June 2018: 6 people
November 2017: 10 people
Active Users (8)
>> Home > Forum > Hobby Chit Chat! > JOINING BATTERY & RECEIVER CABLE
(519 views)
Les-Forbes
17th Sep 2017 19:23
mdlbt.com/33317
I want to cut the battery lead to my receiver in order to incorporate an on/of switch. Can I just join up the two new peices of wire with insulating tape. Will it matter if the two wires are slightly different thicknesses. I would use some sort of insulting tape to complete. Or would what I am contemplating doing, give me some big headaches at some point.
Forum Posts: 295
17th Sep 2017 19:38
mdlbt.com/33318
You would be better to solder and cover with shrink tube that would ensure problem free running. As to wire try to keep as near to original as possible. Good day Colin.
Wingcoax
Forum Posts: 15
17th Sep 2017 19:38
mdlbt.com/33319
Very likely to give you migraine. visit your local model shop or look online for the correct switch harness to match your radio gear, that way the plugs will match.
Forum Posts: 1679
17th Sep 2017 21:23
mdlbt.com/33321
Hi Les, if you can't solder DON'T CUT ANYTHING! How would you want to connect the switch anyway?
What you need is this
http://www.componentshop.co.uk/jst-male-female-with-on-off-s...
I don't recommend insulating tape for anything on a model boat! After a while the glue leaches out and makes everything sticky 😡 --> Emergency repairs only !
If you do cut wires and insert a switch Colin is quite right; soldering and heat shrink sleeve is the way to do it. Wire at least same thickness as the original. You would only need to cut the red wire anyway.
But much easier to use the switch above and the existing plugs. Don't cost the earth.😉
PS What a difference one little letter can make! Would love to hear what 'insulting' tape has to say for itself 😉
Les-Forbes
18th Sep 2017 16:10
mdlbt.com/33356
Ah Insulting Tape. LOL. That's for Donald Trump. I think I may have ordered the wrong switch fitting. I thought they were all the same. But the one I received does not fit the receiver, its a tad too fat. Perhaps I can return it for the correct fitting. Problem is I not at all versed in the various pugs types and associated names for them.
You have been courageous in stopping me kill this little bit of apparatus. Not wishing to waste my time on this murder, I applied two new transfers to the little Proboat Westward 18 in preparation for its initial sail. I have three ponds I can go to, Knightswood Boat Club, Elderpark Boat Club and Richmond Park Boat Club. All within fifteen minutes drive of me. The suspense is killing me. Thanks again.
Forum Posts: 1679
18th Sep 2017 16:34
mdlbt.com/33357
Hi Les, then I assume that you need something like this harness with JR/Hitec male & female plug/socket. This one also has a third plug for connecting the battery to a charger when the switch is in the off position.
DON'T use this feature if you are using a LiPo battery!!
There are several other versions without this third plug available here
http://www.componentshop.co.uk/futaba-charging-switch-harnes...
I guess the RX battery is a fairly small NiMH and also has the JR type plug.
BTW: something to check before switching on-
Does your speed controller have a BEC circuit? If so it supplies the RX as well so you don't need an RX battery at all.
Or doesn't your yacht have any auxiliary motor and ESC?
Happy sailing, Cheers Doug 😎
Looking forward to the video of the insulting tape 😁😉 or is that what I keep seeing on the news with Mr T??
