February 2019: 8 people January 2019: 16 people December 2018: 6 people November 2018: 11 people October 2018: 9 people September 2018: 13 people August 2018: 5 people July 2018: 8 people June 2018: 8 people May 2018: 7 people April 2018: 9 people
Again, as not wanting to nick someone else's thread.
Huntsman 31 currently has a geared (belt) brushed motor which was probably quite a good spec. many years ago. I don't remember how quick it was but having watched brushless boats running this morning in Southsea I have decided now is the time for change before I start painting.
I've been reading various threads and gleaned some info but it is still a minefield. Whilst this boat (original) is twin screw I am not yet ready to go that far so will stay single screw.
A thread suggested 3639 -1100KV which is fine as a spec. but there are a zillion different makes and models for that spec. Cornwall models seem to offer 6 or 8 so I am looking for more specific advise for make and model of each piece of the power system...motor, ESC, battery, charger.
I'm not going to say 'money no object' just that I don't 'need' to buy bottom spec.
I suspect there will be as many different suggestions as 'Cornwall' have motor makes but something good will come out of it. Many thanks Steve
Hi Steve I started with the Hobbyking 3639-1100 kv in my Huntsman with a 2 blade 40mm prop, 3S 5800mah Lipo and a car 60 Amp ESC. Upgraded to the 100Amp car ESC and a straight change over to the 3648-1450 motor. All from Hobbyking. Good units and have no problems. Also a the price will not break the bank book!!! Note, change the uni-joint to metal as the plastic ones will not handle the power and break. Canabus
depending upon the type of motor cooling it can be a problem. Most brushless motors are out runners so the case rotates! In runners are usually for higher speed applications (or driving a gearbox). If you have an idea as to the size of IC engine the boat was intended to have then this list may be a help
.049 or .051 = 100 watts
0.10 = 200 watts
0.15 = 300 watts
0.25 = 500 watts
0.32 = 640 watts
0.40 = 800 watts
0.45 = 900 watts
0.51 = 1020 watts
0.61 = 1220 watts
0.75 = 1500 watts
0.91 = 1820 watts
Since Watts are Volts * Amps ( I know this is not accurate for a reactive load like an electric motor but its a rule of thumb)
This gives you a ball park next point is the KV ( revs per volt) of a motor. The higher the KV the smaller the prop. Finally buy a Watt meter they are not expensive and give you a chance to " fine tune" a setup.
Will need to put this on hold for a bit as I have just discovered a guy working in the next industrial unit to mine is into boating and has offered to give me a motor and ESC that he has 'outgrown'.
In the mean time I need to replace the propshaft as it is not man enough plus a metal U/J. Bit of hacking required.
