April 2018: 21 people March 2018: 13 people February 2018: 8 people January 2018: 25 people December 2017: 7 people November 2017: 13 people October 2017: 9 people September 2017: 4 people
Hello all this is my latest build of the Kingston mouldings Bristol pilot cutter 'mascotte' was purchased from a forum friend who no longer had time to build it.
Sadly Kingston mouldings has now closed down.
The first job was to glue the lead ballast into the bottom of the hull, this was done by using fibreglass resin then a couple of layers of fibreglass to seal the lead shot into the built in keel
The next job was to fit the bulk heads and the deck shelf strips around the edges.
I had some scrap pieces of 8mm OSB board so I used this for the bulk heads which were glued in place using gorilla glue then fibreglassed in once the glue had gone of. The shelf strips are 10mm square oak that were fixed 6mm below final deck hieght as I will be using 4mm ply for the sub deck followed by 2mm planking strips in walnut and beech.
The strengtheners for where the main mast will be fixed in place through the deck were glued in place with gorilla glue and fibreglassed in once the glue had gone of again this timber was an of cut that was to hand but this needed to be substantial as I would be using 12mm dowel for the main mast.
After fitting the 2 lead gel batteries in place (6v 4mah) either side of the mast support and fitting the electrics the sub deck 4mm ply was fitted and glued in place using gorilla glue. If you hadn't guessed I decided to try using the brown gorilla glue on this build to see how it fairs compared to the usual resin and normal wood glue's and I must admit I have been impressed with the results so far . Sorry no pics of this stage as I forgot to take them at the time. This picture shows the area were most of the electrics will be situated for easy access.
Nothing much was done for a while after this stage due to my health halting the build for about 6 months.
But I have started the build again and decided to post it on here for you all.
The next stage was planking the decking and in whales , the deck is planned in walnut and beech which was glued and pinned to the sub deck using titebond 2 .the in whales were lined with mahogany on the inside and walnut on the outside topped with a walnut top rail made using 5mm square section bent and glued together again with titebond 2.
Here is where the build is at now this was taken after the second coat of yacht varnish, all in all it has now had 4 coats of varnish and is ready for painting the lower deck.
Beeuuutiful woodwork 👍 Which varnish did you use? Love the contrasting woods 👍
Young at heart - slightly older in other places 😉 cheers Doug Grant me the Serenity to accept things I can't change, the Courage to change things that I can, and the Wisdom to know the difference!
Thanks Doug it took about 4 weeks in total to complete the planking.
The varnish is Wilko's own brand clear gloss yacht varnish which was sanded with fine wet and dry sand paper between each coat to get that smooth finish on the final coat.
I will show all the hand made fittings next which I have already started making
Ta for the info Ron 👍 I can see you also used bags of my 'secret' ingredient 😉 Your choice of woods really does her proud. Shall watch progress with great interest 😊 Cheers, Doug 😎 BTW: I believe most of the Kingston moulds were taken over by someone else! Have a record of it somewhere in the 'electronic stash'. Will try and dig it out.
That's interesting Doug I was adviced that most of the moulds were cut up for fire wood as he couldn't find anyone that could make the hulls to his standard.
ok here we have some pictures of some of the fittings i have already made using brass. i have taken the pictures with the drawings that come in the folder.
Very sad if that did happen 🤔😭 Last I heard is that Robin wanted to retire to spend more time with his Missus and go travelling, not to mention his sadly neglected own modelling! He apparently retired in April 2016 and stopped all Mail Order. But retained the moulds with the intention of still making a few hulls To Order BUT for Collection Only! Positively no more Mail Order hectic. Sad if that didn't work out. Cheers Doug 😎
here is some of the deck furniture i have made the chimney stack and storage brackets, these are not in the folder and found these after researching the mascotte and finding detailed pictures of the vessel.
Excellent fittings Ron 👍 Have given me inspiration to make some mini hinges for a cabin door on my Sea Scout. 😉 Ciao, Doug 😎
he we have the hatch covers that were made earlier the forward hatch covers the power switch and battery charging points. the mid-ships hatch houses the receiver and the main cabin houses the sail and rudder servos. the last picture is just to show with the hatch covers on
Thank you Doug much appreciated this is the build fully caught up now so everything from now on will be as happens. i was advised by frank nylet of nylet sails that robin used to make the hulls for his yacht kits but was told would no longer supply them as no replacement had been found to take over the moulds and as you say is a very sad loss to the modeling would i have always found his hulls to be outstanding quality. would be nice to see those hinges if you get round to making them , i have tried in the past but failed badly but no doubt i will try again one day.
Your boat is beginning to look suspiciously 'Museum Standard'!👍
Yep, shame about Kingston, but can understand why Robin didn't want to build for Frank's kits anymore (or anyone else's for that matter) wouldn't fit in with his No Hectic policy!
Re 'tin bashing! Here's a couple of examples of my last attempts from several years ago, from my H Class 1936 destroyer, scale 1/72. I note that they need the years of neglect cleaning off 🤔 I'll pass it off as North Atlantic Convoy duty muck😁 First two pics 20mm Oerlikons, made from 0.5mm brass sheet, 1mm copper for the carriage frames and 1 and 2mm brass tube. Guns can elevate 😉 Recoil 'springs' are shrink sleeve, but I now have some suitable real springs. Will try to finish them off when Hotspur comes up for refit completion. Pic 3 is one of the depth charge throwers port side. Core is a 1/4" wood dowel, the rest is 0.5mm brass, tinned copper wire and 2mm brass tube for the firing cylinder. I used John Lambert (RIP) plans for both. Pic 4, the thrower on deck and copper wire ladder rails, crewman shanghaied from Monty's 1/72 Airfix 8th Army. A Desert Rat on board! Under the black square is the hole for the aft torpedo mount. Underneath is the speaker for the "Whoop Whoop". That part of the 'deck' is just painted aircraft silk! Must get back into practise now I've got nowt more important to do 😁 Cheers Doug 😎
Nice job there Doug nice detailing , I've not got the fingers for that scale (I have no feeling in end of my fingers ) the smallest scale I've worked on is 1/32 an MMM eurogirl tug and eldergarth tug but had to sell them last year because I couldn't lift them anymore. This Bristol pilot cutter is 1/16 and finding fittings in this scale is getting harder so no choice but to make the fittings my self. But it keeps me busy and some what active
It's a shame you had to sell your tugs! I collect 1/32 scale tug and boy can they be very heavy... Although you had to switch to sail. Building the boat is almost all the fun! anyway for me it is!
That is very true Ed it was a sad day when my tug's left , they were built to tug as well and had a few trips to balne Moore for the tugging it's what I loved doing. But I'm enjoying this build and looking forward to sailing her for the first time
Very sorry to hear that Ron! "There but for the Grace of God ...." At least you have the consolation of some fine work on the Pilot Cutter 😉 Hope you enjoy many many happy hours sailing her, 👍
I don't know what I would do. If I had to get rid of my collection! But I'm glad you have found another boat to build! looking forward to a video of her Maiden Voyage!
Excellant work on all you are doing.I've had to downsize and lose some of my heavier boats.They were tugs also.I had to have an emergency hernia operation and the doctor said to take it easy.Still recovering.Looking forward to more of your posts.
Hi all not much has been done over last few days been on a downer with my health which has left me house bound but I'm starting to pick up again so hopefully can get back to building again. I have attached the specs and pics of the original mascotte that I have been using to get the detail info from Ron
Not done much today except get some of the fittings and rigging points fix in place while I'm waiting for the weather to warm up so I can get the lower half of the hull painted
Today I have masked of the boat ready for painting when the weather warms up . Materials used where frog masking tape and some paper packaging that came out of the last delivery box from Amazon. Firstly I went round taping of all the fidly bits before completely masking the sides of the hull before applying the paper
Today while waiting for the weather to warm up i have started work on the ships boat which when finished will be 8" in length and a beam of 4". I will be making this using mahogany for the whole boat and the first job was to cut, sand and glue the parts that make up the keel. this was made using 5mmx3mm mahogany sandwiched between 2 lengths of 10mmx2mm mahogany which when finished will give 5mm square keel.i have always found it easier doing it this way rather than try and bend the wood.
The ships boat continued The plans of the ships boat is to make it out of paper but I will be using walnut. I have made and cut out the cardboard templates for the ribs and stenciled them onto a walnut sheet , I cut these out using a coping saw and using permagrit sanding blocks to sand to shape after which I will mark the inner line and cut and final shaping to make the ribs their are 5 ribs in total.
I've said it before and will probably say it again; 'Brilliant woodwork' 👍 And an excellent tutorial, 😎
ships boat continued i have got all the ribs cut out and the outer edge sanded within a couple of mm of the marked edge, leaving the last couple of mm for when they are fixed to the keel.(pic1) i then marked out and filed out the notch for the fixing point to the keel using my permagrit needle files.(pic2) finally today i finished with marking out the inner edge of the (pic3) ribs using my makeshift compass using a steel rule as the smooth edge with a couple of wood coffee stirrers as packers (pic4) to get a uniform width for all the ribs held together with a couple of cable ties ready for cutting out and sanding over the weekend. Ron
the ships boat continued today i have finished cutting out the inner of the ribs with my tungsten rod saw. these where filed and sanded with 250 grit and 2500 grit sandpaper. i have dry test fit each of the ribs to be sure of a square true fit before they will be glued. tomorrow i will be making a jig to hold the keel and ribs while the glue goes of and to keep the frame square till planked. pic 1 is of the rod saw used pic 2 is of the ribs after being filed and sanded pic 3 & 4 is of the dry test fit Ron
ships boat continued hi all have spent today knocking up a simple jig to hold the keel and ribs of the ships boat while the glue goes off. pic 1 & 2 shows the jig set with the keel in place. pic 3 shows the dry fit test to insure all fits square and true. pic 4 is all the ribs glued to the keel. The rig is made up of pieces of ali angle which was a damaged length from when my greenhouse was delivered last year, all i have done is cut 12 pieces approx 10-15mm wide and drilled 1 hole for fixing to the board. I then marked out the board for where the ribs need to be and fixed two of the brackets for either side of the ribs and used a length of 6x2 beech long enough to be clamped to both angles which was for clamping the ribs too, 1 piece of angle was placed at the front and stern to hold the keel square to the board which is a scrap bit of OSB. Each rib was dry fitted to the keel for any fine tuning using a set square to insure square and true, once i was happy with the results i dismantled it and refitted glueing the ribs in place again double checking with the set square to check for any movement in the jig.
Looking good👍 Can't wait to see that wood tidied up and varnished 😊
Thanks Doug have had to do some more research on the ships boat about the planking and finally discovered that it's a clinker built boat so lots of sanding and shaping to do yet
Please don't sand off the 'clinkers' 😲 S'pose you'll have to sand n seal each board individually before it goes on 🤔 Knew there was reason I've never tackled clinker build 😉
That's correct Doug each plank needs to be shaped and sealed as you go. This will be my first clinker hull and just hoping not to many mistakes happen and don't need to scrap it and start again but that's model building 😵 . Don't worry Doug I won't be sanding the clinkers out its took me long enough to find out the details of the ships boat as no info in the plans Ron
I had to open my mouth yesterday didn't I 😭 this morning I took of the clamps to file of the excess glue and dropped the frame onto the floor knocking one of the ribs of 💩so I have had to re-glue the rib back on again so will be starting the blanking tomorrow now.i have included a couple of pics of the boat frame before I dropped it. 😱😱
ships boat planking well the first 2 planks have been fitted today and things went better than expected, guess that is from making sure everything was squared up yesterday 😎 well that's my excuse and i'm sticking to it 😜
The bench is so well camouflaged I couldn't find the ribs at first 🤔 Watching with interest to see how you get 'clinkered' up 😉
Never done it either Ron hence my interest in your progress, fingers crossed ofr yuo (maske ti hrad ot tpye!) 😉 Maybe attached pic helps; LHS clinker, RHS carvel built. Bon chance mon ami 👍
Hi hammer, just spent an interesting half hour looking at your blog for the 6" clinker boat. Lovely work 👍 and a useful tutorial. Good stuff! Any more where that came from? Cheers Doug 😎
The way you've been going so far I'm sure you will Ron 👍
Ships boat continued Hi all the planking is coming along slowly have just attached the fourth plank on either side. Thanks to hammer's excellent clinker build and advice I am starting to get the hang of this. The only problem I am having at the moment is working out the length of the oars , I have some 5mm square section in walnut I thought of machining down to make the oar shafts but unsure of length as these are not on the plans for the ships boat any advice welcome.
Ships boat continued It's coming along now almost finished planking the sides just a couple of planks to fit and can then plank the stern. It's certainly been a learning curve doing my first clinker hull and at this size , there has been a few mistakes but that's modelling .
Back to the main hull Have finally got the hull sprayed today with this heat it has been drying faster than I can spray it on 😄 Firstly the hull was sanded with a 200grit paper to sand of the shiny coating to give the paint something to key too. It has had three coats of undercoat sanded with 2500grít wet and dry paper between each coat.the undercoat used was Halfords rattle can plastic primer. Then the lower hull colour was sprayed on again three coats sanded with 2500grit paper between each coat.colour used was Halfords rattle can ford arctic blue. the top half of the hull was sprayed with two coats only with it being black plus I didn't have enough paint to give it a third coat😋 colour used was Halfords rattle can satin black. Finally the hull was sprayed with Halfords rattle can clear lacquer three coats sanded with 2500grit paper between each coat.
Great job on the paint.Must be nice to be able to paint outside.We're still waiting for the snow to disappear.We are only at 5 degrees.Lovely job.Can't wait to see it finished.
Thanks Donnieboy it has been 28degrees c here today perfect painting weather. I can now start assembly while waiting for the glue to dry on the ships boat planking, been that warm on my shed I managed to get two planks each side today . Normally have to wait 12hrs between planks. Ron
Me too! 👍 Just thought you might have got the rattle cans mixed up 😁 Unusual lower hull colour - but nice 😉
I've started on getting the fittings fitted now the paints dried and also the sail control line has been fitted and tested.i have used 50lb clear carb fishing line for the control wire so it isn't clearly visible. Last job done today was to fit and test the rudder assembly, all's working as it should👍
The rudder assembly was made using a 200mm prop shaft squared of on the lower 3/4 of the shaft to allow for secure fixing for the rudder made from three layers of 4mm ply. The rudder was fixed to the shaft using 2ton epoxy and held in place with three pieces of brass strip which are bolted through the rudder The prop tube bearings were cut of the ends and fixed into the hull for the rudder shaft , I have also installed rubber o rings to insure no water can come in through the rudder posts.
Hi Ron , I have really enjoyed your build,great wood ,brass and painting skills gives us mere mortals (whittlers)something to aim for .seeing the figure reminded me of your other post, when i next pop into work i will see how there getting on with the figures i was getting scaled up and printed from 1/24 to 1/16 and if there ready post some pictures . Almost forgot what are the dimensions of the build ?. Cheers Marky
Hi marky and thanks for your comments very much appreciated the dimensions for the mascotte are 1140x300x310 (l,w,d) I look forward to seeing the images of the figures when they are done. I did purchase some doll house figures but the adult ones are to large but the child ones you could get away with using them as the adults. Today so far not done to much but fit a few more fittings and make the reach hooks. The reach hooks were made using some 2mm I.d brass tubing which was heated and hammered to shape to make the hooks and attached to some round 2mm pine which was sanded and varnished to finish off. Ron
Today I have made the sails storage frames for when there stored in the rig bag.i've not posted pics yet as don't want to show the sails to early in the build. Has also got some more done with the rigging pulley's ready for starting the time consuming job of the rigging hopefully next week. The second pic shows the removable boom rest that I finished making today and have given it a coat of varnish while it's in position. Ron
Hello all have got some more of the rigging points completed and had to re-do the sail control line after dropping my snips onto the line and it caught the edge and nicked it so had to be replaced as no doubt would have snapped once under strain. The ships boat is coming on nicely , have got the stern planked now and have made a start on cleaning up the glue overspill and sanding it down before fitting the floor and seats . Once finished I will be painting the outside of the hull to match the main hull and varnishing the inside with a yacht varnish.
