February 2018: 5 people
Active Users (8)
>> Home > Forum > Electrical Related > Wiring in a rx, an ESC and a battery (pack)
(722 views)
NickW
Forum Posts: 75
16th May 2017 15:27
mdlbt.com/28967
Ok boys and gi....er boys....Last week Dave M (Dave) and RNinMunich (Doug) very kindly puppy walked me through how NOT to wire up your boat, esp to prevent smoke appearing and burning out ESC's and Rx's. So now I have a 'new' boat, the Bristol Bay....my pride & joy, my baby.....and I have a new Rx and a new ESC to fit. Only this time I don't want to make smoke (I can get a machine off eBay for that)....do I research on the net how to wire up? Is it special knowledge only Fleet Admirals and wizard's get to know? I so need to go sailing on Thursday I need help (i'v got an email ready for the devil and the promise of my soul if all else fails).....attached are photo's of the wiring etc and the battery pack's are I believe NiCad
Forum Posts: 425
16th May 2017 16:40
mdlbt.com/28971
first take a deep breath and calm down its not rocket science.
Question does your ESC have a battery eliminator ?
if so take away the dry batteries to use in something else.
Now your nicads connect to the POWER side of the esc. make sure you have the correct polarity.
The servo plug from the ESC plugs into your receiver whichever is your throttle channel. If you have a modern set then you can put it on the wrong way round with no worries since positive is the centre post.
The output of the ESC connect to your motor. If its a brushed motor no need to worry about polarity for now.
With your ESC there should be some setup instructions if there are none ......
Usually its connect and switch on receiver then switch transmitter on with throttle full listen for beeps then go to low throttle. Switch receiver off. When you switch on in future make sure transmitter is switched on FIRST
ok having gotten this far it only remains to check the direction of rotation of the motor. Take off the prop ( saves fingers) and put a piece of masking tale around end of prop shaft.
Switch on transmitter switch on receiver and try the throttle. If the motor spins in correct direction fine if not
Brushed motor swap the motor leads over
Brushless motor swap any 2 of the 3 motor leads over.
Job done have a cuppa then decide to sort out the rudder.
NickW
Forum Posts: 75
17th May 2017 13:09
mdlbt.com/28983
Thanks for the guidance....I seem to have got there without creating smoke and I still have all my fingers so successfully missed the prop!!!! Everything appears to be working other than a noise coming from the ESC or somewhere else that I can't fathom. Switch on and all lights are working (ESC & rx) move throttle control and screw turns in right direction but the noise is a tad worrying/annoying....think it might be a trip to the Army/Navy stores for some ear-muffs :-)
NickW
Forum Posts: 75
17th May 2017 13:14
mdlbt.com/28984
But my Saturday will now consist of me sailing my new baby and not writing reams of words, trawling through mathematical material on the tinterweb, annoying the kind gentlemen on here, annoying anyone else I can think of and telling my sister how rubbish I am at electronics....which I do on a daily basis....she has now made a note for my headstone 'Here lies Nick, was really thick, lost his head, coz he wired the RED' Really cannot wait for Saturday!!!!
Forum Posts: 1301
17th May 2017 14:27
mdlbt.com/28985
Hearty Congrats 👍
What sort of noise?
Can you feel any vibrations from the motor and/or coupling - prop shaft?
Carefully test motor / shaft with your finger tips!!
Dry bearing somewhere perhaps?
cheers Doug 😎
Forum Posts: 1301
17th May 2017 14:29
mdlbt.com/28986
PS or should we call you 'Dr Faust' ?? 😎
NickW
Forum Posts: 75
17th May 2017 19:25
mdlbt.com/29008
It's a tinny type noise, no vibrations or anything I can see/feel.... I'm using the Tamco Tx and Rx along with an Mtroniks Viper 20 ESC....once it's all switched on the green rx light is on and the red/green light is on on the ESC....the Tx is also switched on and all is quiet...once the throttle moves the sound starts...possibly the motor, could be a normal sound one should expect....the coupling appears ok
Forum Posts: 1301
17th May 2017 20:12
mdlbt.com/29009
Hi Nick,
(Sorry - more questions!!)
Do you get the same noise in both forward and reverse?
Try a drop of light machine oil on the motor bearings.
Which motor is it?
Then move back along the shaft input and output.
Is there any slack in the coupling joint?
If so a spot of grease helps quieten it at least, if nowt else Vaseline will do.
