261
11
ยฃ10
ยฃ15
ยฃ50
ยฃ5
ยฃ10
ยฃ15
ยฃ20
    Page 1 of 116
    Hints and Tips.
    I like your tip, it reminded me of the way I have used cycle spokes as drive shafts, the spoke nuts are usually plated brass so can be used in brass props by drilling out then silver solder the nut into the prop after removing the plating. Cheers Colin.
    3 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง Colin H ( Lieutenant Commander)
    3 hours ago
    by Colin H
    Prop size and speed
    6 hours ago by ๐Ÿ‡บ๐Ÿ‡ธ samc ( Leading Seaman)
    by StuartE
    6 hours ago
    by samc
    Help identify
    Hi Doug, I have just had another look at the 2642 and I think you have hit it on the head. It is the closest to my boat. Thank you so much for your help. I think you have solved the mystery. Regards Sid
    10 hours ago by ๐Ÿ‡ฆ๐Ÿ‡บ sidley70 ( Master Seaman)
    3 months ago
    by sidley70
    10 hours ago
    by sidley70
    Coming soon.
    You are going to a SteamPunk festival dressed as a tugboat !?
    12 hours ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    12 hours ago
    22 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง pmdevlin ( Sub-Lieutenant)
    22 hours ago
    Cheap easy anchors
    2 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง DodgyGeezer ( Warrant Officer)
    Air Sea Rescue Launch 123
    2 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    by Will-I-Am
    Eastleigh ... visits
    2 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Tall Paul ( Petty Officer 2nd Class)
    Jun
    19
    2019
    Jun
    23
    2019
    by Tall Paul
    Pond Weed
    by Tall Paul
    water is wet and so was I.
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Brianaro ( Petty Officer 2nd Class)
    by Colin H
    Aerokits Plans
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง donrecardo ( Able Seaman)
    by donrecardo
    by donrecardo
    4 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Warrant Officer)
    Can anyone help please?
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง andyhynes ( Leading Seaman)
    by andyhynes
    5 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    by Elsrickle
    Reversing Field-Wound motors
    Battery backup
    5 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Sub-Lieutenant)
    6 days ago by ๐Ÿ‡บ๐Ÿ‡ธ tgilchristjr ( Able Seaman)
    by tgilchristjr
    AERKITS SOLENT LIFEBOAT
    6 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง stuartbell3553 ( Recruit)
    by stuartbell3553
    by stuartbell3553
    Waveney class lifeboat
    6 days ago by ๐Ÿ‡ฟ๐Ÿ‡ฆ redpmg ( Petty Officer 1st Class)
    by Jerry1
    HAZELGARTH
    Help and advice please
    by Gren-York
    Another boat leaves the yard
    by GrahamP74
    SS Torrey Canyon
    9 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Airtrooper ( Recruit)
    by Airtrooper
    Have I been Demoted
    9 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง MouldBuilder ( Warrant Officer)
    by Scratchbuilder
    Vosper mtb 379
    9 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Boats ( Recruit)
    by Boats
    by Boats
    11 days ago by ๐Ÿ‡จ๐Ÿ‡ฆ Donnieboy ( Warrant Officer)
    21 days ago
    by Donnieboy
    12 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Fred ( Chief Petty Officer 2nd Class)
    by andyhynes
    by Fred
    13 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    13 days ago by ๐Ÿ‡จ๐Ÿ‡ฆ Ron ( Midshipman)
    by andyhynes
    Site glitches!
    14 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง mturpin013 ( Sub-Lieutenant)
    2 months ago
    by mturpin013
    Page 1 of 116
