Active Users (13)
>> Home > Forum > Electrical Related > LED Tug Mast Navigation Lights
(3162 views)
pittsfieldpete
Forum Posts: 42
28th May 2018 13:32
mdlbt.com/42219
Hi, everyone:
I have a Hobby Engine Richardson Tugboat that I’m about 98% happy with just as it came out of the box. The 2% that I’d like to add would be to rebuild the main mast & replace the “dummy” mast-mounted navigation lights with LEDs. The mast has a partially open back with molded-on ladder rungs. I plan to use the open area for wiring, then add a back cover & bent wire rungs. The boat has working red & green sidelights, working rear deck area floodlights, a working searchlight on the pilot house roof & working pilot house interior lighting. Each of the “white” lights have individual on & off function switches on the transmitter, which is excellent. But for some odd reason the red & green sidelights are turned on & off separately. Ideally, what I would like to do is combine the sidelights so they switch on & off together with one transmitter switch & use the now “spare” transmitter switch to turn the new mast-mounted “white” lights on & off. I realize my plan may not be possible but I really would like my idea to work. Note that the tug has a short mast attached to the aft pilot house railing. This mast has two dummy navigation lights & the main mast has three. I plan to remove the short mast & add two aft-facing lights to the main mast. I’ll need help with wiring power correctly for the five new LEDs. I’d like to tap into the boat’s 7.2 volt battery power, but it might be best to add a separate battery box. I’d really appreciate ideas. Can anyone offer advice about my project? Is it feasible to do or should I leave well enough alone? Thanks.
Forum Posts: 210
28th May 2018 20:58
mdlbt.com/42243
Although I've never had any dealings with these type of boats , I'm pretty sure that they are built in such a way that they aren't easily modified without ripping out everything and starting again.
As the electrics are built into the circuit board it's not easy to identify each circuit function without having a electronic wizz kid at your side.
I think the easiest option would be to put in a separate switch,battery ect.
Forum Posts: 1821
28th May 2018 21:57
mdlbt.com/42248
Evenin' Pete, basically Ron's right, but there may be a way, 😉if you have a simple multimeter! I'll get back to you tomorrow when I've thought it through.
Cheers,Doug 😎
BTW; I'm a retired electronics engineer 👍
pittsfieldpete
Forum Posts: 42
29th May 2018 21:44
mdlbt.com/42269
pittsfieldpete
Forum Posts: 42
29th May 2018 21:50
mdlbt.com/42270
Forum Posts: 1821
29th May 2018 23:33
mdlbt.com/42275
Hi Pete, Good to hear you've got a multimeter👍 and also that the board has unique plugs and sockets. I only have the earlier version of this Tug (the Southampton) with 40MHz RC and no lights or frills 😭
Would help enormously if the bottom cover can be removed so you can see which leads connect to the 'side' lights - the red and green navigation lights.
I am assuming that the existing lights have LEDs and not bulbs? Please correct me if I'm wrong. It makes a difference. And you want to add 5 new white LEDs on one circuit powered from one of the existing switch channels.
OK. been a hard day today and now 00:30 here so I'll finish this and send you the gen tomorrow. Will probably take longer to describe than to do.😉
deepdiver
Forum Posts: 52
30th May 2018 09:07
mdlbt.com/42279
Have a look at this
http://led.linear1.org/1led.wiz It may be of some help
Fred
Forum Posts: 1821
30th May 2018 10:47
mdlbt.com/42281
Good stuff Fred, 👍
I have something similar that I will use to help Pete,
When we know where to connect up!
More later, cheers Doug 😎
pittsfieldpete
Forum Posts: 42
30th May 2018 14:42
mdlbt.com/42284
Forum Posts: 1821
30th May 2018 15:26
mdlbt.com/42285
Hi Pete, Okaaay!
That complicates the issue a little. 'I think I better think it out again'!
Now we have to decide which lights you want to switch together as some would not normally be on simultaneously; e.g. Anchor and running lights.
Do you perchance have a layout drawing of the circuit board and the plugs and sockets? 'snipped' out of the instruction book perhaps.
Or a good focussed photo might do.
As I understand it you currently have the following switchable functions, correct?
1. red running light,
2. green running light, to be combined with the red,
3. white deck lights, How many individual LEDs?
4. white searchlight,
5. white interior lights, How many individual LEDs?
Need to know the numbers of LEDs in 3 and 5 to estimate the current the switching circuits can handle!!!
Maybe we could combine some others as well, e.g.
deck lights and towing light or anchor light?
Stern light with the red and green?
Deck lights with the interior lights?
Interior lights with the running lights?
Forum Posts: 1821
31st May 2018 15:12
mdlbt.com/42309
Hi Pete, Some basics.
If you want to run 5 LEDs from 7.2V this is the circuit you need. See pdf.
Click the file icon and then 'Download' in the top left of the disply to view and download the file as pdf.
If you want to drive 6 LEDs you insert the 6th in the third branch and change the resistor to 62 Ohm, like the first two branches.
Current drawn remains 60mA, power consumption drops a few mW.
Any dropping resistor fitted on the circuit board must be shorted out or replaced with a tinned copper wire link, if possible. More on that later.
Instructions for wiring up, and finding out where!, follow this evening.
cheers Doug 😎
BTW: does this look like the circuit board you have? (Last two pics.)
Same part # JH-003R ?
pittsfieldpete
Forum Posts: 42
5th Jun 2018 11:26
mdlbt.com/42430
Hi, Doug:
You’ve been a busy man! I certainly appreciate your efforts & assistance. I haven’t removed the tug’s deck or the bottom cover of its pilot house to look at the circuit boards as yet but I’ll do it later on this morning.
TABLE ONE - EXISTING CONFIGURATION
Switch L2 - Controls (1) clear LED pilot house roof searchlight.
Switch L3 - Controls (1) red LED port sidelight.
Switch L4 - Controls (2) clear LED aft deck lights.
Switch R2 - Controls (1) clear pilot house interior light*.
Switch R3 - Controls (1) green LED starboard sidelight.
Switch R4 - Controls the horn.
TABLE TWO - MODIFIED CONFIGURATION
Switch L2 - [No change]
Switch L3 - Controls (1) red LED port sidelight, (1) green LED
starboard sidelight, (1) aft-facing clear LED anchor
light & (1) aft-facing clear LED navigation light.
Switch L4 - [No change]
Switch R2 - [No change]
Switch R3 - Controls (1) yellow LED mast top light & (3) forward-
facing clear LED navigation lights.
Switch R4 - [No change]
The modifications above result in having (4) LEDs controlled by
Switch L3 & (4) LEDs controlled by Switch R3. If these changes are possible then adding the (6) new LEDs should be relatively easy, plus all lighting & the horn are still powered by the tug’s 7.2 volt battery. I plan to upgrade the battery to a much higher mAh rating to help offset the extra drain from the additional LEDs.
Thanks again for your help.
Pete
Forum Posts: 1821
5th Jun 2018 11:58
mdlbt.com/42431
Hi Pete, sorry no attachment found!🤔
Or did you just type copy from the booklet?
Is there a pic of the circuit board and wiring in the booklet?
Maybe the board is marked with L2 etc to identify the outputs!
That would be too easy though 😉
The bulb: can you see it from outside?
A white LED should be 'see through' or milky and look like the attached pic. Ciao, Doug 😎
pittsfieldpete
Forum Posts: 42
5th Jun 2018 13:55
mdlbt.com/42433
Sorry about that, Doug. My not-so-nimble fingers hit the “Post “ button before I finished everything. I think everything is posted now.
pittsfieldpete
Forum Posts: 42
5th Jun 2018 13:57
mdlbt.com/42434
I’d rather have a bottle in front of me than a frontal lobotomy.
Forum Posts: 1821
5th Jun 2018 14:15
mdlbt.com/42436
OK: just off out to restock the 'bottles in front of me' 😉
More later. No pic of the circuit board in the booklet??
Maybe you can photograph it, both sides if possible.
Would help to us to discover the dropping resistors in each output circuit.
Where they are and what values.
Cheers Doug
pittsfieldpete
Forum Posts: 42
5th Jun 2018 15:18
mdlbt.com/42437
Forum Posts: 1821
5th Jun 2018 20:41
mdlbt.com/42443
OK Pete, I've started trying to write down some instructions as to how we might find the correct wires and modify them. More soon, ciao Doug 😎
pittsfieldpete
Forum Posts: 42
5th Jun 2018 21:32
mdlbt.com/42446
pittsfieldpete
Forum Posts: 42
5th Jun 2018 21:43
mdlbt.com/42447
There is only one ceiling light in the pilot house.
Forum Posts: 1821
5th Jun 2018 22:05
mdlbt.com/42448
Weird😲
Can you get at it to change it for an LED??
pittsfieldpete
Forum Posts: 42
6th Jun 2018 01:31
mdlbt.com/42452
Forum Posts: 415
6th Jun 2018 03:13
mdlbt.com/42453
Hi Pete,
I have the Southampton too. which came with no lights!
I got it about 6 years ago.
Anyway I carefully took the top off the pilot house using a single edge razor! You could give that a try! I also painted mine to resemble the WYEFORCE!
Good luck, Oh I also painted the inside of the pilot house as well!
pittsfieldpete
Forum Posts: 42
6th Jun 2018 05:53
mdlbt.com/42456
It looks great! It really stands out from the crowd...er, fleet of similar tugs. How long did it take for you to remove the pilot house roof? Thanks.
Forum Posts: 415
7th Jun 2018 02:48
mdlbt.com/42478
Hi Pete,
When I worked on mine. I believe it took me about an hour or so!
Just be careful with the seams! take your time.
Start from the rear of the Pilot house!
I first took apart the pilot house.
I took the smoke stacks off!
Then slowly pride the rear of the pilot house!
NOTE: on mine they had only glued the glue points!
If you look carefully, You can see them.
They're located at each corner!
Maybe you can also use a wide xacto.
That's what I used back then.....
Good Luck!
pittsfieldpete
Forum Posts: 42
7th Jun 2018 05:32
mdlbt.com/42479
Thank, Ed. Now I have some helpful advice I can use to get the roof off. Excellent!
Pete
Forum Posts: 1821
7th Jun 2018 06:09
mdlbt.com/42480
HI Guys, took me about 10 seconds to get the roof, which was grey not white, off my old 40MHz Southampton 😊
It wasn't glued on at all 😲 Just ran round the seam with my thumbnail and it popped off 😁 All the rest was screwed together. Only some of the detailing 'stuff' was glued. Some was just 'plugged in'.
More later Pete, cheers Doug 😎
pittsfieldpete
Forum Posts: 42
7th Jun 2018 13:06
mdlbt.com/42486
Pete
Forum Posts: 1821
7th Jun 2018 13:22
mdlbt.com/42487
Afternoon Pete, Not awesome 😉 just 'Been there - Done that'!
Albeit on older versions.
So; now we're getting somewhere. Good idea with the connector 👍
I plan to do that with mine as well. I took it apart to investigate adding smoke, lights and sound. And possibly a twin ESC rudder mixer.
Project got shelved when I got deeply involved by a couple of renovation / conversion jobs. 🤔 You've inspired me to bump her up the 'To Do List' a ways 😉
Now we should be able to trace the wires back to the circuit board😊
Will send a Step by Step procedure tonight. Gotta go fix a rotten fence now 😡 Cheers Doug 😎
PS: I was also impressed with the quality and fit of the mouldings. Good tooling 👍
PPS: You may find this thread useful
https://model-boats.com/builds/view/34234?goto=34235
Neil has also been down a similar road. 'Jarvo' as well, who came up with some useful tips, esp re locations of hidden screws😉
Forum Posts: 260
8th Jun 2018 02:56
mdlbt.com/42521
Doug that pilot house light could be a fusible link. Has it got a white painted tip? If so it is fusible for sure. If not it is a" could be" fuse. Trouble is you can't test it LOL😁👍 You could;if you can find one,fit a resetting led fuse.🤓
John /O/T
pittsfieldpete
Forum Posts: 42
8th Jun 2018 03:29
mdlbt.com/42522
Pete
Forum Posts: 1821
8th Jun 2018 08:46
mdlbt.com/42523
See where you're coming from John. But what would be the point?
The bulb is only connected to one output of the RX board so has no influence on other circuits.
Pete; same applies to the 'resistor' idea. Plus; the bulb's DC resistance is around the square root of not very much!😲
I've found some pics of the internal wiring of the Richardson, samples attached, and am trying to figure out what we can do to maximise the flexibility of the existing function switches. Your pic of the cabin roof connections has given me an idea Pete 👍
More later, plus some LED basics for future reference.😉
Happy Tugging All, cheers Doug 😎
pittsfieldpete
Forum Posts: 42
8th Jun 2018 10:40
mdlbt.com/42524
Thanks again, Doug.
Full speed ahead!
Forum Posts: 1821
8th Jun 2018 12:00
mdlbt.com/42526
Hi Pete, Go easy with the prying!!
You're right. The spring loaded button is the way in. But it can be very stiff and underneath the hatch is a dense foam rubber gasket which makes the hatch catch (😆) difficult to release. Press the button firmly down while trying to ease the hatch forward with your blade.
In my basic version there ain't much underneath except the rudder servo.
But that's where I intend to put a decent battery.
Re electronic speed controller (AKA ESC); it MAY be on the cct board but I doubt it cos I don't see the FET power transistors for the outputs to the motors! Unless that's them in the bottom left corner in the second pic?
In mine it's a separate square block with the heat-sink tabs of the transistors clearly visible. Trace the wires back from the motors to find yours😉
Everything else, RX and switched outputs, is on the cct board.
Check out the blog with the link above and you will find all the secrets about removing the deck without busting anything👍
More later, ciao, Doug 😎
pittsfieldpete
Forum Posts: 42
8th Jun 2018 13:33
mdlbt.com/42527
Hey, Doug:
Thanks,
Pete
Forum Posts: 1821
8th Jun 2018 14:05
mdlbt.com/42528
Great👍 Those are the FETs😊 actually 4 of 'em as I would expect.
Do me a big favour😉 Now take a full-frame close up of the whole board showing all connecting wires and the legends on the sockets please.
I've just chopped half the stern off my 'disaster area' Fish Cutter!
Oh woe is me 🤔
Forum Posts: 1821
8th Jun 2018 14:27
mdlbt.com/42529
OK Got 'em!
N channel MOSFETS good for 180V, 4A DC and 16A Pulsed (as with our speed controllers) so more than enough for our 'little toys' 😊
pittsfieldpete
Forum Posts: 42
8th Jun 2018 15:29
mdlbt.com/42530
pittsfieldpete
Forum Posts: 42
8th Jun 2018 15:39
mdlbt.com/42531
Forum Posts: 1821
8th Jun 2018 15:41
mdlbt.com/42532
Muchas gracias Pete, important is that as many legends on the board as possible are readable. 😎
Forum Posts: 1821
8th Jun 2018 15:45
mdlbt.com/42533
Can't sir down for a month or two either 😡😱😁
New Build Blog will soon reveal all (Or as much as I want to😉)
Little progress expected this evening; dinner with the GF and Germany plays Saudi Arabia 😁 in a Test Game. If they flunk that then they can save the air tickets to Moscow😉
Forum Posts: 415
8th Jun 2018 16:54
mdlbt.com/42535
Hi Pete,
I agree with Doug. Push and lift at the same time!
At least that's how mine worked out! I found a piece of foam in the bilge of my southhampton. didn't see the point of it. so I took it out! Now underneath the first hatch. I found the reciever.
Believe it or not it was a 27mhz reciever! Which I quickly switched out for a 2.4ghz reciever.
But maybe the Richardson Tug is completely different electronics wise....!
pittsfieldpete
Forum Posts: 42
8th Jun 2018 19:10
mdlbt.com/42536
Forum Posts: 415
8th Jun 2018 19:36
mdlbt.com/42537
Hi Pete,
Glad you have learned! I too have learned as well.
My Southampton didn't come with lights.
So, your Richardson tug.
must look awesome on the water at night.
Oh, 2.4ghz is way better than 27mhz.
This is why, I changed the reciever to my Southhampton!
And the long aerial just doesn't look right!
Forum Posts: 1821
8th Jun 2018 21:47
mdlbt.com/42538
Evenin' Both,
Pete, you're right about the hatch, in the instructions (or mine at least with the old 40MHz version) they warn you to leave the hatch loose when not using the boat. Otherwise it sticks to the foam gasket. Just like yours did 😉 During the upgrade of my 40MHz Southampton I will remove that over-engineered catch and use neodymium magnets in the corners instead. That gives more 'headroom' to fit a decent sized NiMh battery underneath 😊
And yes there are 3 different versions of this boat, whereby Richardson and Southampton are identical apart from name and 'paint job'. 27 and 40 MHz with no frills and the modern 2.4GHz version with bells and whistles. Well, lights and smoke anyway 😊 Makes a change from Smoke and Mirrors eh? 😁 So between the 3 of us we represent all 3 generations!!!
Re different RC frequencies, as a ex Radio and naval COMMS engineer:
27MHz and 40MHz have inherently longer range and better water penetration, which is why I still have such sets for my submarines.
2.4GHz is strictly Line of Sight only, which is one reason why they first gained popularity with the 'Fly Boys'. 2.4Gig waves also bounce off water or are absorbed by it, so it's useless for subs😭
The other reason is that they use a frequency hopping (FH) technique which makes them virtually immune to interference 😊 Although I have yet to find a set that hops over the full 85 frequencies available. Most seem to only use 16 or so🤔 Limited bandwidth at the RX !?
As with all FH radio systems 2.4Gig RC sets also use a binding technique so that the RX recognises the 'signature', i.e- hop sequence, of it's own TX and ignores others. Mostly anyway 😉
Here endeth the 99th Epistle of Admiral Doug 😁
Main thing is, enjoy the 'fiddlin aboot' and even more so the sailing, as my German colleagues say; "I wish you always a hand's breadth of water under your keel". Cheers Doug 😎
Forum Posts: 260
8th Jun 2018 22:08
mdlbt.com/42539
Forum Posts: 1821
8th Jun 2018 22:20
mdlbt.com/42540
Tell me about it John😲😉
I got fed up with hunting for the dud bulbs in the chains year after year. So threw 'em all out a few years ago and replaced with LED chains and icicles and snow showers and .....
Anyone need a batch of spare Chrimbo tree blubs!?😁
pittsfieldpete
Forum Posts: 42
9th Jun 2018 00:02
mdlbt.com/42546
Hey, Doug:
Board-01: Overall view of the board, “North” is at the top.
Board-02: “Northeast” corner.
Board-03: “East” edge. All of the labels are letters.
Board-04: “Southeast” corner.
Thanks.
Forum Posts: 1821
9th Jun 2018 00:16
mdlbt.com/42547
Thanks Pete👍 The row of 220 Ohm SMD resistors give a very good clue!
My 67 year old eyes let my Sony Cybershot take the strain 😉
Get back to you soon. It's sack time here in Munich now. "ZZZZZZZZZZZZ"
CU. Ciao, Doug 😎
pittsfieldpete
Forum Posts: 42
10th Jun 2018 15:46
mdlbt.com/42582
Hi, Doug:
Pete
Forum Posts: 415
10th Jun 2018 16:45
mdlbt.com/42586
Hi Pete,
Not sure why the name plate says Southampton.
I've never seen the Atlantic before!
The controller that you see is the 27mhz unit
I know I have one in my spare parts bin!
Forum Posts: 1821
10th Jun 2018 21:23
mdlbt.com/42592
Hi Both, All the mouldings look identical to the Southampton and Richardson. The hull and stand are the same as my 'Southampton', the superstructure the same as the Richardson?, but with a red roof😆?
Maybe they ran out of grey and white plastic 😁
pittsfieldpete
Forum Posts: 42
11th Jun 2018 04:51
mdlbt.com/42602
Hey, Guys:
Forum Posts: 415
11th Jun 2018 19:43
mdlbt.com/42618
That's about right take a look at the real Wyeforce!
Guess 22" is where they thought the model should be at!
https://www.marinetraffic.com/en/ais/details/ships/235000813
pittsfieldpete
Forum Posts: 42
12th Jun 2018 11:49
mdlbt.com/42624
Enough said.
pittsfieldpete
Forum Posts: 42
20th Jun 2018 12:20
mdlbt.com/42919
Hi, Doug:
Forum Posts: 1821
20th Jun 2018 22:52
mdlbt.com/42941
I ain't laughing Pete, it's a fair question (or two) 😉
1 Location: you're on the right track👍 A little distribution board, e.g. built on Veroboard, is a good tidy solution and simplifies any troubleshooting later. Put the resistors in the + lead to the LEDs.
2 Resistor size and heat: 1/8 or 1/4 W resistors will do nicely. Since they will only be passing 20 to 30mA they should not get hot. The size is about 3mmx 10mm. Allow 3 or 4mm at each end for the leads for flat mounting.
3 Values: Before we can determine these we will need to know what voltage is supplied to the dropping resistors on the circuit board just before the plug and socket connection to the lamp wire.
So you will have to do some testing with your multi-meter😲
before you pull anything apart make a sketch of the lamps connections to the board. Switch on your TX and RX - IN THAT ORDER PLEASE!
Switch on each existing light in turn and measure the volts at the socket on the board, referred to the negative of the main battery supply.
Then look for one of those teeny SMD resistors directly connected to the socket pin you've just measured and check the volts at both ends while the lamp is on. Note all these readings on your sketch.
Make a clear photo of this sketch and post it or PM me for my email address. doug-bell@t-online.de that might get deleted by the site system🤔 When we have these readings I can work out some suitable combinations to achieve what you want and minimise the number of different resistors. Basically I need to know if the full 7.2V of the main battery is switched to the resistor by the RX output! If not then what!?
Hope this makes sense 😉 Takes longer to describe than to do it !
Re sourcing: Try Radio Shack. I recently pointed another site colleague (figtree) in this direction for a similar project with his Brooklyn tug.
For instance-
https://www.radioshack.com/collections/resistors/products/50...
This is a collection of so called preferred values, i.e. near enough standard values and cheap to produce by the millions.
For $7.50 it's got all the values you are likely to need for the next 10 years illuminated boating 😁
Cheers, Doug 😎🤓
pittsfieldpete
Forum Posts: 42
21st Jun 2018 00:28
mdlbt.com/42943
Thanks, Doug.
Forum Posts: 1821
21st Jun 2018 00:48
mdlbt.com/42944
Mornin' Pete (at least it is here!)
Yes, switch on only one light at a time to avoid any confusion with the readings. Easier to find the 'live one' then.
Socket means the connectors on the circuit board where you told me plugs from the superstructure wiring are connected , and as I saw in your photos.
First job is to trace all wires back from the existing lights and note them on your sketch. If any are directly soldered into the board the procedure is just the same as if it were a socket pin.
I'm particularly curious about the voltage to the bulb, and why it's a bulb in the first place.
Carefully check all other lights, if they are also bulbs we have a slightly different ball game. Still need the voltages though 😉
I guess we are all collectively responsible for the demise of local model shops and Radio Shacks and the like. We all want Rolls Royces and Cadillacs but are only prepared to pay Hyundai and Toyota prices, so we all (me too - Guilty as Charged🤔) buy online from HobbyKing and similar and the local shops starve. Simple economics. Model shop owners gotta eat too!
Sack time now in Munich, tomorrow (today😲) is another day, ciao, Doug 😎🤓
pittsfieldpete
Forum Posts: 42
21st Jun 2018 04:28
mdlbt.com/42945
Hi, Doug:
Forum Posts: 1821
21st Jun 2018 07:24
mdlbt.com/42947
Sorry, my mistook🤔
Look forward to the sketch, cheers Doug 😎
pittsfieldpete
Forum Posts: 42
23rd Jun 2018 17:00
mdlbt.com/43020
Hello, Doug:
Forum Posts: 1821
23rd Jun 2018 22:19
mdlbt.com/43026
Hi Pete,
Number 1, Get yourself some more batteries! You'll want a spare at the pond anyway 😉
Better still, get a variable mains power supply for such bench tests so you don't have to mess with batteries until you're on the pond!
Here in Munich I got a Basetech 30V 5A regulated PSU for less then the price of a decent boat kit. See 2nd pic, shows mine during my test of a converted field coil motor to make it run forwards and backwards.
it saves a lot of faffing about with batteries for a quick test of a circuit😉 Get one where you can set a current limit down to mAmps so you don't risk blowing components, e.g. LEDs!
Re Connectors: if you are going to make a little distribution board for the lights then why not use this for all connections to the superstructure?
I.e. first solder all the wires from the circuit board into the input end of your Veroboard.
At the output end solder a strip of 1/10" pitch connector pins. Try Radio Shack!
For each output to lamps, smoker etc you can then use the little 2 pin JST plugs. See pic. Type JST-RCY. Try Googling them.
Sure you can get these from any half decent Online RC supplies shop over there. They are often used in Park Flyer planes etc.
Doing it that way you only have half the wires to squash into the tiny plugs 😉
As soon as we have the voltage readings we can work out the connections and resistors etc for your little board.
Happy measuring😁 Looking forward to your sketch. Cheers, Doug 😎
pittsfieldpete
Forum Posts: 42
30th Jun 2018 23:37
mdlbt.com/43361
Hi, Doug:
pittsfieldpete
Forum Posts: 42
3rd Jul 2018 10:52
mdlbt.com/43401
Hey Doug!
Thanks again,
Pete
Forum Posts: 1821
3rd Jul 2018 11:26
mdlbt.com/43402
Hi Pete, many thanks, good work 👍
Just one question; What was the battery voltage?
GF about to drag me out to the Shopping Mall 🤔 so more this evening.
pittsfieldpete
Forum Posts: 42
3rd Jul 2018 13:38
mdlbt.com/43405
Hi, Doug:
Sorry about that. Where power enters the circuit board the reading is 8.08 volts, same as the 7.2V battery pack when it’s fully charged.
That sounds like something from an Abbott & Costello routine!
Forum Posts: 1821
3rd Jul 2018 16:34
mdlbt.com/43408
"Who's on first base?"
"Yes."
"What"?
"No, What's on second."
"Who?"
"No, What. Who's on first."
BTW: thanks for the input voltage 👍
Is that the same value where you have marked '+' on the sketch?
c
pittsfieldpete
Forum Posts: 42
3rd Jul 2018 17:05
mdlbt.com/43410
Doug:
Yes, sir. I should’ve written “8.08V” next to the “+” but I missed it.
Pete
Forum Posts: 1821
3rd Jul 2018 17:13
mdlbt.com/43412
OK. Good, that's all I need to know 👍
Now to put new batteries in me calculator 😁
BTW: I know soccer isn't exactly THE game over there, BUT
England are playing in the World Cup tonight, wish 'em luck - they might need it 😉 Ciao, Doug 😎
