January 2018: 11 people
May 2017: 8 people
April 2017: 3 people
Active Users (20)
(2390 views)
16th Oct 2017 21:42
mdlbt.com/34594
Berty
17th Oct 2017 11:29
mdlbt.com/34626
17th Oct 2017 16:55
mdlbt.com/34641
Hi Berty,
John,
Forum Posts: 1453
17th Oct 2017 17:31
mdlbt.com/34647
Interesting.
17th Oct 2017 18:08
mdlbt.com/34649
Forum Posts: 1453
17th Oct 2017 18:43
mdlbt.com/34650
17th Oct 2017 20:29
mdlbt.com/34653
Forum Posts: 520
17th Oct 2017 20:54
mdlbt.com/34656
Berty
17th Oct 2017 22:22
mdlbt.com/34674
Hi John
Berty
17th Oct 2017 22:23
mdlbt.com/34675
Hi Jarvo,
17th Oct 2017 22:27
mdlbt.com/34676
Hi Berty,
Forum Posts: 1453
17th Oct 2017 23:37
mdlbt.com/34687
18th Oct 2017 00:39
mdlbt.com/34690
Forum Posts: 15
18th Oct 2017 03:14
mdlbt.com/34695
Hi John,
Forum Posts: 1176
18th Oct 2017 13:09
mdlbt.com/34703
Good luck, Doug 😎
Forum Posts: 15
18th Oct 2017 13:46
mdlbt.com/34705
Forum Posts: 1176
18th Oct 2017 13:54
mdlbt.com/34706
18th Oct 2017 20:59
mdlbt.com/34732
Thank you all,
Forum Posts: 1176
18th Oct 2017 21:21
mdlbt.com/34737
Good luck, Doug 😎
Forum Posts: 1453
18th Oct 2017 21:27
mdlbt.com/34738
18th Oct 2017 22:27
mdlbt.com/34744
Forum Posts: 1176
19th Oct 2017 00:51
mdlbt.com/34765
Good luck John 👍
tomarack
Forum Posts: 24
19th Oct 2017 12:15
mdlbt.com/34784
tomarack
Forum Posts: 24
20th Oct 2017 15:53
mdlbt.com/34811
hi,
20th Oct 2017 22:40
mdlbt.com/34813
Thanks Tom.
Forum Posts: 425
21st Oct 2017 08:32
mdlbt.com/34819
Forum Posts: 425
22nd Oct 2017 05:50
mdlbt.com/34845
Forum Posts: 1176
22nd Oct 2017 05:58
mdlbt.com/34846
22nd Oct 2017 19:47
mdlbt.com/34861
Forum Posts: 1453
22nd Oct 2017 20:47
mdlbt.com/34863
Hi John
22nd Oct 2017 21:49
mdlbt.com/34867
Mzee
24th Oct 2017 14:46
mdlbt.com/34926
29th Oct 2017 18:08
mdlbt.com/35136
1st Nov 2017 20:44
mdlbt.com/35216
Forum Posts: 15
1st Nov 2017 22:20
mdlbt.com/35220
Hi John,
1st Nov 2017 22:47
mdlbt.com/35221
Forum Posts: 1453
2nd Nov 2017 01:03
mdlbt.com/35223
Hi John
Forum Posts: 15
2nd Nov 2017 01:33
mdlbt.com/35225
John,
Separately
Colin T
2nd Nov 2017 17:20
mdlbt.com/35237
John,
Forum Posts: 1176
2nd Nov 2017 17:52
mdlbt.com/35238
2nd Nov 2017 23:13
mdlbt.com/35252
Forum Posts: 425
2nd Nov 2017 23:24
mdlbt.com/35253
2nd Nov 2017 23:53
mdlbt.com/35254
Forum Posts: 425
3rd Nov 2017 00:16
mdlbt.com/35255
Forum Posts: 425
4th Nov 2017 10:11
mdlbt.com/35311
4th Nov 2017 20:30
mdlbt.com/35330
Forum Posts: 1453
4th Nov 2017 20:54
mdlbt.com/35331
4th Nov 2017 22:01
mdlbt.com/35333
Forum Posts: 1176
4th Nov 2017 22:10
mdlbt.com/35334
Forum Posts: 15
4th Nov 2017 22:16
mdlbt.com/35335
Hi John,
4th Nov 2017 22:19
mdlbt.com/35336
Forum Posts: 1176
4th Nov 2017 22:33
mdlbt.com/35337
Hmm!🤔
4th Nov 2017 22:44
mdlbt.com/35339
Forum Posts: 1453
4th Nov 2017 23:28
mdlbt.com/35341
Forum Posts: 1176
4th Nov 2017 23:55
mdlbt.com/35342
For example;
What is the current setup?
TX and RX make & model?
Motors?
BEC or not?
Power source?
Charge status?
And on the battery as well.
5th Nov 2017 00:23
mdlbt.com/35343
Forum Posts: 329
5th Nov 2017 17:43
mdlbt.com/35371
5th Nov 2017 18:50
mdlbt.com/35378
Forum Posts: 329
5th Nov 2017 18:53
mdlbt.com/35379
5th Nov 2017 18:57
mdlbt.com/35380
Berty
5th Nov 2017 19:22
mdlbt.com/35381
Hi John..
Berty
5th Nov 2017 21:00
mdlbt.com/35389
tomarack
Forum Posts: 24
6th Nov 2017 17:23
mdlbt.com/35423
Maybe it will help you
Tom
6th Nov 2017 20:39
mdlbt.com/35426
7th Nov 2017 18:46
mdlbt.com/35454
Forum Posts: 1453
7th Nov 2017 20:23
mdlbt.com/35458
Hi John
Thanks for the pics.
Forum Posts: 329
7th Nov 2017 20:36
mdlbt.com/35462
Dave,
7th Nov 2017 21:03
mdlbt.com/35466
Forum Posts: 1176
8th Nov 2017 20:15
mdlbt.com/35540
Hi John,
Forum Posts: 1176
8th Nov 2017 20:31
mdlbt.com/35541
Hi John,
earlier you wrote
8th Nov 2017 20:39
mdlbt.com/35544
Forum Posts: 1176
8th Nov 2017 20:59
mdlbt.com/35545
All's well that ends well! 👍
Forum Posts: 1453
8th Nov 2017 21:56
mdlbt.com/35552
Hi John
8th Nov 2017 22:47
mdlbt.com/35555
