August 2018: 3 people
December 2017: 4 people
Active Users (14)
>> Home > Forum > Electrical Related > LED Tug Mast Navigation Lights
(6304 views)
pittsfieldpete
Forum Posts: 69
28th May 2018 13:32
mdlbt.com/42219
Hi, everyone:
I have a Hobby Engine Richardson Tugboat that I’m about 98% happy with just as it came out of the box. The 2% that I’d like to add would be to rebuild the main mast & replace the “dummy” mast-mounted navigation lights with LEDs. The mast has a partially open back with molded-on ladder rungs. I plan to use the open area for wiring, then add a back cover & bent wire rungs. The boat has working red & green sidelights, working rear deck area floodlights, a working searchlight on the pilot house roof & working pilot house interior lighting. Each of the “white” lights have individual on & off function switches on the transmitter, which is excellent. But for some odd reason the red & green sidelights are turned on & off separately. Ideally, what I would like to do is combine the sidelights so they switch on & off together with one transmitter switch & use the now “spare” transmitter switch to turn the new mast-mounted “white” lights on & off. I realize my plan may not be possible but I really would like my idea to work. Note that the tug has a short mast attached to the aft pilot house railing. This mast has two dummy navigation lights & the main mast has three. I plan to remove the short mast & add two aft-facing lights to the main mast. I’ll need help with wiring power correctly for the five new LEDs. I’d like to tap into the boat’s 7.2 volt battery power, but it might be best to add a separate battery box. I’d really appreciate ideas. Can anyone offer advice about my project? Is it feasible to do or should I leave well enough alone? Thanks.
“There is nothing...absolutely nothing...half so much worth doing as simply messing about in boats”.
Kenneth Grahame, Author
1859 - 1932
Forum Posts: 210
28th May 2018 20:58
mdlbt.com/42243
Although I've never had any dealings with these type of boats , I'm pretty sure that they are built in such a way that they aren't easily modified without ripping out everything and starting again.
As the electrics are built into the circuit board it's not easy to identify each circuit function without having a electronic wizz kid at your side.
I think the easiest option would be to put in a separate switch,battery ect.
Forum Posts: 2047
28th May 2018 21:57
mdlbt.com/42248
Evenin' Pete, basically Ron's right, but there may be a way, 😉if you have a simple multimeter! I'll get back to you tomorrow when I've thought it through.
Cheers,Doug 😎
BTW; I'm a retired electronics engineer 👍
pittsfieldpete
Forum Posts: 69
29th May 2018 21:44
mdlbt.com/42269
1859 - 1932
pittsfieldpete
Forum Posts: 69
29th May 2018 21:50
mdlbt.com/42270
1859 - 1932
Forum Posts: 2047
29th May 2018 23:33
mdlbt.com/42275
Hi Pete, Good to hear you've got a multimeter👍 and also that the board has unique plugs and sockets. I only have the earlier version of this Tug (the Southampton) with 40MHz RC and no lights or frills 😭
Would help enormously if the bottom cover can be removed so you can see which leads connect to the 'side' lights - the red and green navigation lights.
I am assuming that the existing lights have LEDs and not bulbs? Please correct me if I'm wrong. It makes a difference. And you want to add 5 new white LEDs on one circuit powered from one of the existing switch channels.
OK. been a hard day today and now 00:30 here so I'll finish this and send you the gen tomorrow. Will probably take longer to describe than to do.😉
deepdiver
Forum Posts: 54
30th May 2018 09:07
mdlbt.com/42279
Have a look at this
http://led.linear1.org/1led.wiz It may be of some help
Fred
Forum Posts: 2047
30th May 2018 10:47
mdlbt.com/42281
Good stuff Fred, 👍
I have something similar that I will use to help Pete,
When we know where to connect up!
More later, cheers Doug 😎
pittsfieldpete
Forum Posts: 69
30th May 2018 14:42
mdlbt.com/42284
1859 - 1932
Forum Posts: 2047
30th May 2018 15:26
mdlbt.com/42285
Hi Pete, Okaaay!
That complicates the issue a little. 'I think I better think it out again'!
Now we have to decide which lights you want to switch together as some would not normally be on simultaneously; e.g. Anchor and running lights.
Do you perchance have a layout drawing of the circuit board and the plugs and sockets? 'snipped' out of the instruction book perhaps.
Or a good focussed photo might do.
As I understand it you currently have the following switchable functions, correct?
1. red running light,
2. green running light, to be combined with the red,
3. white deck lights, How many individual LEDs?
4. white searchlight,
5. white interior lights, How many individual LEDs?
Need to know the numbers of LEDs in 3 and 5 to estimate the current the switching circuits can handle!!!
Maybe we could combine some others as well, e.g.
deck lights and towing light or anchor light?
Stern light with the red and green?
Deck lights with the interior lights?
Interior lights with the running lights?
Forum Posts: 2047
31st May 2018 15:12
mdlbt.com/42309
Hi Pete, Some basics.
If you want to run 5 LEDs from 7.2V this is the circuit you need. See pdf.
Click the file icon and then 'Download' in the top left of the disply to view and download the file as pdf.
If you want to drive 6 LEDs you insert the 6th in the third branch and change the resistor to 62 Ohm, like the first two branches.
Current drawn remains 60mA, power consumption drops a few mW.
Any dropping resistor fitted on the circuit board must be shorted out or replaced with a tinned copper wire link, if possible. More on that later.
Instructions for wiring up, and finding out where!, follow this evening.
cheers Doug 😎
BTW: does this look like the circuit board you have? (Last two pics.)
Same part # JH-003R ?
pittsfieldpete
Forum Posts: 69
5th Jun 2018 11:26
mdlbt.com/42430
Hi, Doug:
You’ve been a busy man! I certainly appreciate your efforts & assistance. I haven’t removed the tug’s deck or the bottom cover of its pilot house to look at the circuit boards as yet but I’ll do it later on this morning.
TABLE ONE - EXISTING CONFIGURATION
Switch L2 - Controls (1) clear LED pilot house roof searchlight.
Switch L3 - Controls (1) red LED port sidelight.
Switch L4 - Controls (2) clear LED aft deck lights.
Switch R2 - Controls (1) clear pilot house interior light*.
Switch R3 - Controls (1) green LED starboard sidelight.
Switch R4 - Controls the horn.
TABLE TWO - MODIFIED CONFIGURATION
Switch L2 - [No change]
Switch L3 - Controls (1) red LED port sidelight, (1) green LED
starboard sidelight, (1) aft-facing clear LED anchor
light & (1) aft-facing clear LED navigation light.
Switch L4 - [No change]
Switch R2 - [No change]
Switch R3 - Controls (1) yellow LED mast top light & (3) forward-
facing clear LED navigation lights.
Switch R4 - [No change]
The modifications above result in having (4) LEDs controlled by
Switch L3 & (4) LEDs controlled by Switch R3. If these changes are possible then adding the (6) new LEDs should be relatively easy, plus all lighting & the horn are still powered by the tug’s 7.2 volt battery. I plan to upgrade the battery to a much higher mAh rating to help offset the extra drain from the additional LEDs.
Thanks again for your help.
Pete
1859 - 1932
Forum Posts: 2047
5th Jun 2018 11:58
mdlbt.com/42431
Hi Pete, sorry no attachment found!🤔
Or did you just type copy from the booklet?
Is there a pic of the circuit board and wiring in the booklet?
Maybe the board is marked with L2 etc to identify the outputs!
That would be too easy though 😉
The bulb: can you see it from outside?
A white LED should be 'see through' or milky and look like the attached pic. Ciao, Doug 😎
pittsfieldpete
Forum Posts: 69
5th Jun 2018 13:55
mdlbt.com/42433
Sorry about that, Doug. My not-so-nimble fingers hit the “Post “ button before I finished everything. I think everything is posted now.
1859 - 1932
pittsfieldpete
Forum Posts: 69
5th Jun 2018 13:57
mdlbt.com/42434
I’d rather have a bottle in front of me than a frontal lobotomy.
1859 - 1932
Forum Posts: 2047
5th Jun 2018 14:15
mdlbt.com/42436
OK: just off out to restock the 'bottles in front of me' 😉
More later. No pic of the circuit board in the booklet??
Maybe you can photograph it, both sides if possible.
Would help to us to discover the dropping resistors in each output circuit.
Where they are and what values.
Cheers Doug
pittsfieldpete
Forum Posts: 69
5th Jun 2018 15:18
mdlbt.com/42437
1859 - 1932
Forum Posts: 2047
5th Jun 2018 20:41
mdlbt.com/42443
OK Pete, I've started trying to write down some instructions as to how we might find the correct wires and modify them. More soon, ciao Doug 😎
pittsfieldpete
Forum Posts: 69
5th Jun 2018 21:32
mdlbt.com/42446
1859 - 1932
pittsfieldpete
Forum Posts: 69
5th Jun 2018 21:43
mdlbt.com/42447
There is only one ceiling light in the pilot house.
1859 - 1932
Forum Posts: 2047
5th Jun 2018 22:05
mdlbt.com/42448
Weird😲
Can you get at it to change it for an LED??
pittsfieldpete
Forum Posts: 69
6th Jun 2018 01:31
mdlbt.com/42452
1859 - 1932
Forum Posts: 433
6th Jun 2018 03:13
mdlbt.com/42453
Hi Pete,
I have the Southampton too. which came with no lights!
I got it about 6 years ago.
Anyway I carefully took the top off the pilot house using a single edge razor! You could give that a try! I also painted mine to resemble the WYEFORCE!
Good luck, Oh I also painted the inside of the pilot house as well!
pittsfieldpete
Forum Posts: 69
6th Jun 2018 05:53
mdlbt.com/42456
It looks great! It really stands out from the crowd...er, fleet of similar tugs. How long did it take for you to remove the pilot house roof? Thanks.
1859 - 1932
Forum Posts: 433
7th Jun 2018 02:48
mdlbt.com/42478
Hi Pete,
When I worked on mine. I believe it took me about an hour or so!
Just be careful with the seams! take your time.
Start from the rear of the Pilot house!
I first took apart the pilot house.
I took the smoke stacks off!
Then slowly pride the rear of the pilot house!
NOTE: on mine they had only glued the glue points!
If you look carefully, You can see them.
They're located at each corner!
Maybe you can also use a wide xacto.
That's what I used back then.....
Good Luck!
pittsfieldpete
Forum Posts: 69
7th Jun 2018 05:32
mdlbt.com/42479
Thanks, Ed. Now I have some helpful advice I can use to get the roof off. Excellent!
Pete
1859 - 1932
Forum Posts: 2047
7th Jun 2018 06:09
mdlbt.com/42480
HI Guys, took me about 10 seconds to get the roof, which was grey not white, off my old 40MHz Southampton 😊
It wasn't glued on at all 😲 Just ran round the seam with my thumbnail and it popped off 😁 All the rest was screwed together. Only some of the detailing 'stuff' was glued. Some was just 'plugged in'.
More later Pete, cheers Doug 😎
pittsfieldpete
Forum Posts: 69
7th Jun 2018 13:06
mdlbt.com/42486
Pete
1859 - 1932
Forum Posts: 2047
7th Jun 2018 13:22
mdlbt.com/42487
Afternoon Pete, Not awesome 😉 just 'Been there - Done that'!
Albeit on older versions.
So; now we're getting somewhere. Good idea with the connector 👍
I plan to do that with mine as well. I took it apart to investigate adding smoke, lights and sound. And possibly a twin ESC rudder mixer.
Project got shelved when I got deeply involved by a couple of renovation / conversion jobs. 🤔 You've inspired me to bump her up the 'To Do List' a ways 😉
Now we should be able to trace the wires back to the circuit board😊
Will send a Step by Step procedure tonight. Gotta go fix a rotten fence now 😡 Cheers Doug 😎
PS: I was also impressed with the quality and fit of the mouldings. Good tooling 👍
PPS: You may find this thread useful
https://model-boats.com/builds/view/34234?goto=34235
Neil has also been down a similar road. 'Jarvo' as well, who came up with some useful tips, esp re locations of hidden screws😉
Forum Posts: 326
8th Jun 2018 02:56
mdlbt.com/42521
Doug that pilot house light could be a fusible link. Has it got a white painted tip? If so it is fusible for sure. If not it is a" could be" fuse. Trouble is you can't test it LOL😁👍 You could;if you can find one,fit a resetting led fuse.🤓
John /O/T
pittsfieldpete
Forum Posts: 69
8th Jun 2018 03:29
mdlbt.com/42522
Pete
1859 - 1932
Forum Posts: 2047
8th Jun 2018 08:46
mdlbt.com/42523
See where you're coming from John. But what would be the point?
The bulb is only connected to one output of the RX board so has no influence on other circuits.
Pete; same applies to the 'resistor' idea. Plus; the bulb's DC resistance is around the square root of not very much!😲
I've found some pics of the internal wiring of the Richardson, samples attached, and am trying to figure out what we can do to maximise the flexibility of the existing function switches. Your pic of the cabin roof connections has given me an idea Pete 👍
More later, plus some LED basics for future reference.😉
Happy Tugging All, cheers Doug 😎
pittsfieldpete
Forum Posts: 69
8th Jun 2018 10:40
mdlbt.com/42524
Thanks again, Doug.
Full speed ahead!
1859 - 1932
Forum Posts: 2047
8th Jun 2018 12:00
mdlbt.com/42526
Hi Pete, Go easy with the prying!!
You're right. The spring loaded button is the way in. But it can be very stiff and underneath the hatch is a dense foam rubber gasket which makes the hatch catch (😆) difficult to release. Press the button firmly down while trying to ease the hatch forward with your blade.
In my basic version there ain't much underneath except the rudder servo.
But that's where I intend to put a decent battery.
Re electronic speed controller (AKA ESC); it MAY be on the cct board but I doubt it cos I don't see the FET power transistors for the outputs to the motors! Unless that's them in the bottom left corner in the second pic?
In mine it's a separate square block with the heat-sink tabs of the transistors clearly visible. Trace the wires back from the motors to find yours😉
Everything else, RX and switched outputs, is on the cct board.
Check out the blog with the link above and you will find all the secrets about removing the deck without busting anything👍
More later, ciao, Doug 😎
pittsfieldpete
Forum Posts: 69
8th Jun 2018 13:33
mdlbt.com/42527
Hey, Doug:
Thanks,
Pete
1859 - 1932
Forum Posts: 2047
8th Jun 2018 14:05
mdlbt.com/42528
Great👍 Those are the FETs😊 actually 4 of 'em as I would expect.
Do me a big favour😉 Now take a full-frame close up of the whole board showing all connecting wires and the legends on the sockets please.
I've just chopped half the stern off my 'disaster area' Fish Cutter!
Oh woe is me 🤔
Forum Posts: 2047
8th Jun 2018 14:27
mdlbt.com/42529
OK Got 'em!
N channel MOSFETS good for 180V, 4A DC and 16A Pulsed (as with our speed controllers) so more than enough for our 'little toys' 😊
pittsfieldpete
Forum Posts: 69
8th Jun 2018 15:29
mdlbt.com/42530
1859 - 1932
pittsfieldpete
Forum Posts: 69
8th Jun 2018 15:39
mdlbt.com/42531
1859 - 1932
Forum Posts: 2047
8th Jun 2018 15:41
mdlbt.com/42532
Muchas gracias Pete, important is that as many legends on the board as possible are readable. 😎
Forum Posts: 2047
8th Jun 2018 15:45
mdlbt.com/42533
Can't sir down for a month or two either 😡😱😁
New Build Blog will soon reveal all (Or as much as I want to😉)
Little progress expected this evening; dinner with the GF and Germany plays Saudi Arabia 😁 in a Test Game. If they flunk that then they can save the air tickets to Moscow😉
Forum Posts: 433
8th Jun 2018 16:54
mdlbt.com/42535
Hi Pete,
I agree with Doug. Push and lift at the same time!
At least that's how mine worked out! I found a piece of foam in the bilge of my southhampton. didn't see the point of it. so I took it out! Now underneath the first hatch. I found the reciever.
Believe it or not it was a 27mhz reciever! Which I quickly switched out for a 2.4ghz reciever.
But maybe the Richardson Tug is completely different electronics wise....!
pittsfieldpete
Forum Posts: 69
8th Jun 2018 19:10
mdlbt.com/42536
1859 - 1932
Forum Posts: 433
8th Jun 2018 19:36
mdlbt.com/42537
Hi Pete,
Glad you have learned! I too have learned as well.
My Southampton didn't come with lights.
So, your Richardson tug.
must look awesome on the water at night.
Oh, 2.4ghz is way better than 27mhz.
This is why, I changed the reciever to my Southhampton!
And the long aerial just doesn't look right!
Forum Posts: 2047
8th Jun 2018 21:47
mdlbt.com/42538
Evenin' Both,
Pete, you're right about the hatch, in the instructions (or mine at least with the old 40MHz version) they warn you to leave the hatch loose when not using the boat. Otherwise it sticks to the foam gasket. Just like yours did 😉 During the upgrade of my 40MHz Southampton I will remove that over-engineered catch and use neodymium magnets in the corners instead. That gives more 'headroom' to fit a decent sized NiMh battery underneath 😊
And yes there are 3 different versions of this boat, whereby Richardson and Southampton are identical apart from name and 'paint job'. 27 and 40 MHz with no frills and the modern 2.4GHz version with bells and whistles. Well, lights and smoke anyway 😊 Makes a change from Smoke and Mirrors eh? 😁 So between the 3 of us we represent all 3 generations!!!
Re different RC frequencies, as a ex Radio and naval COMMS engineer:
27MHz and 40MHz have inherently longer range and better water penetration, which is why I still have such sets for my submarines.
2.4GHz is strictly Line of Sight only, which is one reason why they first gained popularity with the 'Fly Boys'. 2.4Gig waves also bounce off water or are absorbed by it, so it's useless for subs😭
The other reason is that they use a frequency hopping (FH) technique which makes them virtually immune to interference 😊 Although I have yet to find a set that hops over the full 85 frequencies available. Most seem to only use 16 or so🤔 Limited bandwidth at the RX !?
As with all FH radio systems 2.4Gig RC sets also use a binding technique so that the RX recognises the 'signature', i.e- hop sequence, of it's own TX and ignores others. Mostly anyway 😉
Here endeth the 99th Epistle of Admiral Doug 😁
Main thing is, enjoy the 'fiddlin aboot' and even more so the sailing, as my German colleagues say; "I wish you always a hand's breadth of water under your keel". Cheers Doug 😎
Forum Posts: 326
8th Jun 2018 22:08
mdlbt.com/42539
Forum Posts: 2047
8th Jun 2018 22:20
mdlbt.com/42540
Tell me about it John😲😉
I got fed up with hunting for the dud bulbs in the chains year after year. So threw 'em all out a few years ago and replaced with LED chains and icicles and snow showers and .....
Anyone need a batch of spare Chrimbo tree blubs!?😁
pittsfieldpete
Forum Posts: 69
9th Jun 2018 00:02
mdlbt.com/42546
Hey, Doug:
Board-01: Overall view of the board, “North” is at the top.
Board-02: “Northeast” corner.
Board-03: “East” edge. All of the labels are letters.
Board-04: “Southeast” corner.
Thanks.
1859 - 1932
Forum Posts: 2047
9th Jun 2018 00:16
mdlbt.com/42547
Thanks Pete👍 The row of 220 Ohm SMD resistors give a very good clue!
My 67 year old eyes let my Sony Cybershot take the strain 😉
Get back to you soon. It's sack time here in Munich now. "ZZZZZZZZZZZZ"
CU. Ciao, Doug 😎
pittsfieldpete
Forum Posts: 69
10th Jun 2018 15:46
mdlbt.com/42582
Hi, Doug:
Pete
1859 - 1932
Forum Posts: 433
10th Jun 2018 16:45
mdlbt.com/42586
Hi Pete,
Not sure why the name plate says Southampton.
I've never seen the Atlantic before!
The controller that you see is the 27mhz unit
I know I have one in my spare parts bin!
Forum Posts: 2047
10th Jun 2018 21:23
mdlbt.com/42592
Hi Both, All the mouldings look identical to the Southampton and Richardson. The hull and stand are the same as my 'Southampton', the superstructure the same as the Richardson?, but with a red roof😆?
Maybe they ran out of grey and white plastic 😁
pittsfieldpete
Forum Posts: 69
11th Jun 2018 04:51
mdlbt.com/42602
Hey, Guys:
1859 - 1932
Forum Posts: 433
11th Jun 2018 19:43
mdlbt.com/42618
That's about right take a look at the real Wyeforce!
Guess 22" is where they thought the model should be at!
https://www.marinetraffic.com/en/ais/details/ships/235000813
pittsfieldpete
Forum Posts: 69
12th Jun 2018 11:49
mdlbt.com/42624
Enough said.
1859 - 1932
pittsfieldpete
Forum Posts: 69
20th Jun 2018 12:20
mdlbt.com/42919
Hi, Doug:
1859 - 1932
Forum Posts: 2047
20th Jun 2018 22:52
mdlbt.com/42941
I ain't laughing Pete, it's a fair question (or two) 😉
1 Location: you're on the right track👍 A little distribution board, e.g. built on Veroboard, is a good tidy solution and simplifies any troubleshooting later. Put the resistors in the + lead to the LEDs.
2 Resistor size and heat: 1/8 or 1/4 W resistors will do nicely. Since they will only be passing 20 to 30mA they should not get hot. The size is about 3mmx 10mm. Allow 3 or 4mm at each end for the leads for flat mounting.
3 Values: Before we can determine these we will need to know what voltage is supplied to the dropping resistors on the circuit board just before the plug and socket connection to the lamp wire.
So you will have to do some testing with your multi-meter😲
before you pull anything apart make a sketch of the lamps connections to the board. Switch on your TX and RX - IN THAT ORDER PLEASE!
Switch on each existing light in turn and measure the volts at the socket on the board, referred to the negative of the main battery supply.
Then look for one of those teeny SMD resistors directly connected to the socket pin you've just measured and check the volts at both ends while the lamp is on. Note all these readings on your sketch.
Make a clear photo of this sketch and post it or PM me for my email address. doug-bell@t-online.de that might get deleted by the site system🤔 When we have these readings I can work out some suitable combinations to achieve what you want and minimise the number of different resistors. Basically I need to know if the full 7.2V of the main battery is switched to the resistor by the RX output! If not then what!?
Hope this makes sense 😉 Takes longer to describe than to do it !
Re sourcing: Try Radio Shack. I recently pointed another site colleague (figtree) in this direction for a similar project with his Brooklyn tug.
For instance-
https://www.radioshack.com/collections/resistors/products/50...
This is a collection of so called preferred values, i.e. near enough standard values and cheap to produce by the millions.
For $7.50 it's got all the values you are likely to need for the next 10 years illuminated boating 😁
Cheers, Doug 😎🤓
pittsfieldpete
Forum Posts: 69
21st Jun 2018 00:28
mdlbt.com/42943
Thanks, Doug.
1859 - 1932
Forum Posts: 2047
21st Jun 2018 00:48
mdlbt.com/42944
Mornin' Pete (at least it is here!)
Yes, switch on only one light at a time to avoid any confusion with the readings. Easier to find the 'live one' then.
Socket means the connectors on the circuit board where you told me plugs from the superstructure wiring are connected , and as I saw in your photos.
First job is to trace all wires back from the existing lights and note them on your sketch. If any are directly soldered into the board the procedure is just the same as if it were a socket pin.
I'm particularly curious about the voltage to the bulb, and why it's a bulb in the first place.
Carefully check all other lights, if they are also bulbs we have a slightly different ball game. Still need the voltages though 😉
I guess we are all collectively responsible for the demise of local model shops and Radio Shacks and the like. We all want Rolls Royces and Cadillacs but are only prepared to pay Hyundai and Toyota prices, so we all (me too - Guilty as Charged🤔) buy online from HobbyKing and similar and the local shops starve. Simple economics. Model shop owners gotta eat too!
Sack time now in Munich, tomorrow (today😲) is another day, ciao, Doug 😎🤓
pittsfieldpete
Forum Posts: 69
21st Jun 2018 04:28
mdlbt.com/42945
Hi, Doug:
1859 - 1932
Forum Posts: 2047
21st Jun 2018 07:24
mdlbt.com/42947
Sorry, my mistook🤔
Look forward to the sketch, cheers Doug 😎
pittsfieldpete
Forum Posts: 69
23rd Jun 2018 17:00
mdlbt.com/43020
Hello, Doug:
1859 - 1932
Forum Posts: 2047
23rd Jun 2018 22:19
mdlbt.com/43026
Hi Pete,
Number 1, Get yourself some more batteries! You'll want a spare at the pond anyway 😉
Better still, get a variable mains power supply for such bench tests so you don't have to mess with batteries until you're on the pond!
Here in Munich I got a Basetech 30V 5A regulated PSU for less then the price of a decent boat kit. See 2nd pic, shows mine during my test of a converted field coil motor to make it run forwards and backwards.
it saves a lot of faffing about with batteries for a quick test of a circuit😉 Get one where you can set a current limit down to mAmps so you don't risk blowing components, e.g. LEDs!
Re Connectors: if you are going to make a little distribution board for the lights then why not use this for all connections to the superstructure?
I.e. first solder all the wires from the circuit board into the input end of your Veroboard.
At the output end solder a strip of 1/10" pitch connector pins. Try Radio Shack!
For each output to lamps, smoker etc you can then use the little 2 pin JST plugs. See pic. Type JST-RCY. Try Googling them.
Sure you can get these from any half decent Online RC supplies shop over there. They are often used in Park Flyer planes etc.
Doing it that way you only have half the wires to squash into the tiny plugs 😉
As soon as we have the voltage readings we can work out the connections and resistors etc for your little board.
Happy measuring😁 Looking forward to your sketch. Cheers, Doug 😎
pittsfieldpete
Forum Posts: 69
30th Jun 2018 23:37
mdlbt.com/43361
Hi, Doug:
1859 - 1932
pittsfieldpete
Forum Posts: 69
3rd Jul 2018 10:52
mdlbt.com/43401
Hey Doug!
Thanks again,
Pete
1859 - 1932
Forum Posts: 2047
3rd Jul 2018 11:26
mdlbt.com/43402
Hi Pete, many thanks, good work 👍
Just one question; What was the battery voltage?
GF about to drag me out to the Shopping Mall 🤔 so more this evening.
pittsfieldpete
Forum Posts: 69
3rd Jul 2018 13:38
mdlbt.com/43405
Hi, Doug:
Sorry about that. Where power enters the circuit board the reading is 8.08 volts, same as the 7.2V battery pack when it’s fully charged.
That sounds like something from an Abbott & Costello routine!
1859 - 1932
Forum Posts: 2047
3rd Jul 2018 16:34
mdlbt.com/43408
"Who's on first base?"
"Yes."
"What"?
"No, What's on second."
"Who?"
"No, What. Who's on first."
BTW: thanks for the input voltage 👍
Is that the same value where you have marked '+' on the sketch?
c
pittsfieldpete
Forum Posts: 69
3rd Jul 2018 17:05
mdlbt.com/43410
Doug:
Yes, sir. I should’ve written “8.08V” next to the “+” but I missed it.
Pete
1859 - 1932
Forum Posts: 2047
3rd Jul 2018 17:13
mdlbt.com/43412
OK. Good, that's all I need to know 👍
Now to put new batteries in me calculator 😁
BTW: I know soccer isn't exactly THE game over there, BUT
England are playing in the World Cup tonight, wish 'em luck - they might need it 😉 Ciao, Doug 😎
pittsfieldpete
Forum Posts: 69
20th Jul 2018 09:52
mdlbt.com/43957
Hello, Doug:
Are you doing OK? I sincerely hope so. 🙏🏼
Three questions have come up as a result of my searches on MB for information about & photos of Hobby Engine’s various tugs.
First, when you have the time, will you please look at the wires that run from the circuit board up to the pilot house LEDs & ceiling light & let me know what gauge you think they are? I’ll need to get wire of the same gauge for my LED mast lighht connections, (assuming it can be done at all).
Second, I would like to get a new 7.2V battery with a much higher amp-hour rating. Can I simply get a higher capacity battery & charger to do this as long as I stay with 7.2v?
Last, the factory motors in the HE tugs seem to be quite robust & powerful. Why does it seem like most boaters can’t wait to replace them?
Thanks,
Pete
1859 - 1932
deepdiver
Forum Posts: 54
20th Jul 2018 14:09
mdlbt.com/43961
Hi Pittsfieldpete
I use 30awg wrapping wire for my LED's the RS stock number is 209-4849 Black they also do it in red.
Hope that this is of some help.
Fred
pittsfieldpete
Forum Posts: 69
20th Jul 2018 18:02
mdlbt.com/43964
Hello, Fred:
Thank you very much for your information about wrapping wire. That kind of wire will be easy to conceal inside the Richardson’s mast en route to each of the six mast-mounted LED navigation lights I hope to use. Excellent!
Thanks again!
Pete
1859 - 1932
Forum Posts: 433
20th Jul 2018 18:49
mdlbt.com/43967
Hi Pittsfieldpete,
I ordered these LED's. It's quite a large assortment!
They arrived about two weeks later!
I think they will help you with your Robertson Tug!
https://us.banggood.com/Wholesale-Warehouse-375pcs-3MM-5MM-L...
Also you'll have LED's for any project!
Cheers' Ed
Forum Posts: 484
20th Jul 2018 19:12
mdlbt.com/43968
before you use RS to buy your wrapping wire you might like to look here
https://www.ebay.co.uk/itm/0-25mm-30AWG-Insulated-Silver-Pla...
I didn't realise anyone was still making wire wrapping supplies.
deepdiver
Forum Posts: 54
20th Jul 2018 20:25
mdlbt.com/43969
I got 50mts from when I was at work and so far I still have some 45+ left.
In the past I have used telephone/alarm wire and that has worked well.
Fred
Forum Posts: 433
20th Jul 2018 20:49
mdlbt.com/43972
Hi Pittsfieldpete,
I use really tiny wire for wiring running lights!
Bought it as radio shack years ago!
Wire wrapping wire is the best to use.
Especially when you can't hide the wire!
Paint black or what ever color your using.
Best thing from a distance you can't tell!👍
Cheers, Ed
Forum Posts: 2047
20th Jul 2018 22:03
mdlbt.com/43974
Hi Pete,
since you are in the US try here, the OTHER RS😉:-
https://www.radioshack.com/pages/search-results?findify_limi...
Personally I prefer stranded wire as it is more flexible and less prone to break if you often have to remove and remake connections, like when you take the cabin off! It's slightly thicker so it's more a question of 'Will it fit?'
https://www.radioshack.com/products/22-gauge-hookup-wire-3-p...
Some model shops have (or used to!) a really thin stranded wire, as used for tiny 'rice grain' bulbs'.
2nd question:
I assume your tug has an 800mAh NiMh battery like mine did. Correct me if I'm wrong, I don't know the new models.
I propose to change mine for a 2200mAh NiMh. Can't use LiPo cos the Brushed ESC isn't LiPo safe; i.e. with built in cut off if the battery falls to 3.0V per cell - lowest safe LiPo discharge voltage.
3rd Question - changing motors; I've often wondered that!😲
Up to now I don't see any reason to. Maybe those guys want to enter Towing Competitions!? I don't.
Also some folks are just not happy unless they are tinkering and 'improving' 😉
I might try to quieten the gearbox down a bit though 🤔 Teflon grease perhaps!?
Forum Posts: 326
21st Jul 2018 13:07
mdlbt.com/43987
I wait with bated breath so come on Doug or I'll suffocate 😁😁👍
Forum Posts: 2047
21st Jul 2018 14:00
mdlbt.com/43988
OK John, just warn me when you start turning blue 😁
Got a bit bogged down with other snags!
At least we managed to clear up Martin's little mystery 😉
More velly soon (must be using too much Chinese stuff😊)
pittsfieldpete
Forum Posts: 69
21st Jul 2018 20:00
mdlbt.com/43997
Hi, Doug:
Thank you once again for answering my questions. I especially like your response & comments about HE tug’s factory-installed motors. I think the “heart of the machine” for my tug is perfectly fine. I’d rather add detail to the model, over time & within reason, to make the boat look as realistic as possible without becoming so delicate that I’d be afraid to put it in the car for a drive to the lake.
Continuing on, I’d like to get your comments about my latest idea for adding connectors to the wiring that runs from my tug’s circuit board to the various lights & components in the deck house & pilot house.
This is something I can do with or without my proposed new LED Mast Navigation Lights to add the convenience of being able to completely disconnect & separate the Deck House/Pilot House from the circuit board/Deck House bottom cover assembly. This will make detailing the upper works much easier because it won’t be tethered to the circuit board by (16) wires.
The circuit board holes where the (10) Search Light, Port & Starboard Sidelight & Aft Deck Light wires are soldered are equally spaced at 0.10” (2.5mm). I can tag & desolder the wires, insert a 10-pin HS male socket & solder it to the board. Then I can connect the wires to the male plug. I can do the same thing with the (6) wires that run to the Pilot House Light, Smoke Generator & Smoke Pump.
What do you think? If you find that powering & controlling the new LED Navigation Lights on the Mast the way I’d like to can’t be done, the circuit board connectors still make sense.
Or am I AWOL from reality...again?
Thanks,
Pete
1859 - 1932
Forum Posts: 2047
21st Jul 2018 22:46
mdlbt.com/44005
Evenin' Pete,
Not AWOL at all, haven't noticed that you were AWOL before either!)
The connectors are an excellent idea, as already briefly discussed.
Don't use the wrapping wire for the Smoker though. That wire is only good for about 500mA and the smoker probably takes more.
The lighting mods you want are possible, so hang on with the connectors until I've got the 'How' finished! Cos some of the lighting wires will be diverted through a new distribution board with the appropriate resistors, as we also discussed.
Will do my best to get the instructions finished tomorrow.
Cheers, Doug
pittsfieldpete
Forum Posts: 69
22nd Jul 2018 00:08
mdlbt.com/44011
Hi, Doug:
Wrapping wire is an option only if “normal” stranded/insulated wires won’t fit inside the mast. I don’t like to use single conductor wire for anything unless it’s for industry-standard applications like telephone wiring.
I asked if you had any idea what gauge the existing tug wiring is so that I can buy the same gauge for my project. I have to order things like small gauge wire, LEDs, resistors, etc. because there aren’t any shops where I can take in a sample of existing wire to compare with what’s on the shelf.
Oh, boy. As I’m typing this it suddenly just dawned on me that I can mike the existing wire O.D. to find the gauge...DUH!!
I’m looking forward to your instructions for my project but please don’t push your own interests aside for me.
Thanks,
Pete
1859 - 1932
Forum Posts: 2047
22nd Jul 2018 00:52
mdlbt.com/44014
Agree Pete,
But then telephone wires come as twisted pairs (to minimise induced interference) which gives them additional strength (and bulk🤔).
Your wiring looks to me to be about 24 gauge.
I also agree with space in the mast, had also pondered that while looking at my Southampton. Came to the conclusion that I would use the tiny wrapping wire (as U lot call it😉) down the mast and into a socket permanently glued under the cabin. Then use flexible stranded wire from then on down to the electronickery! Then there's no strain on the fragile wiring when you remove the cabin for maintenance etc.
That light 'wrapping' wire is fine for the LED circuits as they only take a few tens of milliamps. I'm also looking at the possibility to use a common return (negative) lead to minimise the wires needed on the mast itself.
I buy my wire Online as well, almost no shops left where you can go an look at stuff🤔 Was surprised and disappointed at the limited choice at Radio Shack, pretty miserable compared with the range I can get here from Conrad, and many others, even Krick Modellbau.
I'm multiplexing my projects with yours, and others who have approached me by PM. Trouble is I can never resist a challenge!
What I'm doing for your Richardson will also be the basis for some mods to my Southampton😉
Anyone know a good 'Cloning Shop'? 😁😁
Big 3D printer and an Isaac Asimov Positronic brain perhaps?
Cheers All, Doug 😎
pittsfieldpete
Forum Posts: 69
22nd Jul 2018 01:13
mdlbt.com/44016
Doug:
I was thinking along the same vein for the wiring in the mast; a common “buss” for the LED grounds. Sure would make the installation a bit easier. I like your socket idea a lot. I was considering a wiring conduit running up the space between the rear windows in the Pilot House & up into the mast, which would be glued to its mounting bracket on the roof. But it would be great to build the mast as a plug-in unit that could be removed for transit. You da man!
1859 - 1932
Forum Posts: 2047
22nd Jul 2018 01:16
mdlbt.com/44017
I think you just took my basic idea to the 'next level' Pete 👍👍
BTW: Like your 'Footnote', 'Three Men In A Boat' 😁😁
Forum Posts: 326
22nd Jul 2018 10:54
mdlbt.com/44026
You might find your wire here at the componentshop https://www.google.co.uk/search?q=componentshop&oq=component...
It's worth getting their catalogue. Brilliant service I can really recommend them. Good prices and quality with fast turnaround.
Forum Posts: 2047
22nd Jul 2018 22:17
mdlbt.com/44060
Evenin' Pete, first instalment coming shortly in pdf format.
A table, based on your excellent sketches of what you want to do, showing control element on the TX, function, number of LEDs in the cct or ccts, resistor(s) needed, current consumed, for various battery voltages.
Example attached as jpg pic.
Based on your measurements I am assuming that the searchlight is a 3V high brightness LED and all the others are 2V LEDs, and nominal current 20mA.
This means that with a nominal 7.2V supply (Vs) for some circuits with 3 or 4 LEDs two parallel ccts will be needed. All will shortly be revealed 😉
I have optimised the resistors so that
a) the LEDs don't fry when the batt is fully charged, 8V,
b) that the LEDs can still turn on when the batt voltage dips to the 7.2V nominal.
c) Only 2 or 3 values will be needed.
Now have to convert my Excel file to pdf.
Will follow this up with wiring suggestions, including the little Distribution Board with the resistors.
I've tried to combine the lights you want logically considering how they would be used on the real ship.
Stay tuned! Cheers, Doug 😎
BTW; the mods and resistors suggested in the table mean that the existing SMD resistors on the ccts board must be shorted / replaced with wire. Your wrapping wire (stripped of course!) will be ideal for this😉
Hope you have a small soldering bit!
Forum Posts: 2047
22nd Jul 2018 22:58
mdlbt.com/44062
Here the result for batt voltage (Vs) 7.2V, the 'nominal' voltage.
LEDs should still 'strike' but will be a little dimmer. Esp fore and aft Nav lights.
The resistors were chosen to (hopefully) prevent the LEDs from blowing at fully charged 7.7 - 8V.
The additional lights triple the current consumption, but at a max of around 300mA max it shouldn't affect your run time noticeably, esp. if, like me, you are going to beef up the battery to about 2Ah or more.
pittsfieldpete
Forum Posts: 69
23rd Jul 2018 12:55
mdlbt.com/44087
Thanks Doug. You’re amazing!
Somehow I’ve managed to pick up The Curse Of The Pink Eye. I can see OK this morning so I’m replying quickly before The Goo blinds me again. Over the weekend I went through a cycle of “blink, blink, blink...I can see again! I can SEE!!...blink...I’M BLIND!!...blink, blink..., repeat. A few minutes ago I looked in the bathroom mirror & saw a hideous monster with horrible red eyes & wild gray hair. I’m definitely NOT going in there again! It’s the powder room for me today. I don’t know what that thing is but they should put his face on medicine bottles & toxic household chemicals to frighten children.
Thanks for your hard work, Doug. I’ll look at your results as soon as the yellow woodworker’s glue in my eyes runs out. I hope pink eye can’t be spread through cyberspace. Wash your hands thoroughly after reading this just in case. Here it comes!
“There is nothing...absolutely nothing...half so much worth doing as simply messing about in boats”.
Kenneth Grahame, Author
1859 - 1932
Forum Posts: 2047
23rd Jul 2018 13:14
mdlbt.com/44088
Sounds like Albert Einstein's ghost!! 😲
Get well soon 👍
If you are happy with the arrangement in my table I'll knock up a wiring sketch for it.
All the best, Doug 😎
PS: I used the MacAffee 'washing machine' to scrub the electrons before displaying your message 😁😁
Forum Posts: 2047
24th Jul 2018 00:19
mdlbt.com/44103
Hi Pete, Hope the eyeballs are better 👍
Think I've now got the ultimate configuration 😊 (or the possible, tentative, subject to committee approval and board resolution, potential penultimate configuration 😲) See attached pdf. All new stuff is in red.
Thinking is as follows, according to the mast diagram you sent me-
L3; NAV & Towing in parallel 2 ccts; one for the port & stbd in the cabin roof, one for the white rear NAV & Towing, yellow, on the mast pointing aft.
L4; 2 white deck working lights plus new LED for the cabin light - white or yellow/amber. Your choice. I might be inclined to go for yellow as bridge lighting tends to be not too bright so it doesn't impair the night vision of the watch. Could be why it was a bulb in the first place - softer light ?
R2; Anchor light at mast top only. Makes no sense to combine with running (NAV) lights etc.
R3; The three new white running lights on the mast pointing forward.
L2 and R4 remain as they are for searchlight and horn.
Now working on the corresponding wiring sketch.
More tomorrow.
Forum Posts: 433
24th Jul 2018 00:47
mdlbt.com/44105
Hi Guy's,
R2 should be RED not WHITE!
Top most light on the Mast!
Anchor lights are RED and their arc of view is 360 degree's!
Forum Posts: 2047
24th Jul 2018 00:56
mdlbt.com/44106
Muchas gracias Ed 👍
Gen straight from the 'horse's mouth', so to speak 😉
How's your 'Brooklyn' lighting coming on?
Cheers, Doug
Forum Posts: 2047
24th Jul 2018 00:59
mdlbt.com/44107
Evenin' John O/T,
Can you breathe again now!? 😉
Hope I was in time!
pittsfieldpete
Forum Posts: 69
24th Jul 2018 01:14
mdlbt.com/44108
Hi:
Thanks for your input. I got my data for mast light colors from the US Coast Guard website. According to the USCG all of the lights on the mast except the Stern Light should be white. The Stern Light is should to be yellow. After I found that information I browsed the web for a mast navigation light layout. I found a shipbuilder’s site that had an excellent general arrangement drawing for a tug’s which matches the USCG requirements. An enlargement of the mast is attached. I think I posted the sketch in an earlier post but I’m not sure.
Thanks,
Pete
1859 - 1932
Forum Posts: 2047
24th Jul 2018 01:18
mdlbt.com/44109
That's the diagram I have been working to Pete,
Was also surprised to hear red for the anchor light, but Ed has worked on tugs!? Your boat, your choice!
Cheers and G'night All, Doug
Forum Posts: 433
24th Jul 2018 01:37
mdlbt.com/44110
I'm going to work on the Brooklyn's light's.
After I complete her! The wires are going to be in her main cabin.
So, will work on the lights last! Will be using two 9 volts for two separate lights!👍
Forum Posts: 433
24th Jul 2018 01:41
mdlbt.com/44111
I must be thinking of a larger size vessal!
Sorry about that, Got to take a look at the rules of the road (Ships)!
Forum Posts: 2047
24th Jul 2018 01:46
mdlbt.com/44112
Look forward to the light show Ed 👍
BTW Guys; looking again at the photos of the original Wyeforce boat (sample attached) I note that she does not have the silly UHF antenna stuck in the middle of the mast on the model.
So that can be removed to give easy access to the top light and 360° visibility of it 😉
Now I'm really off to Bedfordshire, nearly 3am and still talking boats ?😲
Ciao for now
Forum Posts: 433
24th Jul 2018 01:50
mdlbt.com/44113
I stand corrected Rule 30!
—INTERNATIONAL— Lights and Shapes
Rule 30 Anchored Vessels and Vessels Aground
(a) A vessel at anchor shall exhibit where it can best be seen: (i) in the fore part, an all-round white light or one ball; (ii) at or near the stern and at a lower level than the light prescribed in subparagraph (i), an all-round white light. (b) A vessel of less than 50 meters in length may exhibit an all-round white light where it can best be seen instead of the lights prescribed in paragraph (a) of this Rule. (c) A vessel at anchor may, and a vessel of 100 meters and more in length shall, also use the available working or equivalent lights to illuminate her decks
Forum Posts: 433
24th Jul 2018 01:51
mdlbt.com/44114
G'night Doug!
Forum Posts: 2047
24th Jul 2018 08:08
mdlbt.com/44115
Mornin' All, had wondered about that 3rd antenna on the model!
UHF on board is only used by the military.
The two longer (VHF) antennas are for the IMM band (International Maritime Mobile). Two are fitted according to the SOLAS/GMDSS regulations; one for transmission, one for reception.
SOLAS = Safety Of Life At Sea, introduced after the Titanic disaster
GMDSS = Global Maritime Distress and Safety System. Applicable to all ships of 500t or more and boats / ships capable of carrying 50 or more passengers.
These regs were part of my daily working life for 30 odd years.
They define the COMMS equipment a ship should carry according to the Sea Area they will sail in.
Area A1: close to shore within LoS range of VHF IMM radio. Roughly 30 miles, depending on height of antenna above sea level.
Area A2: off shore within the north and south 70° latitudes, beyond which SATCOM, esp INMARSAT is not possible due to the earth's curvature.
INMARSAT and/or MH/HF must be carried. Alternative means of long range communication must be carried.
A3: Worldwide. MF / HF radios must be on board for operations beyond the 70° parallels.
Cheers All, Doug
Forum Posts: 2047
24th Jul 2018 13:30
mdlbt.com/44119
Hi Pete,
Decided to change the 120Ohm resistors to 150s for safety at 8V fully charged! Keeps the total lighting current down to about 200mA 😉
New tables attached.
Last calc was with diode forward voltage drop (Vf) of 2.5V.
From your measurements the existing ones appear to be approx Vf 2.0V.
And I suggest you buy the same for your additional lights; Vf 2.0V, forward current (If) ~20mA.
pittsfieldpete
Forum Posts: 69
24th Jul 2018 13:38
mdlbt.com/44120
Thank you, O Great & Mighty Helpful One (AKA Doug).
My doctor prescribed eye drops for me yesterday afternoon so the torture should be over soon.
I looked at your spreadsheets & everything looks fine to me. 👍
By the way, I’ve been reading up on LEDs during our correspondence. One thing I learned that surprised me is that LEDs require different supply voltage depending on their color. Silly me thought that different colors were made by simply tinting a clear LED. But it’s confusing to me because the LEDs used for the port & starboard sidelights on my tug are actually are red & green in color, not clear, when they’re turned off. However, the aft deck lights are clear as water when off but yellow when turned on. According to various web articles I’ve read Hobby Engine was after the yellowish color of halogen lights, which they’ve done really well.
Why are some LEDs clear when turned off but change to a color when turned on, as opposed to LEDs that are their given whether off or on?
1859 - 1932
Forum Posts: 2047
24th Jul 2018 14:15
mdlbt.com/44123
Hi Pete,
Yep, the colour of the LEDs can be determined by doping the diode chip with various elements. The early ones were either red or clear, so the colour was added in the epoxy dome around the chip.
Cheap ones still are like that.
Nowadays you can get LEDs that light different colours according to the voltage applied! For instance in those irritating shelf / vitrine light strings that rotate through a variety of colours all the time.😡
I have some that are red or green depending on which way round you apply the voltage! They are milky white when off. Useful for checking the operation and setup in the boat of brushed ESCs and motors, esp for multi-screw boats, and the output of switching circuits.
Funny I always thought halogen lights were a hard white with a blue tint, like some car headlights. Cool on the Kelvin temp range.
Yellow is more like the warm white light of a tungsten bulb to me.
Yellow deck floodlights are more likely to be sodium lamps, like many street lamps.
The measurements you sent me indicated that the switch on voltage (Vf) of the searchlight was 3V and all the others 2V. So I based my final calc on that. If any of your LEDs don't 'strike' with 150Ohm just reduce the resistor to 120 to give it a 'shove'😁 I don't expect that though.
I have a box of 300 various LEDs and 1000 various resistors in front of me (and the mast from my Southampton tug😉) so will do some practical tests.
BTW: I can strongly recommend that you buy a simple LED Tester, like one of these-
https://www.ebay.com/bhp/led-tester
I'll help you get the LEDs the right way round in your circuits and tell you how much current they need for a decent brightness, and at what voltage they will turn on! Only a few bucks and saves a lot of aggro.
It'll also tell you what colour a 'clear or white' one will be when it turns on😊
pittsfieldpete
Forum Posts: 69
24th Jul 2018 14:56
mdlbt.com/44126
Doug:
You’re right about halogen lights. They’re mentioned as halogen in one article but as mercury vapor in a few others. Over here mercury vapor lamps are used for highway & parking lot lights & they do have a soft, yellowish glow. Halogen would be quite harsh & hard on drivers’ eyes. Maybe a tug or similar boats would prefer mercury vapor lighting in deck areas because they’re quite effective at cutting through fog? MVs are a good choice for highways & parking areas for the same reasons, I guess.
By the way, in your spreadsheet’s Notes column I noticed that you wrote “Clear” for the two deck light LEDs when in fact they’re yellow when operating. It shouldn’t make any difference to your calculations because you used the actual measured voltage in your calculations.
Here’s a question. Suppose you were given a box containing dozens of clear & different colored LEDs, both the cheap tinted epoxy kind & the ones that have clear domes with different innards to give various colors. How do you tell what voltage they require? From what I’ve seen LEDs aren’t marked in any way with a tiny numbers or letters so how do you know their power requirements if they’re not in their original packaging? Are LED supply voltage requirements standardized?
Thanks,
The Eternal Questioner (AKA Pete)
1859 - 1932
Forum Posts: 2047
24th Jul 2018 15:11
mdlbt.com/44127
Hi Pete, that's one reason I recommended you get an LED Tester!!
I would assume 2V and 20mA and work up from there if the LED doesn't turn on with 2V. But 'Gently Bentley', go too high too quick and you'll pop it! A good average is 2.5V. Maximum for some colours or high brightness types might be about 3.3V.
Yep, I'd forgotten about mercury vapour, thought they'd all been phased out in favour of sodium. Nasty stuff Mercury 😡
You're right, won't make any significant difference with the deck lamps.
If they won't turn on when the battery is low just change the resistors for 120Ohms.
Ciao Doug 😎
pittsfieldpete
Forum Posts: 69
24th Jul 2018 15:47
mdlbt.com/44128
Sorry, Doug. I missed the LED tester suggestion. I remember the one about the bench top battery charger. I must’ve been in one of my narcoleptic fogs. I’ll get a tester as soon as I can.
You’re correct, mercury vapor lights definitely would have been replaced by sodium vapor lights by now. Mercury that finds its way into the environment is a major concern. There are still areas on our interstate highways where yellow is used because heavy fog is a concern. Maybe a special yellow tinted lens is used. Bolt-on fog lights for cars have halogen bulbs in a housing with an amber lens. They cut through fog very well. Maybe the Wyeforce has similar deck lamps?
Speaking of fog, The Goo is coming back again with a vengeance. I’ll be back when my eyes are clearer.
Pete
1859 - 1932
Forum Posts: 2047
25th Jul 2018 02:31
mdlbt.com/44184
Morning Pete,
Hope you see something this morning cos here's your wiring diagram.
Any queries just YELL! 😁
Bon chance mon ami 👍
pittsfieldpete
Forum Posts: 69
25th Jul 2018 03:20
mdlbt.com/44186
Hey, Doug
The drawing is excellent; thanks very much. I have one concern about something that I might not be able to do. The resistors that are to be removed & replaced with jumpers are the surface-mounted type & are microscopic. They don’t have leads passing through the board that can be desoldered. Seriously, those resistors are very tiny. They’re only about 1/8” (3mm) long. If a flea sat on one it would overhang the resistor’s sides quite a bit. I have a couple of magnifying visors but I still may not be able to do the necessary microsurgery. My worry is that the patient may not survive the operation.
Are there any techniques that help make the job of removing those tiny resistors any easier?
Pete
1859 - 1932
Forum Posts: 2047
25th Jul 2018 11:06
mdlbt.com/44189
Mornin' Pete,
Mon plaisir 😉
Yeah, those surface-mounted-devices are a bit fiddly.
First thing is to clamp the board somehow so it can't slip.
Second: PLENTY OF LIGHT!!
Third: a small low power soldering iron, about 20W with a 1mm flat bit (chisel type). Temperature controlled if possible, set to about 200 - 250°C.
Fourth: a solder sucker is very useful to suck the solder off the joints, and probably the little resistor as well 😉
Fifth: a pair of flat ended tweezers. The cross-over self-gripping type are very good for this task, also to put the wire link on afterwards.
Finally: a large magnifying glass with stand, some have an area of extra strong magnification. Make sure it is very clean and the lighting does not cause shadows, reflections or refractions.
Alternative: heat the resistor with a standard 25W iron until the joints melt and flick it off with a scalpel! 😲 Just make sure no solder lands anywhere else on the board and shorts something out!!
Good luck👍
PS: my only concern with the mod is the current capacity of the switching chip / SMD transistors on the cct board.
I hope they can cope with the increased current 😉
That's why I tried to optimise the resistors and layout to keep the total current on each output as low as possible while still turning the LEDs on!
If something goes 'PoP' Don't call me - I'll call you! 😁
Forum Posts: 2047
26th Jul 2018 17:11
mdlbt.com/44212
Hi Pete,
JFF I built a little 'breadboard' (now where's my peanut butter!?😁) to test your LED lighting configurations.
Theory and calculation is fine but there's nowt like an acid test😉
Pics attached of the results (Christmas tree😊). Difficult to capture the colours due to the very bright white LEDs🤔 Will play with the resistors to bring up the yellows and dampen the whites a bit.
The 3 yellows at the bottom are the deck and cabin lights.
The 4 rows at the top are the mast lights, red and green self explanatory!
Applied (battery) voltage is shown on the meter top left, current drawn in mA on the meter to the right.
The circuits work fine from 6.0V upwards.
Current drain is approx-
110mA @ 7.8V (fully charged 6 cell NiMh)
103mA @ 7.5V (probable voltage after running a little while)
90mA @ 7.2V (nominal NiMh battery voltage. It will flatten out at approx this voltage after running a while - until it suddenly collapses at the end!)
75mA @ 6.6V (voltage of FLAT 6 cell NiMh battery)
60mA @ 6.0V curiosity! Below this some LEDs switch off. Brightness is noticeably reduced.
I think we can increase some resistors to reduce the current drawn without reducing the lighting effect😊
More info soon, I'm still experimenting, then I'll start modding my own tug😊 Cheers, Doug 😎
Forum Posts: 433
26th Jul 2018 17:45
mdlbt.com/44216
I don't envy anyone working of the mast of the Robertson or the Southampton!
Forum Posts: 2047
26th Jul 2018 17:49
mdlbt.com/44218
Or even the Richardson Ed 😉
Do you mean the model or the real McCoy?
Forum Posts: 433
26th Jul 2018 18:23
mdlbt.com/44221
The Model of course!
Some micro surgery have to be careful with the soldering iron!😲
Forum Posts: 2047
26th Jul 2018 18:33
mdlbt.com/44223
You betcha Ed😲
Watch this space!
Pete has triggered my curiosity - always dangerous 😁
Cheers Shipmate, Doug 😎
Forum Posts: 2047
26th Jul 2018 22:18
mdlbt.com/44244
Hi Pete,
have been running an endurance test, at 7.2V, for about 8 hours now.
All still burning merrily, nothing getting even warm and current stable at 93mA. Looks good👍 Cheers, Doug
pittsfieldpete
Forum Posts: 69
27th Jul 2018 00:12
mdlbt.com/44258
Excellent work, Doug:
Everything looks great. Unfortunately just as my eyes have begun to feel better I’ve been stricken by a mysterious illness. Fever, headaches & weakness. Ugh. I’ll read your posts when the headaches quiet down.
Thanks again, kind sir.
Pete
1859 - 1932
Forum Posts: 2047
27th Jul 2018 00:18
mdlbt.com/44259
😲 get well sooooon Pete
Forum Posts: 2047
27th Jul 2018 00:41
mdlbt.com/44260
Endurance test has been running for 11 hours now.
'All systems GO'😊
So RN-Munich is closing down for the night.
G'night an' sweet dreams of boat sailing all.
Cheers, Doug 'ZZZZZZZZZZZZZZZZZ'
Forum Posts: 2047
27th Jul 2018 08:36
mdlbt.com/44266
BTW: the above tests were done with 5mm LEDs just to prove the basics.
I also have 3mm LEDs and a strip of the miniscule SMD types.
I plan to use the SMD types in 1/350 scale Plastic Magic projects😉
I'll try those next to see if there's any significant difference in voltages / resistors required and current drain.
Due to the physics I expect the same forward voltages for the same colour LEDs but significantly less current for the SMD types. I'm curious to see how the SMD brightness compares with their big bruvvers!
More soon. Cheers, Doug (aka 'All Lit Up') 😎
Forum Posts: 2047
27th Jul 2018 13:13
mdlbt.com/44272
Hi All Ron's 'electronics Whizz Kid' here 😁😁
(See above for reference!😉)
Repeated tests with 3mm LEDs.
Within a mA current results are the same; all within 'experimental error limits😊 Noticeable was that the brightness of all combinations remains the same (to my eyes) from 7.2 to 7.8V.
All worked happily down to 6.0V and 60mA, just slightly less bright.
All but the two whites in series also worked down to 5.0V !!
The two whites were on but so dim they are barely visible.
Pics show operation at 6V, 60mA.
Now trying to figure out the mechanics of testing the tiny SMD LEDs!!🤔
pittsfieldpete
Forum Posts: 69
28th Jul 2018 05:04
mdlbt.com/44293
Hello, Doug:
It looks like a total success! Outstanding work!
Now that details for this job are just about finalized I’ve been putting a shopping list together for all of the components. 3mm LEDS should be just right for the Richardson’s mast lights. I’ll be able to easily scratch-build the mast light housings & mounting brackets from my spare kit parts bins.
When it comes to the LEDs for this project, what do I need to look for voltage & current rating, brightness or anything else? Unfortunately I can’t see very well yet but I can use Siri on my iPhone to type what I say. If there’s anything offensive in this post, it’s Siri’s fault. I can’t wait for this plague to leave me!
Thanks for your ceaseless generosity & patience.
Pete
1859 - 1932
Forum Posts: 2047
28th Jul 2018 10:13
mdlbt.com/44295
Mornin' Pete,
First off; I must admit that this effort isn't entirely altruistic! 😉
You piqued my curiosity (very dangerous!) but I can also use this set up in my Southampton tug 😊 although I will have to build the RC switches that you have on that circuit board.🤓 Not for the first time!
For the LEDs I used these for the tests-
https://www.banggood.com/search/led-3mm-100.html?direct=6&sb...
For a few bucks you have 100 coloured LEDs which should last you a while👍
BTW: I'll send you my mast over so you can fit the teeny weeny lamp brackets for me 😁😁
Look forward to seeing some pics of how you do that.
All the best,
Forum Posts: 2047
28th Jul 2018 10:30
mdlbt.com/44296
SMD LED test-
Spent yesterday afternoon stretching my eyesight and patience to the limits but finally managed to duplicate the above set up with tiny 1mm chip LEDs 😊 The gap between Vero Board tracks is just right for them. A jeweller's eyeglass was a very useful aid🤓
Test results were very similar to those of the 3mm LEDs using the same resistor values. A pain in the neck to find out which end is which and solder them without shorting them or the damn things jumping off 🤔 but got there in the end.
They're currently (!) on an endurance test at 7.2V, 93mA. Didn't have any yellow so had to use orange - almost indistinguishable from the reds!😲
As with the 3mm LEDs I think we can increase the resistor values and reduce the current drawn without affecting the effective brightness.
Cheers All, Doug 😎
pittsfieldpete
Forum Posts: 69
28th Jul 2018 10:55
mdlbt.com/44298
Good morning, Sir Doug The Amazing:
My eyes are getting steadily better but I’m still having some trouble. Regarding the LED link you sent there seems to be something odd. When I clicked the URL from within your post, a new page starts opening but a “page cannot be found” message appears in a few seconds. If I copy the link & paste it in the address bar of a new page the Banggood.com main page opens without any focus on LEDs. I’m losing my mind!
If you’re not completely blind from wiring up microscopic LEDs with strands of spider silk will you try sending that link again?
BTW the Banggood site looks like it could be a “one stop shopping“ source for the mast project. That would be a nice plus.
Thank you, O Miracle Worker!
Pete
1859 - 1932
Forum Posts: 2047
28th Jul 2018 12:01
mdlbt.com/44302
Hi Pete, STOP with the Sir Doug / Miracle worker and such, well meant but it's getting embarrassing!
None of what I do is rocket science, just methodical and tenacious application of some basics rules and laws.
Try this link.
https://www.banggood.com/100Pcs-3mm-Round-Top-LED-Diodes-Lig...
How your PC reacts to it depends on your browser and PC security settings! You can change the 'Warehouse' to US I think by changing the 'Ship to' to USA. Create an account pronto then it'll be easier and faster next time😉
Good luck👍 Cheers, Doug 😎
Just tested the link and it works fine for me😊
pittsfieldpete
Forum Posts: 69
28th Jul 2018 12:02
mdlbt.com/44303
Hey, Doug:
I was just rummaging through my “miscellaneous leftover, why did I buy this, what did I have in mind for those, where did those come from” stuff & I found the packet of “white” LEDs shown in the attached photo. Does the secret code on the front of the packet mean that these are anywhere close to being usable for my tug?
On another note, back when we were talking about various types of wire I mentioned telephone wire. The other photo shows the type that I was referring to. It’s essentially four 22 AWG solid wires, insulated with thin green, red, yellow & black vinyl & covered with a flexible vinyl outer jacket. This is kind of wire (or is it technically a cable?) has been used for household telephone hookups for a long, long time. In fact, it was originally made with cloth-like insulation on each wires & the outer jacket was a tough, thick material that was more like heavy PVC instead of the newer, thin-wall easy-to-strip. Rumor has it that old kind was field-tested by Lewis & Clark while they explored the Louisiana Purchase.
Pete
1859 - 1932
Forum Posts: 2047
28th Jul 2018 12:15
mdlbt.com/44304
Those LEDs will be fine Pete, now you just need a few red, green and yellow, or use 'Glass lacquer' on a few of those!?
I know that cable, correct several 'wires' in a bundle = a 'cable', it's what my Internet phone / fax is hanging on since I extended the system from the entry point in the cellar. Still works fine even with my Internet connection on it 😊 Still got about 50m of it left. The wires are in twisted pairs to minimise induced RFI/EMI.
Ciao, Doug
Forum Posts: 2047
28th Jul 2018 12:18
mdlbt.com/44305
link to Canadian warehouse-
Forum Posts: 433
28th Jul 2018 13:40
mdlbt.com/44307
Well, Good morning Sir Doug!
Forum Posts: 2047
28th Jul 2018 14:01
mdlbt.com/44308
Don't YOU start 😲
or I'll have you thrown in the Tower😁
Forum Posts: 433
28th Jul 2018 14:06
mdlbt.com/44311
Sorry, I couldn't resist!😉
Forum Posts: 2047
28th Jul 2018 14:09
mdlbt.com/44312
That's what I was afraid of 🤔
I'd have done the same 😉😁
BTW: I think Pete's 'nodded off' while posting!?
pittsfieldpete
Forum Posts: 69
28th Jul 2018 14:50
mdlbt.com/44313
Hey, Doug:
I’m heartily sorry if my gushy-sounding salutations & closings upset or offend you. It’s an old habit that my whole family & I picked up from my maternal grandmother over the years. Gram had a rare sense of humor that combined razor-sharp wit & wordplay with killer sarcasm that she could deliver with laser-guided accuracy to single or multiple targets. On those rare occasions that she missed her primary target, everyone in the room was still temporarily blinded by tears of mirth while they rolled around on the floor gasping for breath. My Mom, three sisters & I lived with Gram from the time I was 9 months old until I married & got my own place with my wife at age 22.
Gram’s arsenal of wit grew bigger & bigger even though she herself became physically smaller & smaller. In her final year she reached equilibrium where her age, weight & preferred room temperature were the same value: 98 (years/pounds/Fahrenheit).
Anyway, every time I repaired something at Gram’s House, usually plumbing or electrical problems, she was equal parts appreciative & amazed every time. I fixed dozens of things in her house & each time I told her I’d finished & said goodbye Gram would say something like “Thank you, Master of Plumbing Mysteries” or “I’m so glad you fixed the bathroom wall switch, “O Conqueror of Darkness”, that sort of thing. She grew up at a time when electrified homes & indoor plumbing didn’t exist & she always seemed to have a childlike sense of amazement with them. To her anyone who understood them & could fix them was a magician.
All that said I’ll be careful not to misspeak in the future. I hope you aren’t bothered by my clowning around occasionally. If so, just speak up & I’ll quit that, too.
Thank you,
Pete
1859 - 1932
pittsfieldpete
Forum Posts: 69
28th Jul 2018 14:53
mdlbt.com/44314
Hey, watch it you guys. I recently had a feeling installed & I’m sensitive.😉 Narcolepsy is no fun, believe me. 😴
1859 - 1932
Forum Posts: 2047
28th Jul 2018 15:21
mdlbt.com/44316
No sweat Pete, our family is very similar, my Mum, 93 last March, is just the same. She was gobsmacked when I souped up her Mk1 Mini Cooper (many years ago😲), or fixed her up with digital TV on a 50" screen, installed an extra phone in her bedroom etc etc etc!
I just thought it was only a matter of time before someone started extracting the Michael. Should have known it would be Ed 😁😁
As for 'clowning around', check out my posts😉
Forum Posts: 433
28th Jul 2018 15:35
mdlbt.com/44318
Pete, We're all one big happy family here on MBW!
We don't mean no harm!😁
pittsfieldpete
Forum Posts: 69
28th Jul 2018 23:19
mdlbt.com/44326
Doug??
What is “extracting the Michael”? I’ve never heard that expression before. Sounds like a technique that a plumber with a fondness for naming his tools would use to pull his stuck plumber’s helper out of a WC.
I’m sorry about that one. Anyway, have you pretty much finalized your resistor options for the tug’s LEDs? Judging from your observations things seem to be working very well indeed. If you have already posted your final configuration I’m sorry but I didn’t see it. What little bit I’ve been able to read about the project appeared to be on a path to optimization. Obviously I don’t want to buy incorrect resistors. That’s not likely to matter much because I’ve found a source where I can buy as many as “2600 1/4 watt .1% metal film resistors in 130 values” in one lot for $10.63 US including free delivery. Smaller lots are available from the same source for far less, also with free delivery. I just need to be certain of your final choices as determined by your tests.
Thank you,
Pete
1859 - 1932
Forum Posts: 2047
28th Jul 2018 23:43
mdlbt.com/44328
Almost on the right track Pete. Sort of😉
"Taking the piss (micturition), " -> "Taking the Mickey" -> "Extracting the Michael" 😁
Quaint Commonwealth expressions for pulling someone's leg, mocking them in a jokey manner. Some versions derived from Cockney rhyming slang; piss -> Mickey Bliss -> Mickey! 'Polite' version - Michael.
https://www.wikiwand.com/en/Taking_the_piss
pittsfieldpete
Forum Posts: 69
29th Jul 2018 20:38
mdlbt.com/44363
Hello, Figtree7nts:
What about “happy”? You wrote “we're all one big family”. Over here we’d usually say “we're all one big, happy family”. Are we not happy? Would anyone not grin from ear to ear when they see their boat on the water for the first time? Wouldn’t any of us be over the moon when our new boat kit arrives? If this or any other hobby doesn’t make us happy then why do it at all?
The above is all in good fun but far off topic.
Over to you, Doug:
For my project can I use the spreadsheets & drawing you’ve already sent or do you plan on posting revised versions based on your operating observations & adjustments? I’m going make a PDF of this entire post eventually so I’ll have a good reference to use as my project progresses. There a many very useful tips & parts sources throughout as well.
BTW have seen the scale boats made by Aquacraft? They’ve got four very nice boats (actually three boats & one ship) that are large, very well detailed & realistic. There’s a tug, a fire/rescue boat, a trawler & a fantastic 1/72 scale US Navy Fletcher-class destroyer that could easily be used as a movie prop. It’s over 5 feet long & priced at about $700 US. My wife said if I spend that much on a boat she’d better be able to ride in it or she’ll leave. I’ll really miss the old girl.🤪Here’s a link to Aquacraft’s page for the model. There’s a nice photo gallery as well as a video:
https://www.aquacraftmodels.com/boats/aqub5705-fletcher-clas...
I have my eye on the Bristol Trawler. I’ve always like trawlers & the Bristol is a beauty. It comes with a full range of LED navigation lights (including mast lights). There’s no working horn but that’s about the only thing lacking. This reminds of a joke: Why do cows have bells?🐮Because their horns don’t work!
Thanks, Pete.
1859 - 1932
Forum Posts: 433
29th Jul 2018 22:36
mdlbt.com/44367
Hi Pete,
Yes, We are all one big happy family!👍
And I'm always very happy to receive.
My kits in the mail or ups or what ever.
Aquacraft is a very good model company!
I haven't collected a trawler yet.
If you get one I look forward to your post!
Regards, Ed
Forum Posts: 2047
29th Jul 2018 23:21
mdlbt.com/44370
Hi Pete,
the wiring diagram as such will stay as it is, but after my test results I will revise the resistor value (upwards) to reduce the power requirement without reducing the perceived brightness.
Also to damp down the whites a little and bring up the yellows, otherwise I reckon the white mast lamps will be blinding and the yellow deck lights will look oddly dim. I would be tempted to use whites for the deck lights, maybe put a dollop of yellow glass lacquer on them to tone 'em down a bit.
Apropos Fletcher Class; I have 1/144 kit I intend to convert to RC.
My H class destroyer 1/72, HMS Belfast cruiser and Graf Spee pocket battleship 1/128 are also all about 4&1/2 to 5 feet!
Don't know how much longer I'll be able to carry them to the lake so I'm considering building a trailer, like I've seen here on the site, and using Jessica's old RC beach buggy to haul them 😊
Also have a 1/96 kit of the fast cruiser / minelayer HMS Manxman which is scheduled for the next winter build. Also 4 foot something 😲
pittsfieldpete
Forum Posts: 69
29th Jul 2018 23:43
mdlbt.com/44372
Thanks, Doug.
I really like the idea of simply using the exact same white LED for everything, including all of the colored LEDs currently on the boat. Coloring each LED the appropriate colors is the ideal solution. Glass lacquer is a great idea, plus Tamiya makes a translucent or semi-opaque acrylic paint available in many colors. Paints are ideal because I can control the depth of color simply by applying more coats. Another plus is that I can replace the somewhat cheesy looking port & starboard sidelights with more realistic ones. I like it!
Will you please rework things as necessary to account for white LEDs as I’ve described?
Things are coming together beautifully.
Thanks,
Pete
1859 - 1932
Forum Posts: 2047
29th Jul 2018 23:50
mdlbt.com/44373
OK will do👍
Since you've already got a 'lifetime supply' of white LEDs (and I know their spec now👍) it makes sense.
In the dim and distant past I used glass lacquer on the old 3V 'rice grain' bulbs to good effect on my destroyer.
It might be more difficult to get a decent red and green effect with lacquer though! Suck it an' see before you rush off and buy coloured LEDs 😉
Forum Posts: 2047
30th Jul 2018 00:19
mdlbt.com/44376
BTW: if you go for the glass lacquer don't apply it with a brush, dip the LEDs and hang 'em up to drip dry! How do I know? Learning by doing!! 😉
pittsfieldpete
Forum Posts: 69
30th Jul 2018 02:24
mdlbt.com/44392
Hey, Doug:
Thanks for the excellent advice. The “dip/dry/repeat if necessary” technique for coloring LEDs makes the most sense. Brush painting transparent colors always seems to result in a very blotchy finish.
Now that I can see well again I think I’ll turn my attention to removing the molded-on ladder rungs inside the mast. Sounds like a job for my little cordless Dremel.
Thanks,
Pete
1859 - 1932
Forum Posts: 2047
30th Jul 2018 02:34
mdlbt.com/44394
"Brush painting transparent colors always seems to result in a very blotchy finish."
That's EXACTLY the experience I made and why I recommend drip dry😊
Happy Dremeling 😁
Forum Posts: 433
30th Jul 2018 02:35
mdlbt.com/44395
Evening Pete,
Are you going to document what you do?
By posting picture and a thread?
Forum Posts: 326
30th Jul 2018 02:59
mdlbt.com/44396
Loads of resistors going cheap (no not cheep) on bang good at PRESENT V👍😁ELLY SHEEP
pittsfieldpete
Forum Posts: 69
30th Jul 2018 03:43
mdlbt.com/44400
Hey, Ed:
Yes, I’ll take several photos to document the project. I’ll shoot a video or two as well to highlight the differences between the tug’s original factory lighting & the new setup. I’ll shoot video of the tug out on the water at dusk, first with the light off, then with the lights on. It should look pretty good.
It’ll be a while before anything gets posted because I still have to get all the parts. I have a lot of nasty medical stuff to deal with, too.
Wish me luck.
Thanks,
Pete
1859 - 1932
Forum Posts: 2047
30th Jul 2018 03:50
mdlbt.com/44403
Shucks John, an' I just bought a batch o resistors 🤔
They don't make no noise neither 😁
G'night, cheers, 'Sleepless in Munich' 😎
Forum Posts: 326
30th Jul 2018 03:56
mdlbt.com/44405
Likewise in Meliden N.W.👍👍 Probably too many in most of the batches unless you sold some on Flea bay. Mixed values BTW😊👍👍I've ordered a hundred of ten to twenty ohms Ten of each for about £3.50👍👍
Forum Posts: 2047
30th Jul 2018 04:05
mdlbt.com/44406
Meliden! Sink a pint for me at the Red Lion 👍
Or do you prefer the Miner's Arms?
My Spies are everywhere 😁😁
Forum Posts: 2047
30th Jul 2018 04:08
mdlbt.com/44407
I just bought 20 of everything between 1 Ohm and zig MegOhms for about 7 Quid.
Should keep me going for a week or two 😁
What on earth do you do with 10 to 20 Ohms??
pittsfieldpete
Forum Posts: 69
2nd Aug 2018 02:40
mdlbt.com/44539
Hello, Doug:
I stumbled upon some other LEDs that are particularly well suited for navigation lights. They have the same specs as the rectangular LEDs shown in the photo I posted recently, but what makes them ideal for me is that they’re flat-topped, not domed. They’re cylindrical in shape, still 3mm diameter & look quite similar to ship’s lanterns (see photo). With your experience you’ve probably seen these before, but I was surprised to see them. My plan is similar to the original idea for making scale lights, except as we last discussed white LEDs will be used everywhere, colored by dipping them in appropriately colored glass paint. For the mast lights that will remain white but need to emit light at a given angle, I’ll mask & paint the LED’s body the same color as the mast, resulting in a clear aperture. 4mm & 2.5mm diameter disks punched from sheet styrene, glued one atop the other, then painted & glued to the top of each LED will form the light’s top covers.
What do you think?
BTW, the flat-top LEDs are also available in a variety of colors. If anyone is interested I’ll post the url to their location.
Thanks,
Pete
1859 - 1932
Forum Posts: 2047
2nd Aug 2018 11:33
mdlbt.com/44541
Sounds good to me Pete👍
Use the resistor values in the table I already posted.
Post the url please.
pittsfieldpete
Forum Posts: 69
2nd Aug 2018 16:14
mdlbt.com/44544
Good afternoon, Doug:
I found the flat-topped LEDs at Ali Express. The url for these LEDs is: https://m.aliexpress.com/item/32462840779.html?
I’ve included another photo of the LED that has a dimensioned sketch with it. FYI, I’ve ordered lots of stuff from Ali Express, such as hobby tools & supplies, electronic components, gizmos, gewgaws & doodads. One particularly nice thing I purchased is a wireless guitar-to-amp device. Everything I’ve bought has been top-quality, but because nearly everything ships from China it can take several weeks to be delivered to me here in Massachusetts.
Now for the inevitable question:
If I use your drawing as it is now & modified the circuit board, added the resistors as you’ve already indicated & connected white LEDs in all locations, everything would work OK, but some LEDs would be brighter than others because your design was based on using colored LEDs. Correct? Based on your observations & experience would any harm be done? Don’t worry, I’m not going to jump the gun without your final drawing (which I’m in no rush for...take your time). I’m just curious.
Which leads to my last remark, for now. For some reason my wife thinks I ask far more questions than “normal” people do. She claims that I’m exceedingly curious. I don’t know what she means, but her offhand remarks have inspired me to rechristen the Richardson. When the LED project is complete & the tug is all ship-shape & Bristol fashion, her new name will be: “Curiosity”.
1859 - 1932
Forum Posts: 2047
2nd Aug 2018 17:00
mdlbt.com/44547
Hi Pete,
Thanks for the link👍 The flat on those diodes should make them easier to fit to the mast😉
Use the 150 and 330 Ohm resistors as in the drawing.
If after painting test 'em and if you feel that the red/green and/or the two yellow deck lights are not bright enough reduce their resistors to 120Ohms.
If anything looks TOO bright or gets warm go one resistor value up.
I.e. 150 --> 180, 330 --> 470.
Good name for the boat👍
Maybe I'll name mine 'Knowall' or 'No-😊orl'.
pittsfieldpete
Forum Posts: 69
2nd Aug 2018 19:11
mdlbt.com/44556
Hey, Doug:
Thanks again. I’ll take your suggestions & mark up your drawing accordingly. I still need to finish clearing away the molded-on plastic details inside the mast, then order the parts for this project. I generally don’t like starting any kind of project until everything needed is on hand (everything I think I’ll need, that is). You’ll probably have your tug’s lighting finished long before I do.
I’m looking forward to being able to use my desktop PC comfortably again. Every word & photo I’ve posted on this fantastic site so far has been typed on or photographed with my trusty iPhone 6. It’s very convenient but it’s awfully hard on my eyes. The little touch keyboard is a challenge for my beat up old dinner plate-size mitts, too.
Anyway, when my tug’s new lighting & modified controls are all built, tested & buttoned up I’d like to combine your drawing, spreadsheets & various notes with my own hen scratches, notes & miscellaneous observations into a CAD drawing. Naturally you’ll be cited as the project EE/electronics designer on the drawing’s title block.
I’m confident in saying that your tug’s lighting will use factory colored LEDs, not hand-colored white ones. It would be a shame if I didn’t follow suit & use your design for colored LEDs as originally intended. I’ll much more satisfied knowing that the new navigation lights & other changes were done the right way.
The glass paint is coming off my list!
Thanks,
Pete
1859 - 1932
Forum Posts: 2047
2nd Aug 2018 19:22
mdlbt.com/44557
Hi Pete,
👍 The glass paint was only a 'wild card' suggestion when I saw that you had dozens of white LEDs 😉 Just happened to see it in the cupboard, I'd used it on some 3V bulbs for my destroyer years ago.
Dunno about mine being finished first. I've got a few other things cooking before I'll get back to to the Southampton. On the other hand ...... 😁😁
PS make a chain of the white LEDs and use them for 'dressing ship'! 😁
pittsfieldpete
Forum Posts: 69
2nd Aug 2018 19:48
mdlbt.com/44559
Doug:
The glass paint is indeed a great idea. It’s an idea that I’ll consider seriously whenever a situation arises that’ll make using colored LEDs impractical, such as on my 1:350 SS Normandie kit, maybe?
Finding the flat-topped LEDs made staying with your original design an easy choice.
Regardless of when the job gets done, I can just imagine launching the tug late in the day, waiting until just before dusk, then switching the lights on with the transmitter’s function buttons until they’re all shining & reflecting in the water.
It doesn’t get much better than that.
Thanks,
Pete
1859 - 1932
Forum Posts: 2047
2nd Aug 2018 19:55
mdlbt.com/44560
I also have a collection of 1:350 kits; HMS Ark Royal (carrier), HMS Hood, USS Enterprise The Big 'E', Bismarck and Titanic. Reckon I'll probably have to use the tiny chip LEDs for those.😲🤓
Can't wait to see photos / vids of 'Curiosity' in action👍
pittsfieldpete
Forum Posts: 69
2nd Aug 2018 21:16
mdlbt.com/44565
Doug:
Why do we do it? So many kits, so little time. I just looked at my list...736 kits, not counting the last year’s worth of purchases. I’ve convinced myself that it’s a nest egg.
My downstairs stash of 1:350 ships also has the Tamiya HMS Hood, Big E & USS Missouri. I’ve got the RMS Titanic, too & the RMS Lusitania as well. Subs of all types, a resin USS Long Beach & Bainbridge to compliment the Big E. Remember the famous “Nuclear Navy Trio” photo? I’ve attached a copy in case anyone hasn’t seen it.
The 1:350 Normandie is an astounding resin cottage industry kit that I got at a very good discount but it still cost twice as much as my first car! I can send you the link to it if you like, but make sure you’re seated before you look at the price.
BTW, I found sets of pre-cut, self-adhesive wood decks for the Titanic & Hood, too, I believe, & a few others, but I can’t remember which ones. They really make a model pop, for sure, but I’d be inclined to use contact cement or something so they don’t “pop” off the model. If you’re interested I can send info about those to you, too.
Pete
1859 - 1932
Forum Posts: 2047
2nd Aug 2018 22:02
mdlbt.com/44568
Hi Pete,
That was just a selection of my larger 350 scale kits! Forgot HMS Prince of Wales battleship😉
I also have a vast collection of everything from 720 to 72, including the Revell Flower Class corvette. I started an XL spread sheet to keep track of them with scale and size data, number of shafts, and where practical and already measured max load capacity!
Re: wood decks; I have them on my Graf Spee and HMS Belfast both 1:128, and have bought them for Hood, Bismarck and the corvette.
In my experience the self adhesive starts to pull up at the edges, always in the most awkward place to get to to fix😡 I learned to use a gel type gluper sue for first time fitting and thin runny stuff for repairs so it creeps under the edge a bit.
Yes please, the info on the decks would be useful especially Titanic. i have a premium version with lots of etch parts but no wood I think.
Why do we do it? Cos we're nuts! Prerequisite for scale modelling 😁
Happy modelling, Cheers, Doug 😎
PS my favourite carrier photo attached; Capn of the Nimitz wanted to go water skiing 😁😁
Rookysailor
Forum Posts: 84
2nd Aug 2018 22:35
mdlbt.com/44569
Hi Doug, with reference to your wooden decks for the 1/72 flower class corvette, where did you get them from? I'm having trouble getting any browser info🤔
many thanks, Peter😋
Forum Posts: 2047
2nd Aug 2018 22:40
mdlbt.com/44570
My God Peter! I've no idea now 😲 She's been in the stash for about 25 years or more now 🤔
Sorry. I'll look for the bits n pieces tomorrow n see if there's any clues. Ciao Doug
PS Found it! It was in the Great Little Ships Deck And Fittings Set, and it's brass not wood, and heavy.😲
https://www.djparkins.com/product.php?productid=18179&cat=30...
In the meantime I believe Artwox in Oz do a wood deck.
Rookysailor
Forum Posts: 84
2nd Aug 2018 23:26
mdlbt.com/44574
Many thanks Doug, once again to the rescue👍, would like to build mine as a USS one, any ideas....then maybe keep the deck steel!
just fancy a different version than the usual HMCS ones.
Peter😁
Forum Posts: 2047
2nd Aug 2018 23:40
mdlbt.com/44575
Know what you mean Peter, I think, when I get round to her, I'll do mine as 'HMS Compass Rose'. The 'fictitious' ship in Nicholas Monserrat's book 'The Cruel Sea'. Which is based on his experiences on a Flower Class in the Battle of the Atlantic. Well worth a read👍 Difficult to put down 😲
Try Googling and/or Wikiing Flower Class corvette and you should get oodles of links to photos of the originals and suppliers of kits n bits.
What you could do of course is to Go The Whole Hog and buy the newer Revell Premium version of the kit. That has wooden decks and a host of detailed upgrade parts. Plus LED lights etc 😊 List price here €199.
https://www.revell.de/en/products/revell-technik/flower-clas...
Whatever you do, enjoy it😊 Cos otherwise there ain't no point is there!?
Rookysailor
Forum Posts: 84
2nd Aug 2018 23:52
mdlbt.com/44576
Strange that you should mention the Movie/book 'The Cruel Sea', have just bought the DVD from Ebay, looking forward to watching it once again. I have an old Revell corvette kit, and last month bought the NEW corvette kit from Revell which has most of the lighting in kit form, plus revolving radar, but very annoyed 😆to find out that there is no p/e parts or wooden decking as in the platinum edition, but it only cost me £100 + vat trade deal, sssh🤐
Cheers Peter😊
Forum Posts: 2047
3rd Aug 2018 00:01
mdlbt.com/44579
Hmmm! Thanks for the warning👍
I've also got the old original kit, no lights or rotating radar, but those are no great sweat anyway.😉 And have collected a mass of 'after market parts. Premium edition seems to have disappeared? Shame.
Enjoy the film, but get the book. It's worth it.
G'night, Doug 😊 ZZZZZZZZZZ
Forum Posts: 2047
3rd Aug 2018 00:10
mdlbt.com/44581
Wadaya Know!
There's still some Premiums / Platinums around and not so pricey now😊
https://www.modellbau-universe.de/produkt%3Bflower-class-cor...
Forum Posts: 326
3rd Aug 2018 17:08
mdlbt.com/44589
Hi doug Can't get a word in sideways /edgewise LOL. Re the resistors I'm repairing some "wall warts" and need output resistors which have been burned out by shorting. Guessing the resist needed but quite small.All I have tried so far have been too much. Red Lion, Miners very good but The Star (old Plough) is less than 100 yds away opposite the end of the Grove where we live. Just across the main road. How come you know Meliden then? The thing is I'm more or less T-Total.😜👍
Forum Posts: 2047
3rd Aug 2018 21:51
mdlbt.com/44591
H
i
J
o
h
n
My 'word in edgewise'😉😁
Are you sure they are resistors and not chokes? What output voltage and current rating are the Warts?
Can't claim to 'know' Meliden! Nearly 50 years ago I lived at RAF Cosford, between Wolverhampton and Wellington, and from there, or when I visited an Aunt & Uncle in New Brighton Wallasey, we used to tour North Wales from time to time. Meliden rang a faint bell, so I Google-mapped it 😉
Sometime much later after a business trip to Liverpool I took 'the pretty way, home to Sandhurst via Wales and the M4 😁 Loved it 👍
The Grove huh? Bet that's your Boat Transporter 😁😁
Forum Posts: 326
4th Aug 2018 09:35
mdlbt.com/44614
Deffo resistors come after the choke. They drop the voltage from 15v to 7.5v To charge Nimhs at 7.4 at various capacities from D cells singles or multiples down to 6 cells Half AA packs. The Ds are glow starters the others for various Radio/Power packs Say 19000 or so Mmilliamps down to a few hundred. all have been shorted some how and fried the resistors beyond readability. I'm doing this for fun as I have others I can use but would like to keep them with their original kit. If needs be I can series them. Auf Wieder whats it. John👍😁
PS thaf van is at no5 I live at no 7🤓
epmbcmember
Forum Posts: 20
8th Aug 2018 19:28
mdlbt.com/44841
I have a Richardson Tug and have now got each prop with its own ESC, trouble is to do it I had to replace the radio which cut out the lights, horn and smoke so maybe to strip out everything and start again is the best idea. Individual twin props are good, it will now turn around in iys own length. I gues it depends on what you want to do with it, just sail it or use it for tug towing.
Forum Posts: 2047
8th Aug 2018 20:16
mdlbt.com/44845
Put the original radio board, smoker and light wiring back in.
Take out your new RX and ESCs and use them for something else.
Then fit a P94 dual ESC and Rudder Mixer from Action Electronics, sold by Component shop. You will get the same effect when used in Mode 3 👍😁
You will only need the 10A version for the Richardson.
https://www.componentshop.co.uk/p94l-dual-esc-and-mixer-2-x-...
Only difference with the 20A version is chunks of ally on the power transistors as heat sinks! Easy enough to 'self fit' 😉
Have fun, cheers, Doug😎
