Active Users (22)
>> Home > Forum > Electrical Related > Brushless motors
Brushless motors
(2799 views)
Spitfire99
Forum Posts: 32
8th Jan 2018 14:03
mdlbt.com/37268
I'm going to use brushless motors for the first time.
I have a brushless ESC. Can I run two motors off of one ESC like brushed motors or will I need two brushless ESC's 🤔
Kevin
"The only thing necessary for the triumph of evil is for good men to do nothing". (Edmund Burke)
8th Jan 2018 14:48
mdlbt.com/37269
Hi Spitfire,
Sorry NO!
This is because the ESC needs feedback from the motor providing info on the position of the rotor and thus provide the correct phasing; either via a shaft position sensing system or by the back emf of the coils in the more common 'sensor-less' types for models.
It can’t do this simultaneously for two motors I'm afraid. You'd confuse the poor thing and give it the 'collywobbles' 😉
You can drive two BL ESCs from one channel using a 'Y' lead or use two channels for independent motor control like in 'Tank Steering'.
PS If you do drive two BL ESCs from one channel you MUST disconnect the Red supply lead (BEC) from one of the ESC leads to prevent damage. If you use a separate RX supply battery you MUST disconnect both Red leads from the ESCs to disconnect their BECs.
Spitfire99
Forum Posts: 32
14th Jan 2018 16:54
mdlbt.com/37384
Hi and thanks. This sounds all very complicated. I've never used brushless mortors before. Or brushless ESC.
Disconnect red lead ?
Anyone got a diagram out there they could send me 😳
Kevin
Spitfire99
Forum Posts: 32
14th Jan 2018 16:55
mdlbt.com/37385
Help needed on this one 😳
Kevin
Elsrickle
Forum Posts: 26
14th Jan 2018 19:18
mdlbt.com/37388
Here is a sketch I have quickly made hope this might help
Elsrickle
Forum Posts: 26
14th Jan 2018 19:20
mdlbt.com/37389
Scrub that put the cut wire in wrong place new drawing coming shortly
Elsrickle
Forum Posts: 26
14th Jan 2018 19:37
mdlbt.com/37390
Here is the correct drawing now
Spitfire99
Forum Posts: 32
16th Jan 2018 01:19
mdlbt.com/37428
Thanks Elsrckle
What could go wrong now. Fitting the ESC over the weekend just to confirm it only the one red wire you cut in your diagram. 😳
Kevin
16th Jan 2018 10:00
mdlbt.com/37432
Hi Spitfire
Yes you need to isolate one of the BEC supplies from the ESC (red wire).
You can cut the wire but I prefer to remove the connector from the plug, you will find a small tab holds the connector in place and if you carefully lift this tab with a scalpel blade the connector will pull out of the plug and can be taped to the other leads. It will then be available for future use should you need a BEC supply.
Good luck
Elsrickle
Forum Posts: 26
16th Jan 2018 14:00
mdlbt.com/37438
As Dave explains that’s the best way of removing the red wire
Spitfire99
Forum Posts: 32
16th Jan 2018 17:28
mdlbt.com/37443
Thanks Dave
I'm very new to this brushless world and not quite sure what a ESC or BEC is yet. Is one of them a speed controller. I think I'm being a bit thick here and do not want to cut or remove the wrong red wire. As there a few. May have to send you guys a photo
Kevin
Forum Posts: 437
16th Jan 2018 17:35
mdlbt.com/37444
Not thick at all, you only learn if you ask questions.
ESC = Electronic Speed Control.
BEC = Battery Eliminator Circuit.
As to the rest I'm sure another member will put you right, try RNmunich he is well up on electrics.
Spitfire99
Forum Posts: 32
16th Jan 2018 17:38
mdlbt.com/37445
Thinks Colin
Kevin
Spitfire99
Forum Posts: 32
16th Jan 2018 17:38
mdlbt.com/37446
The red wire from this
Kevin
Spitfire99
Forum Posts: 32
16th Jan 2018 17:49
mdlbt.com/37448
Sorry that was thanks Colin
Kevin
16th Jan 2018 18:12
mdlbt.com/37452
Hi Spitfire
This is one of your brushless ESC's. As you have indicated the wire is the red one with a brown wire and yellow wire either side and the black bit is the plug. If you turn it over you will see the tab that I suggested lifting to remove the red wire and tape to the brown and yellow wires.
The BEC is contained within the ESC and if you do not disconnect one you will encounter all kinds of trouble.
Keep asking the questions we have all been there and mistakes can be costly.
Spitfire99
Forum Posts: 32
16th Jan 2018 18:26
mdlbt.com/37455
Thanks Dave yes that’s what I was thinking. How much is this going to cost me if I get this wrong. New motors new ESC. Thanks for your help. Being as you have saved me, the cost is time and yours and others so I’m going to make a donation to the web site for up keep. That the lest I can do.
Kevin
Spitfire99
Forum Posts: 32
16th Jan 2018 18:31
mdlbt.com/37458
Can you help with this Dave on the ESC I have three wire to context to the motor
Red Blue and Black. On the motor the wires are Orange Yellow and Blue.
What goes where
Kevin
16th Jan 2018 18:42
mdlbt.com/37461
Hi Spitfire, this is the easy bit 😉 it doesn't matter!! 👍
If you then find the motor runs backwards when you shove the stick forward then just swap over any two wires.
Spitfire99
Forum Posts: 32
16th Jan 2018 19:26
mdlbt.com/37462
Now that was easy. Can’t believe it
Thanks Doug 🙂
Kevin
Forum Posts: 437
16th Jan 2018 19:34
mdlbt.com/37463
Hi Doug, that's just like a 3 phase motor. Is it always like that for brushless motors.
16th Jan 2018 20:42
mdlbt.com/37465
Yes Colin, in essence that's all a brushless motor is!
PS: How's KGV getting on?
I'm still into Sea Scout and PT boat renovations / conversions.
But I know what my next 'new build' is! See pics, 'undreds of bits an' pieces 🤔😉
Forum Posts: 556
16th Jan 2018 21:48
mdlbt.com/37469
HI Spitfire, As Dave M said, the only silly question is the one you didn't ask, usually an expensive answer!!!!!!!
17th Jan 2018 10:09
mdlbt.com/37486
Hi Spitfire
Glad to hear that you will be supporting the site's running costs. Stephen (Fireboat) runs this free site entirely on donations so every little bit helps.
Doug has answered your question re wiring the brushless motor to the ESC.
I would just add that you should not swop any wires whilst the battery is connected.
I would also advise that you fit a fuse between the main battery and the ESCs. Brushless motors can draw very heavy currents when stalled or overloaded. A fuse rated just above your running current and no more than 50% of your ESC rating. I am assuming here that your wiring is capable of carrying this current?
If you haven't got one I suggest you purchase a wattmeter so you can measure the current drawn under load (hold the boat in water and run at full wack). This must not be greater than the Motor or ESC rating. A smaller prop will reduce the current.
Please keep us posted
Spitfire99
Forum Posts: 32
17th Jan 2018 15:21
mdlbt.com/37491
Donation all done. And thank you all for your help. So glad I found this site 👍
Kevin
