February 2019: 8 people
April 2018: 9 people
Active Users (19)
>> Home > Forum > Boat Specific Chit Chat! > Your ideas on how to stabilize a flat-bottomed freighter.
(1199 views)
Forum Posts: 193
22nd Oct 2018 23:19
mdlbt.com/47387
After adding the needed weights to bring this freighter down to a loaded ship water line, the model rocks n rolls. It needs either a keel or exterior stability fins. What is your experience? Please share with us.
Forum Posts: 508
23rd Oct 2018 11:08
mdlbt.com/47391
you could consider using some of the modern tech and fitting active stabilizers there are a lot of cheap solid state gyros and if your receiver does not have enough free inputs and outputs an arduino mini could handle the logic.
Forum Posts: 193
23rd Oct 2018 13:31
mdlbt.com/47395
https://www.marineinsight.com/naval-architecture/roll-stabil...
I chose to add a bilge keel to begin with in the search of stability.
RHBaker
Forum Posts: 120
23rd Oct 2018 22:14
mdlbt.com/47407
Think a bilge keel should be the first step. My next suggestion would be to add some of the ballast to a removable fin keel, bolted to the underside of the hull. This will increase the righting moment, but not the weight. This can be seen if you examine U Tube videos of cruise ships and liners. They have so much superstructure they are inherently unstable.
Have built several freighters and always fit captive nuts into the keel or underside. These are intended for trunnion display mounts, but have always been prepared to bolt a keel on if needed. The nuts can easily be sealed when sailing.
DennisRobotham
Forum Posts: 18
26th Oct 2018 13:53
mdlbt.com/47469
Hi Ron, had the same problem with my 8'-6'' HMS Fearless when I first launched it. Took out all the ballast, weighed it then replaced it with a solid steel keel on edge bolted to the underside of my boat.... cured and never any more problem since. Fast boats go past it and it sits still with the wake going along side, just like the real one. It gave the boat a stabilising keel and put all the ballast 60 mm lower than being inside the boat. Good luck with yours, interested as to how it turns out.
Dennis G.V.M.B.C
