261
11
ยฃ10
ยฃ15
ยฃ50
ยฃ5
ยฃ10
ยฃ15
ยฃ20
    Page 1 of 116
    Prop size and speed
    I did a lot of amp/watts/rpm and gps speed testing with my twin screw 4 foot fireboat, you might wnat to take a look. The quickest and easiest, and by far cheapest route is change from s prop to x prop thus increasing the pitch. They are real cheap to buy (plasic ones)so get a couple of sizes, start with the smallest. You can buy cheap inline amp meters, so using this you can see how the amp draw alters
    5 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง pmdevlin ( Sub-Lieutenant)
    by StuartE
    5 hours ago
    5 hours ago
    Hints and Tips.
    Excellent, And I bet they are a lot cheaper too. Martin.
    9 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Sub-Lieutenant)
    9 hours ago
    Coming soon.
    Come on Martin -.-. --- -- . --- -. -- .- .-. - .. .- Stop Morsing around ... - --- .--. -- --- .-. ... .. -. --. .- .-. --- ..- -. -.. What is the solution? .-- .... .- - .. ... - .... . ... --- .-.. ..- - .. --- -. ..--.. --.- . -.. John ๐Ÿ˜‰
    12 hours ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    12 hours ago
    Cheap easy anchors
    1 day ago by ๐Ÿ‡ฌ๐Ÿ‡ง DodgyGeezer ( Warrant Officer)
    Air Sea Rescue Launch 123
    2 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    by Will-I-Am
    Eastleigh ... visits
    2 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Tall Paul ( Petty Officer 2nd Class)
    Jun
    19
    2019
    Jun
    23
    2019
    by Tall Paul
    Pond Weed
    by Tall Paul
    water is wet and so was I.
    3 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Brianaro ( Petty Officer 2nd Class)
    by Colin H
    Aerokits Plans
    3 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง donrecardo ( Able Seaman)
    by donrecardo
    by donrecardo
    Can anyone help please?
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง andyhynes ( Leading Seaman)
    by andyhynes
    by Elsrickle
    Reversing Field-Wound motors
    Battery backup
    5 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Sub-Lieutenant)
    5 days ago by ๐Ÿ‡บ๐Ÿ‡ธ tgilchristjr ( Able Seaman)
    by tgilchristjr
    AERKITS SOLENT LIFEBOAT
    6 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง stuartbell3553 ( Recruit)
    by stuartbell3553
    by stuartbell3553
    Waveney class lifeboat
    6 days ago by ๐Ÿ‡ฟ๐Ÿ‡ฆ redpmg ( Petty Officer 1st Class)
    by Jerry1
    HAZELGARTH
    Help and advice please
    by Gren-York
    Another boat leaves the yard
    by GrahamP74
    SS Torrey Canyon
    8 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Airtrooper ( Recruit)
    by Airtrooper
    Have I been Demoted
    8 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง MouldBuilder ( Warrant Officer)
    by Scratchbuilder
    Vosper mtb 379
    9 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Boats ( Recruit)
    by Boats
    by Boats
    10 days ago by ๐Ÿ‡จ๐Ÿ‡ฆ Donnieboy ( Warrant Officer)
    21 days ago
    by Donnieboy
    11 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Fred ( Chief Petty Officer 2nd Class)
    by andyhynes
    by Fred
    12 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    12 days ago by ๐Ÿ‡จ๐Ÿ‡ฆ Ron ( Midshipman)
    by andyhynes
    Site glitches!
    13 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง mturpin013 ( Sub-Lieutenant)
    2 months ago
    by mturpin013
    RC Speedboat Driver Needed- Shoot- London/Essex- Available?
    Hi all, I was wondering if there are any RC Boat Speedboat Drivers who have their own boat (1-2 feet long) with a visible propeller, preferably in the London/Essex area? It would be for a filming shoot on the 4th July. If so, please get in touch with me ๐Ÿ˜Š Thanks, Rachael ๐Ÿ˜Š
    15 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Rach2019 ( Recruit)
    by Rach2019
    Page 1 of 116
