July 2018: 6 people
November 2017: 2 people
Active Users (20)
>> Home > Forum > Building Related > Bristol pilot cutter mascotte
(6473 views)
Forum Posts: 210
21st Mar 2018 20:33
mdlbt.com/40245
Hello all this is my latest build of the Kingston mouldings Bristol pilot cutter 'mascotte' was purchased from a forum friend who no longer had time to build it.
Sadly Kingston mouldings has now closed down.
The first job was to glue the lead ballast into the bottom of the hull, this was done by using fibreglass resin then a couple of layers of fibreglass to seal the lead shot into the built in keel
Forum Posts: 210
21st Mar 2018 21:27
mdlbt.com/40255
The next job was to fit the bulk heads and the deck shelf strips around the edges.
I had some scrap pieces of 8mm OSB board so I used this for the bulk heads which were glued in place using gorilla glue then fibreglassed in once the glue had gone of. The shelf strips are 10mm square oak that were fixed 6mm below final deck hieght as I will be using 4mm ply for the sub deck followed by 2mm planking strips in walnut and beech.
Forum Posts: 210
21st Mar 2018 21:34
mdlbt.com/40256
The strengtheners for where the main mast will be fixed in place through the deck were glued in place with gorilla glue and fibreglassed in once the glue had gone of again this timber was an of cut that was to hand but this needed to be substantial as I would be using 12mm dowel for the main mast.
Forum Posts: 210
22nd Mar 2018 02:15
mdlbt.com/40265
After fitting the 2 lead gel batteries in place (6v 4mah) either side of the mast support and fitting the electrics the sub deck 4mm ply was fitted and glued in place using gorilla glue.
If you hadn't guessed I decided to try using the brown gorilla glue on this build to see how it fairs compared to the usual resin and normal wood glue's and I must admit I have been impressed with the results so far .
Sorry no pics of this stage as I forgot to take them at the time.
This picture shows the area were most of the electrics will be situated for easy access.
Forum Posts: 210
22nd Mar 2018 02:25
mdlbt.com/40266
Nothing much was done for a while after this stage due to my health halting the build for about 6 months.
But I have started the build again and decided to post it on here for you all.
The next stage was planking the decking and in whales , the deck is planned in walnut and beech which was glued and pinned to the sub deck using titebond 2 .the in whales were lined with mahogany on the inside and walnut on the outside topped with a walnut top rail made using 5mm square section bent and glued together again with titebond 2.
Forum Posts: 210
22nd Mar 2018 02:28
mdlbt.com/40267
Here is where the build is at now this was taken after the second coat of yacht varnish, all in all it has now had 4 coats of varnish and is ready for painting the lower deck.
Forum Posts: 210
22nd Mar 2018 02:30
mdlbt.com/40268
The forward section
Forum Posts: 1834
22nd Mar 2018 09:52
mdlbt.com/40272
Beeuuutiful woodwork 👍
Which varnish did you use?
Love the contrasting woods 👍
Forum Posts: 210
22nd Mar 2018 10:38
mdlbt.com/40273
Thanks Doug it took about 4 weeks in total to complete the planking.
The varnish is Wilko's own brand clear gloss yacht varnish which was sanded with fine wet and dry sand paper between each coat to get that smooth finish on the final coat.
I will show all the hand made fittings next which I have already started making
Forum Posts: 1834
22nd Mar 2018 11:23
mdlbt.com/40274
Ta for the info Ron 👍
I can see you also used bags of my 'secret' ingredient 😉
Your choice of woods really does her proud. Shall watch progress with great interest 😊 Cheers, Doug 😎
BTW: I believe most of the Kingston moulds were taken over by someone else! Have a record of it somewhere in the 'electronic stash'. Will try and dig it out.
Forum Posts: 210
22nd Mar 2018 13:44
mdlbt.com/40277
That's interesting Doug I was adviced that most of the moulds were cut up for fire wood as he couldn't find anyone that could make the hulls to his standard.
Forum Posts: 210
22nd Mar 2018 14:08
mdlbt.com/40281
ok here we have some pictures of some of the fittings i have already made using brass. i have taken the pictures with the drawings that come in the folder.
Forum Posts: 1834
22nd Mar 2018 14:09
mdlbt.com/40282
Very sad if that did happen 🤔😭
Last I heard is that Robin wanted to retire to spend more time with his Missus and go travelling, not to mention his sadly neglected own modelling!
He apparently retired in April 2016 and stopped all Mail Order. But retained the moulds with the intention of still making a few hulls To Order BUT for Collection Only! Positively no more Mail Order hectic.
Sad if that didn't work out. Cheers Doug 😎
Forum Posts: 210
22nd Mar 2018 14:11
mdlbt.com/40283
here is some of the deck furniture i have made the chimney stack and storage brackets, these are not in the folder and found these after researching the mascotte and finding detailed pictures of the vessel.
Forum Posts: 1834
22nd Mar 2018 14:13
mdlbt.com/40284
Excellent fittings Ron 👍
Have given me inspiration to make some mini hinges for a cabin door on my Sea Scout. 😉 Ciao, Doug 😎
Forum Posts: 210
22nd Mar 2018 14:18
mdlbt.com/40285
he we have the hatch covers that were made earlier the forward hatch covers the power switch and battery charging points.
the mid-ships hatch houses the receiver and the main cabin houses the sail and rudder servos.
the last picture is just to show with the hatch covers on
Forum Posts: 210
22nd Mar 2018 14:20
mdlbt.com/40286
here we have the main boom, jib and yard arm ready for the fittings to be added before attaching the rig.
Forum Posts: 210
22nd Mar 2018 14:28
mdlbt.com/40287
Thank you Doug much appreciated this is the build fully caught up now so everything from now on will be as happens.
i was advised by frank nylet of nylet sails that robin used to make the hulls for his yacht kits but was told would no longer supply them as no replacement had been found to take over the moulds and as you say is a very sad loss to the modeling would i have always found his hulls to be outstanding quality.
would be nice to see those hinges if you get round to making them , i have tried in the past but failed badly but no doubt i will try again one day.
Forum Posts: 1834
22nd Mar 2018 15:31
mdlbt.com/40288
Your boat is beginning to look suspiciously 'Museum Standard'!👍
Yep, shame about Kingston, but can understand why Robin didn't want to build for Frank's kits anymore (or anyone else's for that matter) wouldn't fit in with his No Hectic policy!
Re 'tin bashing! Here's a couple of examples of my last attempts from several years ago, from my H Class 1936 destroyer, scale 1/72. I note that they need the years of neglect cleaning off 🤔 I'll pass it off as North Atlantic Convoy duty muck😁
First two pics 20mm Oerlikons, made from 0.5mm brass sheet, 1mm copper for the carriage frames and 1 and 2mm brass tube. Guns can elevate 😉 Recoil 'springs' are shrink sleeve, but I now have some suitable real springs. Will try to finish them off when Hotspur comes up for refit completion.
Pic 3 is one of the depth charge throwers port side. Core is a 1/4" wood dowel, the rest is 0.5mm brass, tinned copper wire and 2mm brass tube for the firing cylinder. I used John Lambert (RIP) plans for both.
Pic 4, the thrower on deck and copper wire ladder rails, crewman shanghaied from Monty's 1/72 Airfix 8th Army. A Desert Rat on board!
Under the black square is the hole for the aft torpedo mount. Underneath is the speaker for the "Whoop Whoop". That part of the 'deck' is just painted aircraft silk!
Must get back into practise now I've got nowt more important to do 😁
Forum Posts: 210
22nd Mar 2018 17:20
mdlbt.com/40292
Nice job there Doug nice detailing , I've not got the fingers for that scale (I have no feeling in end of my fingers ) the smallest scale I've worked on is 1/32 an MMM eurogirl tug and eldergarth tug but had to sell them last year because I couldn't lift them anymore.
This Bristol pilot cutter is 1/16 and finding fittings in this scale is getting harder so no choice but to make the fittings my self.
But it keeps me busy and some what active
Forum Posts: 417
22nd Mar 2018 18:11
mdlbt.com/40293
Hi kmbcsecretary,
It's a shame you had to sell your tugs!
I collect 1/32 scale tug and boy can they be very heavy...
Although you had to switch to sail. Building the boat is almost all the fun! anyway for me it is!
Forum Posts: 210
22nd Mar 2018 19:13
mdlbt.com/40294
That is very true Ed it was a sad day when my tug's left , they were built to tug as well and had a few trips to balne Moore for the tugging it's what I loved doing.
But I'm enjoying this build and looking forward to sailing her for the first time
Forum Posts: 1834
22nd Mar 2018 19:22
mdlbt.com/40295
Very sorry to hear that Ron!
"There but for the Grace of God ...."
At least you have the consolation of some fine work on the Pilot Cutter 😉
Hope you enjoy many many happy hours sailing her, 👍
Forum Posts: 417
22nd Mar 2018 19:34
mdlbt.com/40296
I don't know what I would do. If I had to get rid of my collection!
But I'm glad you have found another boat to build!
looking forward to a video of her Maiden Voyage!
Forum Posts: 210
22nd Mar 2018 19:42
mdlbt.com/40297
Thanks Ed and Doug for your kind words
Donnieboy
Forum Posts: 36
23rd Mar 2018 19:08
mdlbt.com/40315
Excellant work on all you are doing.I've had to downsize and lose some of my heavier boats.They were tugs also.I had to have an emergency hernia operation and the doctor said to take it easy.Still recovering.Looking forward to more of your posts.
Forum Posts: 210
27th Mar 2018 22:22
mdlbt.com/40491
Hi all not much has been done over last few days been on a downer with my health which has left me house bound but I'm starting to pick up again so hopefully can get back to building again.
I have attached the specs and pics of the original mascotte that I have been using to get the detail info from
Forum Posts: 210
27th Mar 2018 22:27
mdlbt.com/40493
Think something went wrong there will try that again
Forum Posts: 210
29th Mar 2018 19:17
mdlbt.com/40568
Not done much today except get some of the fittings and rigging points fix in place while I'm waiting for the weather to warm up so I can get the lower half of the hull painted
Forum Posts: 210
30th Mar 2018 17:05
mdlbt.com/40599
Today I have masked of the boat ready for painting when the weather warms up . Materials used where frog masking tape and some paper packaging that came out of the last delivery box from Amazon.
Firstly I went round taping of all the fidly bits before completely masking the sides of the hull before applying the paper
Forum Posts: 210
1st Apr 2018 16:06
mdlbt.com/40662
Today while waiting for the weather to warm up i have started work on the ships boat which when finished will be 8" in length and a beam of 4". I will be making this using mahogany for the whole boat and the first job was to cut, sand and glue the parts that make up the keel.
this was made using 5mmx3mm mahogany sandwiched between 2 lengths of 10mmx2mm mahogany which when finished will give 5mm square keel.i have always found it easier doing it this way rather than try and bend the wood.
Forum Posts: 210
5th Apr 2018 21:37
mdlbt.com/40777
The finished keel for the ships boat after sanding and shaping
Forum Posts: 210
6th Apr 2018 12:51
mdlbt.com/40793
The ships boat continued
The plans of the ships boat is to make it out of paper but I will be using walnut.
I have made and cut out the cardboard templates for the ribs and stenciled them onto a walnut sheet , I cut these out using a coping saw and using permagrit sanding blocks to sand to shape after which I will mark the inner line and cut and final shaping to make the ribs their are 5 ribs in total.
Forum Posts: 1834
6th Apr 2018 13:20
mdlbt.com/40802
I've said it before and will probably say it again; 'Brilliant woodwork' 👍
And an excellent tutorial, 😎
Forum Posts: 210
6th Apr 2018 17:34
mdlbt.com/40807
i have got all the ribs cut out and the outer edge sanded within a couple of mm of the marked edge, leaving the last couple of mm for when they are fixed to the keel.(pic1)
i then marked out and filed out the notch for the fixing point to the keel using my permagrit needle files.(pic2)
finally today i finished with marking out the inner edge of the (pic3) ribs using my makeshift compass using a steel rule as the smooth edge with a couple of wood coffee stirrers as packers (pic4) to get a uniform width for all the ribs held together with a couple of cable ties ready for cutting out and sanding over the weekend.
Forum Posts: 210
7th Apr 2018 17:47
mdlbt.com/40849
the ships boat continued
today i have finished cutting out the inner of the ribs with my tungsten rod saw.
these where filed and sanded with 250 grit and 2500 grit sandpaper.
i have dry test fit each of the ribs to be sure of a square true fit before they will be glued.
tomorrow i will be making a jig to hold the keel and ribs while the glue goes of and to keep the frame square till planked.
pic 1 is of the rod saw used
pic 2 is of the ribs after being filed and sanded
pic 3 & 4 is of the dry test fit
Forum Posts: 210
8th Apr 2018 16:30
mdlbt.com/40876
hi all have spent today knocking up a simple jig to hold the keel and ribs of the ships boat while the glue goes off.
pic 1 & 2 shows the jig set with the keel in place.
pic 3 shows the dry fit test to insure all fits square and true.
pic 4 is all the ribs glued to the keel.
The rig is made up of pieces of ali angle which was a damaged length from when my greenhouse was delivered last year, all i have done is cut 12 pieces approx 10-15mm wide and drilled 1 hole for fixing to the board.
I then marked out the board for where the ribs need to be and fixed two of the brackets for either side of the ribs and used a length of 6x2 beech long enough to be clamped to both angles which was for clamping the ribs too, 1 piece of angle was placed at the front and stern to hold the keel square to the board which is a scrap bit of OSB.
Each rib was dry fitted to the keel for any fine tuning using a set square to insure square and true, once i was happy with the results i dismantled it and refitted glueing the ribs in place again double checking with the set square to check for any movement in the jig.
Forum Posts: 1834
8th Apr 2018 17:35
mdlbt.com/40879
Looking good👍
Can't wait to see that wood tidied up and varnished 😊
Forum Posts: 210
8th Apr 2018 17:57
mdlbt.com/40880
Thanks Doug have had to do some more research on the ships boat about the planking and finally discovered that it's a clinker built boat so lots of sanding and shaping to do yet
Donnieboy
Forum Posts: 36
8th Apr 2018 18:11
mdlbt.com/40882
Judging from what you have done so far the ship's boat will be of the same quality.Excellent work.
Forum Posts: 1834
8th Apr 2018 21:58
mdlbt.com/40889
Please don't sand off the 'clinkers' 😲
S'pose you'll have to sand n seal each board individually before it goes on 🤔 Knew there was reason I've never tackled clinker build 😉
Forum Posts: 210
9th Apr 2018 03:30
mdlbt.com/40891
That's correct Doug each plank needs to be shaped and sealed as you go. This will be my first clinker hull and just hoping not to many mistakes happen and don't need to scrap it and start again but that's model building 😵 .
Don't worry Doug I won't be sanding the clinkers out its took me long enough to find out the details of the ships boat as no info in the plans
Forum Posts: 210
9th Apr 2018 15:17
mdlbt.com/40904
I had to open my mouth yesterday didn't I 😭 this morning I took of the clamps to file of the excess glue and dropped the frame onto the floor knocking one of the ribs of 💩so I have had to re-glue the rib back on again so will be starting the blanking tomorrow now.i have included a couple of pics of the boat frame before I dropped it.
Forum Posts: 244
9th Apr 2018 16:48
mdlbt.com/40909
There's an old joke in there somewhere "what's that ? (RH picture ) a dead one of these (LH picture)Boom Boom👍Cheers Marky
Forum Posts: 210
9th Apr 2018 16:55
mdlbt.com/40912
The old ones are the best 😁
Forum Posts: 1834
9th Apr 2018 16:56
mdlbt.com/40913
Oldies but goldies 😁
Forum Posts: 210
10th Apr 2018 16:03
mdlbt.com/40951
ships boat planking
well the first 2 planks have been fitted today and things went better than expected, guess that is from making sure everything was squared up yesterday 😎
well that's my excuse and i'm sticking to it 😜
Forum Posts: 1834
10th Apr 2018 16:24
mdlbt.com/40953
The bench is so well camouflaged I couldn't find the ribs at first 🤔
Watching with interest to see how you get 'clinkered' up 😉
Forum Posts: 210
10th Apr 2018 16:43
mdlbt.com/40955
was wondering that myself Doug being my first attempt at a clinker hull
Forum Posts: 1834
10th Apr 2018 17:30
mdlbt.com/40960
Never done it either Ron hence my interest in your progress, fingers crossed ofr yuo (maske ti hrad ot tpye!) 😉
Maybe attached pic helps; LHS clinker, RHS carvel built.
Bon chance mon ami 👍
Donnieboy
Forum Posts: 36
10th Apr 2018 17:40
mdlbt.com/40962
Good example.Should help a lot.Just take it slow.
BigAlio
Forum Posts: 44
10th Apr 2018 17:44
mdlbt.com/40963
check out yuotube video called. Model Clinker boat building
may help
hammer
Forum Posts: 71
11th Apr 2018 09:22
mdlbt.com/40986
You may find my clinker boat method, built as full size. just 6" long. can be seen build blog page 13.
Don't be shy just reply
Forum Posts: 1834
11th Apr 2018 09:37
mdlbt.com/40987
Hi hammer, just spent an interesting half hour looking at your blog for the 6" clinker boat. Lovely work 👍 and a useful tutorial. Good stuff!
Any more where that came from? Cheers Doug 😎
Forum Posts: 210
11th Apr 2018 10:17
mdlbt.com/40988
Thanks hammer very interesting reading I just hope I can get mine looking that good
Forum Posts: 1834
11th Apr 2018 13:08
mdlbt.com/40992
The way you've been going so far I'm sure you will Ron 👍
hammer
Forum Posts: 71
12th Apr 2018 10:42
mdlbt.com/41021
Glad you enjoyed the 6" clinker build. I have made 12 like that 6" smallest 10" largest.
Forum Posts: 210
13th Apr 2018 10:48
mdlbt.com/41049
Ships boat continued
Hi all the planking is coming along slowly have just attached the fourth plank on either side.
Thanks to hammer's excellent clinker build and advice I am starting to get the hang of this.
The only problem I am having at the moment is working out the length of the oars , I have some 5mm square section in walnut I thought of machining down to make the oar shafts but unsure of length as these are not on the plans for the ships boat any advice welcome.
Forum Posts: 210
19th Apr 2018 08:58
mdlbt.com/41196
It's coming along now almost finished planking the sides just a couple of planks to fit and can then plank the stern.
It's certainly been a learning curve doing my first clinker hull and at this size , there has been a few mistakes but that's modelling .
Donnieboy
Forum Posts: 36
19th Apr 2018 13:24
mdlbt.com/41205
You're doing a good job.Huge learning curve.Lots of patience.I enjoy watching the build.
Forum Posts: 210
19th Apr 2018 16:57
mdlbt.com/41210
thanks Donnieboy i have found with this hobby it is one long learning curve always something new to try 😉
Forum Posts: 210
20th Apr 2018 17:52
mdlbt.com/41229
Back to the main hull
Have finally got the hull sprayed today with this heat it has been drying faster than I can spray it on 😄
Firstly the hull was sanded with a 200grit paper to sand of the shiny coating to give the paint something to key too.
It has had three coats of undercoat sanded with 2500grít wet and dry paper between each coat.the undercoat used was Halfords rattle can plastic primer.
Then the lower hull colour was sprayed on again three coats sanded with 2500grit paper between each coat.colour used was Halfords rattle can ford arctic blue.
the top half of the hull was sprayed with two coats only with it being black plus I didn't have enough paint to give it a third coat😋 colour used was Halfords rattle can satin black.
Finally the hull was sprayed with Halfords rattle can clear lacquer three coats sanded with 2500grit paper between each coat.
Donnieboy
Forum Posts: 36
20th Apr 2018 18:37
mdlbt.com/41230
Great job on the paint.Must be nice to be able to paint outside.We're still waiting for the snow to disappear.We are only at 5 degrees.Lovely job.Can't wait to see it finished.
Forum Posts: 210
20th Apr 2018 18:53
mdlbt.com/41231
Thanks Donnieboy it has been 28degrees c here today perfect painting weather.
I can now start assembly while waiting for the glue to dry on the ships boat planking, been that warm on my shed I managed to get two planks each side today . Normally have to wait 12hrs between planks.
Forum Posts: 1834
20th Apr 2018 21:39
mdlbt.com/41233
Super job, very smart 👍 If upside-down 😁😉
Forum Posts: 210
20th Apr 2018 21:58
mdlbt.com/41234
Thanks Doug thought it would be easier to turn the boat upside down to paint it rather than standing on my head 😂
Forum Posts: 1834
20th Apr 2018 23:57
mdlbt.com/41236
Me too! 👍 Just thought you might have got the rattle cans mixed up 😁
Unusual lower hull colour - but nice 😉
Forum Posts: 210
21st Apr 2018 01:29
mdlbt.com/41239
Been there done that mate 🙄 more times than I dare admit to.😄
The colours were chosen after researching the original mascotte.
Forum Posts: 210
22nd Apr 2018 17:52
mdlbt.com/41260
I've started on getting the fittings fitted now the paints dried and also the sail control line has been fitted and tested.i have used 50lb clear carb fishing line for the control wire so it isn't clearly visible.
Last job done today was to fit and test the rudder assembly, all's working as it should👍
Forum Posts: 210
22nd Apr 2018 18:15
mdlbt.com/41263
The rudder assembly was made using a 200mm prop shaft squared of on the lower 3/4 of the shaft to allow for secure fixing for the rudder made from three layers of 4mm ply.
The rudder was fixed to the shaft using 2ton epoxy and held in place with three pieces of brass strip which are bolted through the rudder
The prop tube bearings were cut of the ends and fixed into the hull for the rudder shaft , I have also installed rubber o rings to insure no water can come in through the rudder posts.
Donnieboy
Forum Posts: 36
23rd Apr 2018 00:03
mdlbt.com/41270
I really like the job you did on the woodwork.Looks great.Nice job on the rudder too.
Forum Posts: 210
23rd Apr 2018 17:40
mdlbt.com/41280
Been fitting more of the fittings today and have had a little helper today
Forum Posts: 244
23rd Apr 2018 21:30
mdlbt.com/41287
Hi Ron , I have really enjoyed your build,great wood ,brass and painting skills gives us mere mortals (whittlers)something to aim for .seeing the figure reminded me of your other post, when i next pop into work i will see how there getting on with the figures i was getting scaled up and printed from 1/24 to 1/16 and if there ready post some pictures . Almost forgot what are the dimensions of the build ?. Cheers Marky
Forum Posts: 210
24th Apr 2018 13:11
mdlbt.com/41296
Hi marky and thanks for your comments very much appreciated the dimensions for the mascotte are 1140x300x310 (l,w,d)
I look forward to seeing the images of the figures when they are done. I did purchase some doll house figures but the adult ones are to large but the child ones you could get away with using them as the adults.
Today so far not done to much but fit a few more fittings and make the reach hooks.
The reach hooks were made using some 2mm I.d brass tubing which was heated and hammered to shape to make the hooks and attached to some round 2mm pine which was sanded and varnished to finish off.
Forum Posts: 210
25th Apr 2018 17:09
mdlbt.com/41310
Today I have made the sails storage frames for when there stored in the rig bag.i've not posted pics yet as don't want to show the sails to early in the build.
Has also got some more done with the rigging pulley's ready for starting the time consuming job of the rigging hopefully next week.
The second pic shows the removable boom rest that I finished making today and have given it a coat of varnish while it's in position.
Forum Posts: 210
26th Apr 2018 16:56
mdlbt.com/41327
Hello all have got some more of the rigging points completed and had to re-do the sail control line after dropping my snips onto the line and it caught the edge and nicked it so had to be replaced as no doubt would have snapped once under strain.
The ships boat is coming on nicely , have got the stern planked now and have made a start on cleaning up the glue overspill and sanding it down before fitting the floor and seats .
Once finished I will be painting the outside of the hull to match the main hull and varnishing the inside with a yacht varnish.
DennisRobotham
Forum Posts: 16
26th Apr 2018 21:27
mdlbt.com/41337
brilliant build and even better finishing, look forward to the launch pictures, excellent, well done a real credit to you.
Dennis G.V.M.B.C
Forum Posts: 1834
26th Apr 2018 22:25
mdlbt.com/41342
Way to go man!!!
At the risk of becoming monotonous 🤓 Brilliant woodwork and fittings 👍
Did you make the pulleys yourself?
Looks like stainless, if so Hat Off Sir 👍👍
PLEASE DON'T PAINT THAT LOVELY CLINKER BOAT!!😲
It would look Soooo good varnished to your usual standard, and I'm pretty sure from the photos of the original that only the canvas cover was blue.
Surely the boat itself was varnished.
More power to your rigging, Cheers Doug 😎
Forum Posts: 210
26th Apr 2018 23:07
mdlbt.com/41344
Thanks Doug for your kind words much appreciated, afraid I did cheat when it comes to the pulley's they were purchased from Cornwall model boats .
I did think of making them but decided it would take to long to make, although they did cost a few quid .
Forum Posts: 1834
26th Apr 2018 23:14
mdlbt.com/41345
OK, I admit defeat 🤔
Seems the dinghy was painted black with a white lower hull.😆
Also doesn't seem to be clinker built!?
But since you have clinkered it please don't hide that under black paint 😲
Happy deciding, cheers Doug 😎
Forum Posts: 210
26th Apr 2018 23:19
mdlbt.com/41346
If you look closely Doug and enlarge the 3rd pic
you can see the clinker but only just due to the layers of paint I think 🙄
Forum Posts: 1834
26th Apr 2018 23:35
mdlbt.com/41347
I think you're right Ron 🤔 only just barely visible - a good argument for NOT painting it black! 😉
Fully understand with the pulleys - there are so many of them, would have done the same 👍 Keep up the good work, cheers Doug 😎
Forum Posts: 210
27th Apr 2018 16:53
mdlbt.com/41355
And so it begins the endless spaghetti that is rigging. As I am using rope and not nylon rigging line I will be stitching the ends of the ropes as I go along so this is going to take more time to complete but I think it will be worth the effort.
The boom and yardarm are now in place .
Donnieboy
Forum Posts: 36
27th Apr 2018 17:10
mdlbt.com/41356
Great progress.As you say it will take time but the effort is worth it.Will be nice to see the rigging complete.As usual it will be a great job.
Forum Posts: 210
27th Apr 2018 17:21
mdlbt.com/41357
Thanks Donnieboy much appreciated
hammer
Forum Posts: 71
27th Apr 2018 17:59
mdlbt.com/41358
Tug man, as the splicing is taped over. Sized, I can save you a lot of time. Super glue the join, then cover with black heat shrink, Nylon cord will melt. But you should be ok. PS. Twist the joint then super glue. Wear latex gloves. Keep up the very good job. Proper job, they say down here.
hammer
Forum Posts: 71
27th Apr 2018 18:49
mdlbt.com/41361
Oh dear stainless pullers!! Wooden pullies easy to make as well. If you can find my harbour, I have a schooner with about 50 of different size, single doubles & triple.
Forum Posts: 210
27th Apr 2018 19:01
mdlbt.com/41362
Thanks hammer have used the heat shrink like that on a previous boat and i tend to use the grimb tubes for the nylon line.
i did think of making the pulleys but just couldn't get my self motivated to do it.
i have my next project ready for starting and thinking will have to make everything for this one.
hammer
Forum Posts: 71
27th Apr 2018 22:13
mdlbt.com/41367
Read the PM before I saw this & posted reply. Good to see there will be a next one.
Hugh
Forum Posts: 16
28th Apr 2018 07:57
mdlbt.com/41371
Good tip Hammer. Will try that.
Forum Posts: 210
3rd May 2018 17:02
mdlbt.com/41506
Have had a few days of as it was our clubs AGM last weekend so had a lot of paperwork to sort out.
The rigging is coming along now, not rushing this as don't want any mistakes .
Each rigging line and block has been stitched using matching thread to the rigging line (pic1) then a length of heat shrink tubing is placed over the stitching (pic2) .
Depending how things go over next couple of days I am hoping to have the sails fitted by Monday 😎
Forum Posts: 417
3rd May 2018 17:30
mdlbt.com/41507
Great job on the eye splices. and of course the rigging!
Question where did you get you anchor from?
Donnieboy
Forum Posts: 36
3rd May 2018 17:48
mdlbt.com/41508
Nice job on the deck planking.Rigging is progressing nicely.Very tedious.lovely work.
Forum Posts: 210
3rd May 2018 18:04
mdlbt.com/41510
thanks figtree7nts and Donnieboy i purchased the anchor from cornwall model boats, i tend to use these for most of my fittings orders as 99% of time they have in stock although they had to order the rigging blocks in for me due to the quantity needed.
Forum Posts: 417
3rd May 2018 18:23
mdlbt.com/41511
Thanks kmbcsecretary, I just saw the Anchor I need!
Forum Posts: 1834
3rd May 2018 18:44
mdlbt.com/41513
Absolutely BRILL 👍 Right up 'Quality Street' 😉
BTW: didn't you say something about giving up tugs cos they were too heavy? What will this monster weigh when complete? 😲
Forum Posts: 210
3rd May 2018 19:17
mdlbt.com/41515
Thanks Doug yes your right about the tugs but this monster when finished is in old money around 9 kilos which is a struggle for me but got the wife to lift this one into the car 😜.
Forum Posts: 210
4th May 2018 17:19
mdlbt.com/41549
At last 95% of the rigging is now complete and I can now announce that it's ready to start fitting the sails 👍 I do still need to decide how to attach the sails so I can de-sail her for transportation.
Donnieboy
Forum Posts: 36
4th May 2018 18:13
mdlbt.com/41550
That looks great.You certainly work faster than I do.I'm not much in the rigging department.Maybe in the future I'll try.Again,good job.
Forum Posts: 1834
4th May 2018 21:27
mdlbt.com/41554
Nice one 'Cyril' 👍
Re transport: how about hinged masts, like the Ship in a Bottle guys??? 😉
Fold down for transport - at the pond
One 'guy' rope to secure and the whole Shebang stands up ready for action!
Easier written as done I know, but wouldn't it be NEAT!? 😁
Forum Posts: 210
4th May 2018 21:33
mdlbt.com/41556
Nice idea Doug , I have made the top mast so it will drop to help with getting it in and out of the car.
Forum Posts: 1834
4th May 2018 21:40
mdlbt.com/41557
So you're half way there 😉 Good stuff 👍
hammer
Forum Posts: 71
4th May 2018 22:33
mdlbt.com/41558
Removing sails. Each model has its own problems hear. First top mast need to be able to lower, important. Main & stay sails remain attached, on my models they can be reefed in the prototype way. Jibs are ease, eyelets in sail hook on cords. The same with topsails if there are mast hoops a little ingenuity is required. I have spaced the hoops on a cord with hooks to the sail top & bottom. The tension on the cord & sail holds them together. Although the sail is not attached to the hoops it doesn’t notice. I often sail reefed down as I do most of my sailing in the winter. To much else to do in summer.
Forum Posts: 210
4th May 2018 22:46
mdlbt.com/41559
Thanks for that hammer I had thought of using some boom grips where I can get away with it but will see how things go once I start with the sails.
JBRCfloats
5th May 2018 20:29
mdlbt.com/41577
Great build. I'm in the process of building a Mid West Tug Boat and reached the point of needing to place some ballast in the bottom of the hull. I noticed that you used epoxy. I know that epoxy can get hot when curing and if you using a molded hull how do you control the heat issue so as to not warp the hull? I plan on using shot gun shot and been a bit worried about damaging the hull.😁
Forum Posts: 210
5th May 2018 21:19
mdlbt.com/41582
Hi jbrcfloats and welcome to the mad house.
Yes you are correct in saying that epoxy gives of heat while it cures and can cause damage to some of the more flimsy plastic hulls. The best way to be save when using epoxy with these hulls is to use smaller amounts so not to build up to much heat.
Forum Posts: 1834
6th May 2018 00:19
mdlbt.com/41586
Go easy on the hardener!!!
More hardener = faster curing = more heat = hole in vac-form plastic hull.
Stick to the epoxy instructions and you shouldn't have any problems.👍
LESS IS MORE 😉
JBRCfloats
6th May 2018 19:27
mdlbt.com/41604
Thanks for the great advise. I was thinking about making smaller amounts of the resin so that I could control the heat. Nothing worse that spending a lot of time on the tug and then have the hull destroyed while adding ballast. You guys and gals over there really build beautiful models.
Forum Posts: 210
6th May 2018 21:10
mdlbt.com/41609
Thanks jbrcfloats for your kind comments , I'm sure your builds will be just as good after all we all had to start somewhere. It would be nice to see your own build blog on here 👍
Forum Posts: 210
22nd May 2018 21:08
mdlbt.com/42001
Hi all afraid I had to but the builds on hold for a while again had another flare up with my health but things are settling down again now so hopefully I can get back to finishing this boat and enjoying sailing her for the first time.
Forum Posts: 1834
22nd May 2018 21:47
mdlbt.com/42002
Hope you can soon 'get steam up' again Ron.👍
Can't wait for the sailing video!! 😁
All the best, cheers Doug 😎
Forum Posts: 210
24th May 2018 19:44
mdlbt.com/42050
The ships boat is almost complete now have got the floor and seats fixed in place ready for sanding and sealing.
have got some more of the rigging completed just a few more bits to do before fitting the sails.
thanks Doug for your kind words
Forum Posts: 210
31st May 2018 19:34
mdlbt.com/42313
im back on the job again now ( fingers crossed ) no more flare ups .
have got the stand for the ships boat built, varnished and fixed to the boat now, i had to change position of the fixing point for the ships boat because of the sail control wire. I have also got the oars for the ships boat made and given them there first coat of varnish, these were made using some 3mm pine dowel and a scrap piece of 4x2 beech planking strip.
have now started on the canvas cover for the ships boat.
hammer
Forum Posts: 71
31st May 2018 21:55
mdlbt.com/42315
You could have only made one oar as pilots always sculled one oar on the transom. I hope you are satisfied with your model, should be.
Forum Posts: 210
2nd Jun 2018 18:38
mdlbt.com/42346
Today i have made a start fitting the sails starting with the jib and stay sail just have the sail control wire to fix to them.
it has taken most of today just to fit these two as some changes had to be made to some of the rigging lines i had already done but this is my fault trying to get to far ahead of myself rather than being patient.
Donnieboy
Forum Posts: 36
2nd Jun 2018 19:28
mdlbt.com/42347
I find that when the boat is nearing completion I don't always contemplate that there is something I haven't thought through.Just want to get the boat finished and on the water.
You're doing a fabulous job on this boat.Waiting to see it on the water.I have been following the construction.Excellant workmanship.
Forum Posts: 417
2nd Jun 2018 19:40
mdlbt.com/42348
Great job on your build, lots of patients!
I commend you sir!
Forum Posts: 210
7th Jun 2018 17:12
mdlbt.com/42497
Have got the main sail finally fitted after some minor length adjustment on some of the rigging
Pic 1 shows the hand made curtain rings made using 1mm brass rod.
Pic 2 shows mid way through threading the rope along the boom.
Forum Posts: 1834
7th Jun 2018 20:18
mdlbt.com/42505
Brillo 👍 Hat off Sir 😉
May be asking your help some time about re-rigging the mess of a fish cutter I inherited. Just took her apart and started renovating the hull.
Wotta mess 🤔😲 More filler than wood and stern made from a cardboard tape reel 😡 Last pic is roughly what she should look like!
Forum Posts: 210
7th Jun 2018 20:56
mdlbt.com/42507
Thanks Doug for your kind words, looks like you have a big job on there Doug and if need help with the rigging I would be more than happy to help were I can
Forum Posts: 1834
7th Jun 2018 21:24
mdlbt.com/42512
Thanks Ron appreciate that👍
Looks like it'll be a while before I get that far but I'm sure I'll be coming back to you.
Not the least because I am converting a (badly built🤔) static model to RC and have an ambition to make the sails work as well. I know, NUTS!😁
But then, aren't we all just a little 😉 Cheers, Doug 😎
Forum Posts: 210
7th Jun 2018 21:37
mdlbt.com/42515
its our moto isn't it Doug " welcome to the mad house you don't need to be NUTS but it sure helps" 😜
besides we don't do the norm
