Active Users (19)
>> Home > Forum > Building Related > Glue
Glue
(1647 views)
glyn44
Forum Posts: 25
10th Mar 2018 08:14
mdlbt.com/39706
Hi All,
Any one suggest a glue that can be used for tacking assemblies together so I can test fit them, see how they look etc. And then remove and disassemble allowing adjustments to be made, allowing the glue to be easily removed when required and the permanent adhesive to be applied.Masking tape not always suitable.
Thanks.
Let's sail in calm waters
10th Mar 2018 08:27
mdlbt.com/39707
Deluxe materials do a tacky wax that may do the job you need
www.deluxematerials.co.uk
glyn44
Forum Posts: 25
11th Mar 2018 12:13
mdlbt.com/39746
Cheers. Looking at it I reckon that it sets, and I’m not sure how hard. I’ll have a chat with the shop to see what they say. Ideally I’m want something that will hold items in place, which can be easily separated by running a blade through the tack so they will separate.
Thanks again.
BigAlio
Forum Posts: 44
11th Mar 2018 12:52
mdlbt.com/39748
Hi have you tried double sided tape maybe it would work
glyn44
Forum Posts: 25
11th Mar 2018 13:08
mdlbt.com/39750
No I haven’t. I do not have any. I’ll buy a roll Monday and see how it fairs. Cheers.
BigAlio
Forum Posts: 44
11th Mar 2018 14:03
mdlbt.com/39753
let me know how you get on its easy to apply and you can split them apart with a scalpel hope it works for you
Forum Posts: 282
11th Mar 2018 19:05
mdlbt.com/39760
what about a little dab of silicone sealer ,if it gets too sticky you could use silicone sealer solvent to remove any excess a.Cheers Marky
Forum Posts: 437
11th Mar 2018 20:40
mdlbt.com/39761
Hi Glyn, I wouldn't use silicone, as nothing else will stick where it has been, even paint will react with areas of contact. I know this from making a similar mistake myself. I have used small dabs of pva, and double sided tape, both have worked well for me.
Hope this is helpful, cheers Colin.
glyn44
Forum Posts: 25
12th Mar 2018 07:27
mdlbt.com/39781
Ah thanks Colin. I was going to try the silicone idea today, but I won’t now, thanks. I’ll go for the tape. I was also thinking, after the silicone tip, to try no nails, as I have some to hand. I’ll test some on pieces of scrap wood and see how it goes.See if it glues ok afterwards.
Cheers all.
Forum Posts: 437
12th Mar 2018 07:39
mdlbt.com/39782
Hi Glyn, no nails should be okay, but only use tiny dots of it as it is very strong. Cheers Colin.👍
glyn44
Forum Posts: 25
16th Mar 2018 13:43
mdlbt.com/39980
Thanks for all the info guys. Double sided tape was a winner, with surprise late runner, blue tack. A flash of inspiration in the wee small hours!
BigAlio
Forum Posts: 44
16th Mar 2018 13:46
mdlbt.com/39981
im glad tape worked out. blue tack new one on me .
Forum Posts: 437
16th Mar 2018 19:37
mdlbt.com/39993
Blue tack is a kind of elastic putty that doesn't set but holds well and lifts away afterwards, can be re used. There is also white tack, same as above but white. Available at all good diy and craft shops. Lasts for years, I bought two packs in 2010 and still using, also ideal for sticking drawings up on workshop wall.
