January 2018: 22 people
Active Users (23)
>> Home > Forum > Electrical Related > Scudder
Scudder
(1584 views)
frankburgess
Forum Posts: 12
7th Nov 2016 09:47
mdlbt.com/24238
I have refurbished this 'Scudder' hydroplane designed by Vic Smeed in the 50/60,s. I think it looks a bit like a marine Douglas Dakota!
In place of a an OS MAX 3 15 glow diesel, I fitted a A2212/13T, 1000KV brushless motor and propeller and an HW H30A controller.
It goes well but will not quite plane.
It current uses a NiCad 7.2v.
I have adjusted the angle of the prop/motor to push the nose up a bit, but will the motor/controller set up take a higher voltage so it will have more power?
Hi Gents
Update on the Scudder...I fitted an 11v Lipo, and relaunched. Loads of power; the hydro immediately went onto the plane and ran very fast....then the trouble started!
The roof flew off, passed through the prop, and was chopped up...this in turn damaged the prop blades and possibly through vibration, the motor mount then broke up!
Maldon never had so much entertainment!
Forum Posts: 425
9th Nov 2016 17:27
mdlbt.com/24259
data on your motor gives
Max V 3s lipo ( nominal 12v)
best prop 9x6 or 10x5 E props
when at 3s lipo battery.
frankburgess
Forum Posts: 12
9th Nov 2016 17:54
mdlbt.com/24260
thanks...I can give it more power!
Forum Posts: 425
10th Nov 2016 05:05
mdlbt.com/24263
Sorry for the terse reply I tried posting a couple of times and got error messages.
Do please get a watt meter you should be pulling no more than 12A whatever prop you use.
Quite honestly to replace a 3.5cc motor I would think you need something a little beefier.
Received wisdom would suggest you look for something in the 3-400W class.
http://www.brchobbies.co.uk/catalog/product_info.php?product...
http://brchobbies.co.uk/catalog/product_info.php?products_id...
The above are only examples not recommendations I have never used that supplier.
unfortunately you will also need to replace your ESC !!!
Forum Posts: 1470
10th Nov 2016 11:01
mdlbt.com/24268
I would agree with Haverlock's advice so far and would add the BRChobbies is a good supplier of motors/Esc and batteries. I have used them in the past and their products are 1st class.
I also believe you will need a much beefier motor and ESC (your wattmeter) will give you the amps and watts used so you will be able to avoid cooking and electrics.
NiMh batteries give good power but for your application you need lots of power and LiPos are the best choice.
Going back to my flying days it was usual the try several different sizes and pitches of propeller before the optimum was achieved. You cannot just add any prop to a brushless motor as they require a load that enables them to work within their wattage.
That is why you need a Wattmeter so you can check and also make sure you are not exceeding the ESC rating or overloading the battery capacity.
This is important with LiPos as they should not be discharged below about 3.3v but this should be marked on the batteries. Many ESCs have a built in cut off that can be set to the correct value. Unlike other batteries LiPos change internally if abused and there have been many instances where fires have resulted. U-tube has many examples.
If you are new to LiPos then you need to be aware of the correct charging procedure using a dedicated charger. LiPos should never be charged unattended and preferably in a charging bag in an area near to an outside door should the need arise.
I have used LiPos for many years without incident so correct use will reduce the chance of any accidents. As with any high speed high power setup you do need to make sure everything is securely fastened and the wiring neat and of the correct capacity. I once cooked a motor because I had not secured it correctly, I now always use bolts locknuts and washers, and check the mounting before every sail.
Good luck and some pics and perhaps video on water would be good to see
frankburgess
Forum Posts: 12
11th Nov 2016 10:14
mdlbt.com/24281
Thanks very much for your advice......running the model at my club at Maldon certainly generates a lot of interest.......there's nothing else like it, so there are lots of suggestions. One of our blokes is going to bring a 12v lipo Batt so we will see if the increased power gets it on the plane.
Angling the motor helped a little, another possibility is to reduce the angle of the hull profile at the bows.
Anyway...keep you posted.
Maybe see you at Warwick ...the Maldon Coach should arrive about 11am on Saturday.
Forum Posts: 1470
11th Nov 2016 11:22
mdlbt.com/24282
Good luck with the test. I suggest you only try a quick short circuit initially and then check your installation to make sure nothing is getting hot. LiPos and brushless work well together but both are low resistance devices so can and do take lots of power very quickly if not correctly matched.
Forum Posts: 425
11th Nov 2016 11:37
mdlbt.com/24283
you might want to lengthen the short circuit as they are bad for electrics !!!!!!!!!
frankburgess
Forum Posts: 12
11th Nov 2016 19:59
mdlbt.com/24288
Thanks gentlemen, but you might as well know I am famous for fires and sinkings!
Now you know why the club members were so interested in the Scudder trials.........................its like a Roman spectacle!
Forum Posts: 186
16th Nov 2016 00:41
mdlbt.com/24368
You may also want to try playing with the thrust .Air boats are funny things in that respect with the the angles often being the opposite of the expected. Did you know that Vic did a similar boat with a tractor screw called SKIDDER ? I did this and his 3 sponson Pond Skater. They both needed a few degrees of down thrust contrary to what you might expect to get them to plane.
Forum Posts: 186
16th Nov 2016 01:05
mdlbt.com/24370
http://www.modelboats.co.uk/forums/postings.asp?th=89630 this link could put you intouch with the guy who built it from the plans You should be able to obtin the reccomended thrust angles I hope this helps John
boaty
Forum Posts: 31
16th Nov 2016 10:07
mdlbt.com/24377
😀 😊 Really great to see an airscrew driven boat especially one designed by Vic Smeed.
Last one I had was a scratch built free running one powered by a Cox Babe Bee back in 1968.
Main benefits of that were you had to run round the lake to catch it before it hit the banks. It was a lot cheaper than an exercise bike.
The Vic Smeed design looks really nice and with modern technology there is a lot more potential for this type of model.
Its got me thinking now about building one . I am sure that some of the plans for the original ones are still available . Other option is to scratch build, fit it with a brushless electric motor and radio then go on a diet.
Have fun- Boaty
Dave Keech
Forum Posts: 186
16th Nov 2016 17:17
mdlbt.com/24384
You're right about the running but we had a round pond and if you set the rudder right it would circle until it ran out of juice.The POND SKATER has recently been done to a bigger size on one with radio.I saw it on a couple of free plans sites but can't recall which had the bigger info. John
Forum Posts: 186
16th Nov 2016 20:14
mdlbt.com/24388
BTW Just Google Vic Smeed Model boat plans and follow the links
boaty
Forum Posts: 31
16th Nov 2016 21:16
mdlbt.com/24389
Thanks for that. It will be good to see all those Vic Smeed plans again
Boaty 😊
Dave Keech
boaty
Forum Posts: 31
16th Nov 2016 21:17
mdlbt.com/24390
Boaty 😊
Dave Keech
