>> Home > Forum > Hobby Chit Chat! > What wood to use for a Boat Stand
(1110 views)
Forum Posts: 413
6th May 2016 22:26
mdlbt.com/21956
I'm presently using a boat stand made of foam. and its collapsing under the weight of my boat!
What wood should I use to make her Stand? and how should I go about it?
Thanks in advance!
ED-
7th May 2016 00:04
mdlbt.com/21958
HI Ed, your problems continue!!!! you need a contour plate, its got thin spines that slide to get a shape, once you have decided where to support the hull, to protect the prop and rudder, approx 1/3 2/3 bow to stern, take the plate and press the splines gently against the hull, this will give you the contour to draw onto stiff card, cut out and make a mirror copy, this will give you the template to mark onto your chosen wood, cut out with a bandsaw or a jigsaw.
I use 10mm plywood, with mahogany veneer, several coats of varnish, sanded between coats, with support rails between uprights, screwed and glued together.
Protect the hull with foam lagging. When cutting allow for the foams thickness.
Forum Posts: 413
7th May 2016 00:43
mdlbt.com/21959
Thanks Mark, Well appreciated advice one of my next projects is making a replacement boat stand for Serenity!
Forum Posts: 72
7th May 2016 13:20
mdlbt.com/21961
You might also want to try using a length of solder wire, instead of a contour gauge. It will follow the hull smoothly. It needs a little more care when tracing around it onto your template.
Kipper
Forum Posts: 20
8th May 2016 22:02
mdlbt.com/21984
If the boat was built from a plan, you could also use the appropriate bulkhead templates & allow for the hull thickness.
Forum Posts: 413
14th Jun 2017 12:07
mdlbt.com/30156
OK, I'm back to making the bow support for my boat stand!
No wood of fret saw to be had.
Eventually Serenity will have a proper boat stand made.
This time I cut out three pieces instead of two.
I will laminate them using contact cement.
Lets see how that goes.....
Forum Posts: 413
14th Jun 2017 12:58
mdlbt.com/30161
It worked with great success...👍
Forum Posts: 1793
14th Jun 2017 13:21
mdlbt.com/30162
Well done that man 👍
Maybe you could also stiffen it up by laminating some 3mm ply onto it?
BTW, just stumbled across 'My R&C Center'
Now I see where the nickname comes from 😉
