January 2018: 22 people
Active Users (13)
>> Home > Forum > Electrical Related > Flickering LED
Flickering LED
(644 views)
Skipper44
14th Jun 2017 16:19
mdlbt.com/30173
I have an LED which when I plug in just flickers randomly even with no flicker unit, I have tested the same equipment with other LEDs and they are all fine. This is very annoying as it is a search light! Does anyone know what he problem is / how to fix it?
Forum Posts: 1203
14th Jun 2017 16:28
mdlbt.com/30176
Hi Skipper, I assume a white LED. What voltage are you using and what value series resistor?
PS If we can't fix it - put it in a Signal Lamp 😉
14th Jun 2017 16:29
mdlbt.com/30177
Looks like a bulb change is required
EAGLE
Forum Posts: 43
14th Jun 2017 16:33
mdlbt.com/30179
I think you have got a flickering LED, they are used in old steam tug, to imitate oil lamps. I hope this helps.
Forum Posts: 1203
14th Jun 2017 17:04
mdlbt.com/30181
He may be right! Flicker LEDs are made for candle lamps, but they are usually only for AC mains lamps! ALL LEDs flicker if you use them on an non-rectified voltage, cos the voltage is constantly switching on and off. The flicker rate is usually between 50/60 to 120Hz so almost all people will never notice it.
If you are using a DC supply it should come on when it has sufficient voltage and current and stay on. UNLESS - it is a DC type with a tiny 'flicker chip' built in! Then your only option is to use it for a signal lamp😉
Otherwise I suspect you may need to reduce the series resistor slightly to push more current through it to keep it on.
What type of LED is it? Do you know the manufacturer and type number?
EAGLE
Forum Posts: 43
14th Jun 2017 17:50
mdlbt.com/30185
If you go on to Components web site you will find Flickering LED's, l have used them on my TID. There forward volts is 3.3.
EAGLE
Forum Posts: 43
14th Jun 2017 17:59
mdlbt.com/30186
Sorry the volts are 2.4.
Forum Posts: 1470
15th Jun 2017 09:29
mdlbt.com/30195
Hi Skipper
I have just found exactly the same problem with a LED on my Trent which I am doing some rework on. It's not a constant flicker more a random dimming followed by a couple of flickers. The electrical connection is OK and the problem was with the LED. It's in a tight space and I had damaged the leads into the LED resulting in the fault. I agree with Sonar and believe your best solution is to replace the faulty LED with another if you are sure the electrical connection is OK.
Forum Posts: 1203
15th Jun 2017 12:08
mdlbt.com/30203
Yep! Quickest easiest way if the other LEDs work in the same circuit ...
