261
11
ยฃ10
ยฃ15
ยฃ50
ยฃ5
ยฃ10
ยฃ15
ยฃ20
    Page 1 of 116
    Hintsand tips - Decals made easy
    If anyone is looking for a cheap easy way to make any decals of photos name plates, designs etc, here is an idea you might find useful. I use a waterslide decal paper on which you can print anything you design, draw etc on your inkjet printer. I buy this paper from a company in Australia for around $30 NZ for 10 A4 sheets. You can buy clear or white. What you do is just print your design, photo, text etc onto the paper (plastic waterslide coated), let the ink dry, spray with either a clear lacquer or Helmar clear (the best), allow to dry, trim,soak in warm water as usual and apply. This material is quite tough and will not tear easily and you can spray lacquer over it to seal it on the model. It is a similar stuff as sold by Testors in a kit but is a lot more cost effective. I've included some examples of decals I've made for my boats and planes . For small decals you can cut a small piece a bit bigger than your design, print your picture on A4 to see where it will come on the page, sellotape the piece of decal paper over the print, (tape horizontally top and bottom) put the page back in the printer with the same orientation as is was, and print onto your decal. This saves wasting a whole sheet of decal paper which cannot be re used. If you find a nice clear sharp design it will come out nicely on the decal
    2 hours ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    2 hours ago
    Coming soon.
    I thought you meant the other octopus pram and the baby with the air conditioned brain ??
    3 hours ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    3 hours ago
    Hints and Tips.
    Neat idea, and comes with ready made handles as well!
    8 hours ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    2 months ago
    8 hours ago
    Pond Weed
    Thanks Scout13, The dye is a good idea. At Guildford the council used barley straw bales, these seemed to work on just surface type weed not the ones we are having trouble with that grow from the bottom. Regards, Tall Paul. ๐Ÿ‘
    15 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง Tall Paul ( Petty Officer 2nd Class)
    by Tall Paul
    15 hours ago
    by Tall Paul
    Dual ESC & Mixer
    I have 2 of the Action-Electronics P94โ€™s and they work great, a neat package containing 2 20amp ESCโ€™s and a rudder mixer, problem is there so erratic in their availability, anyone aware of an alternative? Iโ€™ve used separate ESCโ€™s and a forge electronics mixer, works but not as neat...
    1 day ago by ๐Ÿ‡ฌ๐Ÿ‡ง Shopper ( Petty Officer 1st Class)
    by Shopper
    Help identify
    2 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    3 months ago
    by sidley70
    Prop size and speed
    2 days ago by ๐Ÿ‡บ๐Ÿ‡ธ samc ( Leading Seaman)
    by StuartE
    by samc
    3 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง pmdevlin ( Sub-Lieutenant)
    Cheap easy anchors
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง DodgyGeezer ( Warrant Officer)
    Air Sea Rescue Launch 123
    4 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    by Will-I-Am
    Eastleigh ... visits
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Tall Paul ( Petty Officer 2nd Class)
    Jun
    19
    2019
    Jun
    23
    2019
    by Tall Paul
    water is wet and so was I.
    6 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Brianaro ( Petty Officer 2nd Class)
    by Colin H
    Aerokits Plans
    6 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง donrecardo ( Able Seaman)
    by donrecardo
    by donrecardo
    6 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    Can anyone help please?
    6 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง andyhynes ( Leading Seaman)
    by andyhynes
    by Elsrickle
    Reversing Field-Wound motors
    Battery backup
    7 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Sub-Lieutenant)
    8 days ago by ๐Ÿ‡บ๐Ÿ‡ธ tgilchristjr ( Able Seaman)
    by tgilchristjr
    AERKITS SOLENT LIFEBOAT
    8 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง stuartbell3553 ( Recruit)
    by stuartbell3553
    by stuartbell3553
    Waveney class lifeboat
    8 days ago by ๐Ÿ‡ฟ๐Ÿ‡ฆ redpmg ( Petty Officer 1st Class)
    by Jerry1
    HAZELGARTH
    9 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    Help and advice please
    10 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    by Gren-York
    Another boat leaves the yard
    by GrahamP74
    SS Torrey Canyon
    11 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Airtrooper ( Recruit)
    by Airtrooper
    Have I been Demoted
    11 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง MouldBuilder ( Warrant Officer)
    by Scratchbuilder
    Vosper mtb 379
    11 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Boats ( Recruit)
    by Boats
    by Boats
    13 days ago by ๐Ÿ‡จ๐Ÿ‡ฆ Donnieboy ( Warrant Officer)
    23 days ago
    by Donnieboy
    14 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Fred ( Chief Petty Officer 2nd Class)
    16 days ago
    by andyhynes
    by Fred
    15 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    16 days ago
    Page 1 of 116
