaplane tender
    I am afraid not but quite an interesting film and lovely to see a model of a seaplane tender.
    10 hours ago by πŸ‡¬πŸ‡§ SelwynWilliams ( Chief Petty Officer 2nd Class)
    18 hours ago
    by SelwynWilliams
    10 hours ago
    by SelwynWilliams
    Plan Sources
    You must have done a lot of research to find that matching boat? Dedication!!
    Editing photos
    Big Blue (test facility)
    Thats slick!πŸ‘
    3 days ago by πŸ‡ΊπŸ‡Έ Cashrc ( Leading Seaman)
    by Cashrc
    Propellors
    4 days ago by πŸ‡¬πŸ‡§ John2 ( Chief Petty Officer 1st Class)
    by Alan999
    by John2
    Swordsman or Huntsman?
    4 days ago by πŸ‡¬πŸ‡§ ChrisF ( Petty Officer 2nd Class)
    by billhook301
    by ChrisF
    posting problems
    Me too😭
    5 days ago by πŸ‡©πŸ‡ͺ RNinMunich ( Fleet Admiral)
    POSTING PROBLEM!
    5 days ago by πŸ‡¬πŸ‡§ Brianaro ( Master Seaman)
    by figtree7nts
    Ballcap!
    6 days ago by πŸ‡ΊπŸ‡Έ figtree7nts ( Commodore)
    by figtree7nts
    Thames Barge Plan Kitty
    6 days ago by πŸ‡¬πŸ‡§ TOWN3810 ( Leading Seaman)
    by wmbc40
    by TOWN3810
    Veronica
    7 days ago by πŸ‡¬πŸ‡§ Shopper ( Master Seaman)
    by KenThompson
    by Shopper
    Model boat w gas motor/nitro
    8 days ago by πŸ‡¬πŸ‡§ Haverlock ( Sub-Lieutenant)
    by Aekaraaek
    by Haverlock
    8 days ago by πŸ‡ΊπŸ‡Έ retirement-hobby ( Petty Officer 1st Class)
    by retirement-hobby
    by retirement-hobby
    Model Boat crew....
    10 days ago by πŸ‡¬πŸ‡§ DodgyGeezer ( Chief Petty Officer 1st Class)
    My Harbour
    10 days ago by πŸ‡¬πŸ‡§ Fireboat ( Warrant Officer)
    by boatiebennett
    by Fireboat
    Possible Tid Tug.
    Found out that it is a German Aeronaut Kalle Harbour Tug.
    11 days ago by πŸ‡¬πŸ‡§ jelley_baby ( Chief Petty Officer 1st Class)
    25 days ago
    by jelley_baby
    by jelley_baby
    No sailing in Port Perry Ontario Canada πŸ‡¨πŸ‡¦ for awhile And it is still coming down!
    Hi Ron, We sailed at Lake Lisgar near Tillsonburg today. Ice has gone, bit windy though. Now 17 in Ancaster. Be patient, one day the ice and snow will go - Inshallah!
    11 days ago by πŸ‡¨πŸ‡¦ RHBaker ( Sub-Lieutenant)
    19 days ago
    by RHBaker
    Difficulty posting replies
    Hi Stephen, It was in model boat crew,I had other pictures of 3D printed crewmen
    11 days ago by πŸ‡¬πŸ‡§ marky ( Sub-Lieutenant)
    by marky
    by marky
    HMS Bangor M109
    Fantastic Model congrats on acquiring her!🎁 Now that's a true friend!πŸ‘
    12 days ago by πŸ‡ΊπŸ‡Έ figtree7nts ( Commodore)
    by Mataroa
    by figtree7nts
    R.A.F.SEAL CLASS
    Checkered history on this boat. https://www.yachtharbour.com/yacht/seaman-guard-virginia-5435 Apparently after the Navy was done with this class of ship, they were sold several times and now are owned by a private group for hire. https://m.youtube.com/watch?v=chStEjEeqxA
    12 days ago by πŸ‡¨πŸ‡¦ Ron ( Midshipman)
    by RHBaker
    Mystery boat
    it is a Range Safety Launch I was the coxswain of 1662 based at Londonderry in 1958
    13 days ago by πŸ‡¬πŸ‡§ trekil ( Recruit)
    by Chewi
    by trekil
    Turnigy Standard 9x transmitter
    Solved the problem but the solution will not help others. I bought a Turnigy 9xr Pro. This uses the er9x firmware. What a difference. All of the switches now work. They were really easy to programme as well. I have now purchased the Smartieparts programmer add on and fitted it to the 9x. The goal is to upgrade it to the er9x firmware also. So far I cannot get my laptop to recognise the programmer but I am sure it is only a driver issue.
    13 days ago by πŸ‡¬πŸ‡§ MouldBuilder ( Chief Petty Officer 1st Class)
    Static Model Boat Builders
    Welcome to the pleasure dome, there's no end to the help and information you can glean from the contributors
    13 days ago by πŸ‡¬πŸ‡§ marky ( Sub-Lieutenant)
    by retirement-hobby
    by marky
    New build
    Maybe called something else. It's used in furniture manufacturing and architectural features. Has a really nice surface finish.
    13 days ago by πŸ‡¬πŸ‡§ Hillro ( Petty Officer 1st Class)
    by retirement-hobby
    by Hillro
    Thanks I sent them a message.
    15 days ago by πŸ‡ΊπŸ‡Έ retirement-hobby ( Petty Officer 1st Class)
    16 days ago
    by retirement-hobby
    by retirement-hobby
    Static Model Boat Builders Club
    I think you misunderstood what I intended. There are several RD "clubs" here, people with a common interest. Not everyone does RC, therefore I was attempting to group with people who just build boats.
    16 days ago
    by retirement-hobby
    by retirement-hobby
    Radar with rotational drive
    They are made from cheap Chinese railway figures. I'll start another thread with more info, since this one is meant to be about radar.....
    15 days ago by πŸ‡¬πŸ‡§ DodgyGeezer ( Chief Petty Officer 1st Class)
    17 days ago
    by Hillro
    Page 1 of 103
