July 2018: 6 people
November 2017: 2 people
Active Users (8)
>> Home > Forum > Building Related > Clamp on prop-shaft grease nipple
(660 views)
cormorant
Forum Posts: 200
10th Nov 2016 09:58
mdlbt.com/24265
My part built Perkasa already has the tubes and shafts fitted. Holes have already been drilled in the tubes near the top but no oiler or grease nipple has been fitted so grease keeps oozing out.
Being an old kit the shaft diameter is 3/8" or 9.5mm.
Whilst I have been able to find the items I want, I can't find a larger diameter than 8mm.
Unless anyone knows of a larger diameter I will have to try and drill out the 8mm.
Any suggestions please?
Forum Posts: 297
11th Nov 2016 21:43
mdlbt.com/24290
Hi there, had similar problem a few years ago. I used 3/8" diameter brass tube approx 1" long filed on one end to fit over hole in shaft tube, then soldered in upright position. This was covered with a small push fit dust cover. Hope this helps.
cormorant
Forum Posts: 200
11th Nov 2016 22:51
mdlbt.com/24292
Hi Colin.
One thing I forgot to mention, is that for some reason the holes in the prop tubes are not on the top, but half way round, which gives no clearance for soldering all around the brass tube.
Clamping seems the only option (unless I removed the tubes and start over again - a big job), where I can at least use flexible neoprene pipe for lubrication.
In any event, thanks for the suggestion.
Forum Posts: 297
11th Nov 2016 23:22
mdlbt.com/24294
Could you sleeve the prop tube then re-drill on the top, using oil tube as guide and drill using a small end mill.
cormorant
Forum Posts: 200
12th Nov 2016 07:53
mdlbt.com/24298
Thank you. That's well worth considering.
I'm off to the model boat show today so I may well be able to pick up the bits I need.
