May 2018: 4 people
October 2017: 6 people
Active Users (6)
>> Home > Forum > Electrical Related > Motor cutting out.
Motor cutting out.
(1098 views)
stevethomas
Forum Posts: 18
30th Oct 2016 11:25
mdlbt.com/24111
Hi guys I'm looking for yet more help and advice. My billings white star has a
MFA RE 380 7.2 volt motor with a viper 15 amp 6 to 12 volt esc, a 9.6 volt rc car battery. I have just tried the boat in my pool only to find that after 10 feet the motor cuts out.
I have checked the motor to see if it's getting hot, it's not, checked the esc for the same and that is cold. I have also checked the battery and that is still charged, I also tried another battery 8.4 volt 3000. Still the same. Your thoughts would be great please.
Many Thanks.
Steve.
Forum Posts: 392
30th Oct 2016 13:46
mdlbt.com/24113
Hi Steve
Did you check the batteries on the controller itself.
try resetting the ESC, did you look at the solder points on the motor.
stevethomas
Forum Posts: 18
30th Oct 2016 14:16
mdlbt.com/24114
The solder points seem to be ok. I'll try really setting the esc and see how we do with that. It only seems to happen wwen under load ie in water, out of water is fine.
stevethomas
Forum Posts: 18
30th Oct 2016 15:59
mdlbt.com/24115
Ok I have tried to re set the ESC which made no difference, its almost as if the battery is running flat but put the battery on the volt meter and its fine. ???
Forum Posts: 392
30th Oct 2016 16:12
mdlbt.com/24116
Hi Steve
Why don't you try a 6 volt or 7.2 volt battery instead, I think the motor is being over driven.
so the safety on the ESC is being tripped try this and see if it works.
Forum Posts: 392
30th Oct 2016 16:32
mdlbt.com/24117
The RE380 Motor has a Stall Current of 25.19 Amps at 7.2 volts so if you are using too much volts it will trigger the safety on the ESC.
If anybody degrees with my analogies please interject!
30th Oct 2016 16:52
mdlbt.com/24118
Hi Steve, your comment about the battery seeming flat but showing 7.2volts. it could be that the battery capacity is nil or very low, put a 6 volt bulb across the terminals to act as a load, then monitor the ammeter, if the amps drops very quickly the battery is dead. Hope this helps Mark
stevethomas
Forum Posts: 18
30th Oct 2016 16:56
mdlbt.com/24119
Didn't think of that doh lol ok I'll see if I have a 6 volt and give that a go thanks. it's amazing isn't it put a few heads together!!
stevethomas
Forum Posts: 18
30th Oct 2016 17:11
mdlbt.com/24120
So are you saying I need 30/ 40 amp esc?
Forum Posts: 392
30th Oct 2016 18:56
mdlbt.com/24123
No Steve
I don't think you need to replace the ESC with a higher Amp ESC,
I would how ever follow JARVO's recommendation and try the light as a load maybe you have a bad battery.
30th Oct 2016 19:21
mdlbt.com/24124
Hi Steve
What radio gear are you using? If it's not 2.4 is the aerial above the deck? Is the motor suppressed? Are your heavy current wires remote from any receiver and servo wires?
Your symptoms sound more like radio interference than battery power problems.
The advice given so far should help you solve faulty wiring and batteries.
You do need good connections between the battery and ESC and motor. Electrics deteriorate over time and I have found the Tamiya type connectors to be unreliable at high current. I used to squeeze the female socket together and clean the male plug with fine sandpaper.
Another common problem with older equipment can be corrosion in any of the black wire connections. I recently repaired a 7.2v NiMh that gave correct voltages but failed under load. The problem was corrosion inside the black wire where it had been repeatably bent when being fitted in a boat. I traced it to a thinning of the wire near the battery. Pulling on the wire resulted in the copper parting where it was rotten. There should be little or no give in good wiring. Replacing the wire restored the battery to full working order.
Good hunting and I hope you find a solution.
stevethomas
Forum Posts: 18
30th Oct 2016 19:47
mdlbt.com/24125
Hi Dave, Radio is new 2.4 so am I right in thinking that rules out the interference ?
The 8.4 battery that I also tried is also new and the same was happening with that battery plugged in.
I think I am going to try a New 7.2 volt 3000 mah battery and see how that goes and if I still have the problem the look at perhaps a new motor which has been in the boat for over 10 yrs and sat still for 90 % of that time.
31st Oct 2016 09:52
mdlbt.com/24141
Yes 2.4 is pretty interference free, but you do need to separate the dirty high current wires from all signal wires. I very old motor may be generating lots of interference and could benefit from some suppression. The ESC is also subject to interference and if this is an old VIPER unit there was a faulty batch sold several years ago but I have had no problems with the several I have used in recent years.
I believe you have ruled out battery and plug problems and the finger is pointing to a motor/interference problem.
I am assuming you can still control the rudder servo at a greater range with the motor not running? Some modern radios have a low power range test mode which may be causing the short range.
Can you try another motor? It could be any motor and not fitted in the boat, if the symptoms disappear you will have found the problem.
Good luck
stevethomas
Forum Posts: 18
31st Oct 2016 10:49
mdlbt.com/24142
Morning Dave, the rudder servo works fine so that's that one out. I do have another motor that came out of an old rc glider, the motor is a simprop Power-Speed 1500-10 12 volt. I'll try this one later today and post the out come. Thanks for your help Dave
Steve.
