261
11
ยฃ10
ยฃ15
ยฃ50
ยฃ5
ยฃ10
ยฃ15
ยฃ20
    Page 1 of 116
    Coming soon.
    Ah...of course.......Morse Code ! Should have sussed that long ago! -.-. .-.. . ...- . .-. ....... -... ..- --. --. . .-. Rob.
    1 hour ago by ๐Ÿ‡ฌ๐Ÿ‡ง robbob ( Commander)
    1 hour ago
    by robbob
    Hi Paul. Welcome back, it's been a while ๐Ÿ˜€ Look back at the ealy stages of my Crash Tender build, the sequence and methods of that should be a good guide to way to do it. This method of construction was pretty much common to all the AeroKits boats. Here's my blog: https://model-boats.com/blogs/23951 Tip. Use a heat gun to bend the skins, the heat relaxes the glue between the plys and when it cools the bend is quite well set. Much easier that hot water and steam, I did this for my Thames Police Launch and it works great. Rob.
    11 hours ago
    1 hour ago
    by robbob
    Hints and Tips.
    PUSH ROD JOINERS Hi Guys, This little tip is probably well known. To lengthen my pushrods I use electrical terminal blocks, I cut of the plastic insulation and just use the metal part. Martin.
    1 hour ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Sub-Lieutenant)
    1 hour ago
    Cheap easy anchors
    18 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง DodgyGeezer ( Warrant Officer)
    22 hours ago
    18 hours ago
    Air Sea Rescue Launch 123
    22 hours ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    by Will-I-Am
    22 hours ago
    Eastleigh ... visits
    24 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง Tall Paul ( Petty Officer 2nd Class)
    Jun
    19
    2019
    Jun
    23
    2019
    24 hours ago
    by Tall Paul
    Pond Weed
    24 hours ago
    by Tall Paul
    water is wet and so was I.
    3 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Brianaro ( Petty Officer 2nd Class)
    by Colin H
    Aerokits Plans
    3 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง donrecardo ( Able Seaman)
    by donrecardo
    by donrecardo
    Can anyone help please?
    3 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง andyhynes ( Leading Seaman)
    by andyhynes
    by Elsrickle
    Reversing Field-Wound motors
    Battery backup
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Sub-Lieutenant)
    5 days ago by ๐Ÿ‡บ๐Ÿ‡ธ tgilchristjr ( Able Seaman)
    by tgilchristjr
    AERKITS SOLENT LIFEBOAT
    5 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง stuartbell3553 ( Recruit)
    by stuartbell3553
    by stuartbell3553
    Waveney class lifeboat
    5 days ago by ๐Ÿ‡ฟ๐Ÿ‡ฆ redpmg ( Petty Officer 1st Class)
    by Jerry1
    HAZELGARTH
    Help and advice please
    by Gren-York
    Another boat leaves the yard
    by GrahamP74
    Prop size and speed
    Hi Sam, Yes, by all means mount the motor on an angled block of wood to align the shafts correctly. As you can see in my Sea Scout engine flat. I used a standard 400 size motor mount (from Krick) screwed down to the block. To align the shafts I used a chunk of brass rod drilled on my mini lathe to match both shaft diameters. Once you get the angle just right you can glue down the block, tack it first with cyano gel or 5 minute epoxy. When set you can remove the motor and mount fit the correct coupling. I try to avoid universal joints and use the flexible spiral types - again see the Sea Scout pic. You can also see that I took the opportunity during the refit to fit an oiler pipe as well ๐Ÿ˜‰ Epoxy the block all round. When set reassemble motor and mounting bracket and check that the shaft rotates freely without straining / bending the coupling or binding anywhere. Good luck. Cheers, Doug๐Ÿ˜Ž
    by StuartE
    SS Torrey Canyon
    8 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Airtrooper ( Recruit)
    by Airtrooper
    Have I been Demoted
    8 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง MouldBuilder ( Warrant Officer)
    by Scratchbuilder
    Vosper mtb 379
    8 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Boats ( Recruit)
    by Boats
    by Boats
    9 days ago by ๐Ÿ‡จ๐Ÿ‡ฆ Donnieboy ( Warrant Officer)
    20 days ago
    by Donnieboy
    11 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Fred ( Chief Petty Officer 2nd Class)
    by andyhynes
    by Fred
    12 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    12 days ago by ๐Ÿ‡จ๐Ÿ‡ฆ Ron ( Midshipman)
    by andyhynes
    Site glitches!
    13 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง mturpin013 ( Sub-Lieutenant)
    2 months ago
    by mturpin013
    RC Speedboat Driver Needed- Shoot- London/Essex- Available?
    Hi all, I was wondering if there are any RC Boat Speedboat Drivers who have their own boat (1-2 feet long) with a visible propeller, preferably in the London/Essex area? It would be for a filming shoot on the 4th July. If so, please get in touch with me ๐Ÿ˜Š Thanks, Rachael ๐Ÿ˜Š
    14 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Rach2019 ( Recruit)
    by Rach2019
    Page 1 of 116
