September 2017: 6 people
Active Users (27)
>> Home > Forum > Hobby Chit Chat! > Clamps and such
Clamps and such
(712 views)
Forum Posts: 130
2nd Jan 2018 13:58
mdlbt.com/37067
Please post pictures of clamps and fasteners you use to hold parts, hull joints, while glue is setting up.
2nd Jan 2018 17:38
mdlbt.com/37070
Hi Ron
The latest method I have seen uses Neodium magnets. You use a flat sheet of steel as the base and triangular shaped pieces of 3/4 inch ply in which the magnets are sunk into and glued.
The magnets come in various sizes but are very strong and do clamp well. For hull work you can use two magnets, one on each side of the part that needs holding.
I used cocktail sticks to hold the planks on my schooner-you drill a small hole at each former and tap in a glued stick. Once dry you can sand flush. If you don't want anything to show make your own pins from a plank offcut.
Happy New Year
lesfac
Forum Posts: 28
2nd Jan 2018 18:43
mdlbt.com/37073
I found scrunched up aluminium foil worked well to hold parts in place while i soldered them. The aluminium doesnt take solder readily. It would also work for gluing if you are careful not to glue the parts to the foil
Les
Forum Posts: 130
2nd Jan 2018 21:49
mdlbt.com/37079
Alligator clamps, small woodworking clamps?
Forum Posts: 1497
2nd Jan 2018 22:11
mdlbt.com/37081
Hi Gramps 😉
So far we're a bit Off Track! 🤔
I'll photo tomorrow a selection of what I use, including a good quality masking tape or similar! As Dave says Neodymium mags are also good for some items but I've never tried 'em for hull planking.
I use a variety of types and sizes of wood clamps from traditional G clamp screw types to the spring loaded type (what you call alligator clamps?), even various sizes of Bulldog clips for smaller items.
More tomorrow, cheers Doug 😎
Forum Posts: 1497
2nd Jan 2018 22:30
mdlbt.com/37085
PS: for soldering I use a small machine vice (Proxxon or similar) or jigs cut into close grained wood blocks with masking tape to hold parts down; e.g. for railings or complex mast and crane jibs etc. Doug 😎
Forum Posts: 287
2nd Jan 2018 22:47
mdlbt.com/37087
Alligator clamps better known as crocodile clips.
Forum Posts: 1497
2nd Jan 2018 23:22
mdlbt.com/37088
Aha! Metal and much smaller than the spring clamps I mean. Pics tomorrow.
Sometimes use croc. clips as heat sinks when soldering small parts.
Time now to go 'Up the apples and pairs to Bedfordshire' 😉
All the best Doug 😎
Forum Posts: 130
3rd Jan 2018 01:12
mdlbt.com/37091
Clamps like these...easily slip off, but it’s all I have, other than tape.
3rd Jan 2018 16:14
mdlbt.com/37102
Hi Ron
I forgot you build small models in balsa. My choice would be elastic bands 1/4" wide as used to hold the wings on model planes or similar.
Protect the open bottom with a solid plank and wrap the bands all round every few inches. Get some scrap balsa and put between the band and hull planks, add just enough to hold the joint. Leave to dry then remove and get a box to keep your bands etc for next time.
On larger models I have used luggage straps tied to length and packed with scrap wood.
Very good for holding planks etc on hulls as the bands/straps can be made with the packing to give pressure in more than one direction at the same time.
KenThompson
Forum Posts: 45
4th Jan 2018 15:04
mdlbt.com/37116
Don’t forget the old cloths pegs.
Clips on trousers cloth hangers,bull dog clips,all different sizes,elastic bands are useful too. To name just a few ideas.
May the wind always be always where you want it .
Forum Posts: 130
5th Jan 2018 00:17
mdlbt.com/37122
Ken please post pictures of these clamping ideas. You builders in the UK haveterms of things that are different than us in Canada. Such as theearlier post on Baseboards. Here in Canada baseboards are what is found along the bottom of a wall, an architectural trim. Thanks.
Forum Posts: 287
9th Feb 2018 12:51
mdlbt.com/38425
A selection of the clamps I use. I have at least ten of each type and size.👍
Forum Posts: 1497
9th Feb 2018 13:15
mdlbt.com/38428
Hi Colin, could be photos of my selection 👍 apart from the wooden ones! Home made or Granddad's? Cheers Doug 😎
Forum Posts: 287
9th Feb 2018 13:21
mdlbt.com/38429
The wooden set are original cork faced cabinet makers clamps I bought when I was an apprentice about 50 years ago. Have only had to once replaced the faces.👍
Forum Posts: 1497
9th Feb 2018 13:28
mdlbt.com/38430
Great idea! 👍
I have several of the type at the bottom of your first photo, some up to about 15" Could mod a couple with wood and cork 😉
