259
11
ยฃ10
ยฃ15
ยฃ50
ยฃ5
ยฃ10
ยฃ15
ยฃ20
    Page 1 of 117
    Sub dive system.
    Hi Peter, "I am slowly being swayed towards a gas system where the water is pumped in and whilst being pumped out, the gas bottle replaces the air. This will enable a deeper dive than periscope depth. You just have to avoid running out of air." Hmm! Must admit I also once considered experimenting with something like Sparklets bulbs. But they are very difficult to control. How often have you sent the soda down one side of the glass only to see the whisky shoot out of the other side?๐Ÿ˜ญ Also they run out! Not to mention all that CO2 release to the atmosphere - Bad Footprint๐Ÿ˜ฎ I concluded it was best to leave that to less critical things like experiments with torpedoes. A 'gas tank' per se would be very heavy. One of several reasons that I opted for the Akula with a piston / tank solution. Cheers, Doug ๐Ÿ˜Ž
    1 hour ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    14 hours ago
    1 hour ago
    Motor reversing
    Hi again Peter, Here you can find the very latest rules and regs! Cheers, Doug https://www.ofcom.org.uk/spectrum/radio-spectrum-and-the-law/licence-exempt-radio-use/licence-exempt-devices/Radio-controlled-models
    2 hours ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    2 hours ago
    futaba radio and receivers
    hi my first time asking question to you guys.... have been reading different forum and not sure if i should just ask this question on one of them or start a forum, so i will not bother anyone unnecessary question futaba radio and receivers 3PM-X FASST 2.4GHz d 3-Channel 2.4GHz Computer Radio, came with a futaba 203GF Receiver. has anyone bought an other receiver not a futaba and it worked... looking around to see prices, and there are some less $$$ one but do they work with a futaba RADIO THAT IS FASST... it was not a expense radio set want to have several receivers in several model boats instead of switching them are.every time i want to run a boat... has anyone out there ever run into problems or is there a problem with any of the FASST type of radio set... thank you
    3 hours ago by ๐Ÿ‡บ๐Ÿ‡ธ samc ( Leading Seaman)
    3 hours ago
    by samc
    Visiting European Model Boat Shows
    Genau Ian ๐Ÿ˜‰ TX in right hand, Bierkrug oder Weinglas in left hand! Model boater's heaven ๐Ÿ˜Š I'm usually sat on that right angled bend under the tree at the edge of the Biergarten. Prost!
    3 hours ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    11 hours ago
    by ikseno99
    3 hours ago
    Boat retrieval
    That sounds really weird John.๐Ÿค” Like Identity Hijacking ๐Ÿ˜  Cheers, Doug ๐Ÿ˜Ž PS "good handy women are few and far between" True, nevertheless I always like to keep a good woman handy!๐Ÿ˜‰
    7 hours ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    7 hours ago
    Port/ starboard socks.
    That's extremely kind of you Nerys, thank you very much๐Ÿ˜Š A PM is on it's way to you shortly. If you have sound switched on on your 'device', PC or whatever, you should hear a SONAR Ping when it arrives. Thanks again, Doug ๐Ÿ˜Ž
    12 hours ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    by KenThompson
    12 hours ago
    Direction Finder
    Looks good to me Ian ๐Ÿ‘ Like an ADF searching for a navigation beacon. DG is correct, it wouldn't continuously rotate on a civilian ship using RDF for navigation purposes. I.e. looking for a specific NDB (Non Directional Beacon). On a warship in the old days it might rotate if the set was being used as a Search receiver. Nowadays the antenna for such purposes does not rotate. Instead a fixed multi-element antenna is used and the detector receiver plots the progress of the RF wavefronts across the elements. Thus deducing where the signal came from. So I reckon your setup looks pretty convincing for an older model DF set Cheers, Doug ๐Ÿ˜Ž
    1 day ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    by Elsrickle
    Mixing throttle and rudder
    Having read somewhere on this site ( I canโ€™t find it now!) that turning a 34โ€ crash tender at speed can be a problem I have been thinking about ways to Reduce the risk. The obvious way is to pilot it carefully, turning gently, or slowing before turning sharply. But that requires the pilot to be paying attention. Iโ€™m not sure my young grandson would take that care, even if I do. So, is it a good idea to mix throttle and rudder to overcome this issue. It seems to me there are two options: 1. Reduce the rudder throw based on the throttle setting. i.e. mix such that as the speed increases, the maximum rudder throw reduces. Or 2. Reduce the throttle based on the rudder demand. i.e. mix channels so that the boat automatically slows based on the rudder demand. I havenโ€™t found any reference to this on this website, which make me think it isnโ€™t a good idea, but I would be interested in any thoughts from those with much more experience than I have. Also, can these mixes be set up on an fs- i6x transmitter?
    2 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Graham93 ( Leading Seaman)
    by Graham93
    Recognise this boat ?
    Heartily agree DG๐Ÿ‘๐Ÿ‘ All too often we see queries with very little corroborative info, pics etc. The info we need to be able to help we often have to extract bit by bit๐Ÿค”. Cheers, Doug ๐Ÿ˜Ž
    2 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    by Tall Paul
    Need to change web site address of CLUB
    I know! I tested it first ๐Ÿ˜‰ Cheers, Tall-ish Doug ๐Ÿ˜Ž
    by Tall Paul
    Pond Weed
    Thanks for posting about pond weed control. Biological Control .. best seems to be Grass Carp reported to eat the weeds, we are still investigating. Chemical Control... not allowed to use herbicide as our pond is linked to the River Itchen. However we do use Barley straw extract to control algae. Mechanical Control ... motorised cutters etc are far to expensive and you still have to rake up the cut weeds. In the end throwing a rake out or placed behind roots by guy in a boat and pulling it in is the best solution for us, so far. one in the boat, two each with a rake and barrow. we cut and collected barrow fulls. We continue to use Pond Dye (see biofix and dyofix.co.uk) other shading can be obtained by planting willow trees. Weighted black polythene sheets for 6 months at a time has been suggested as has solar powered fountain or air pumping air bubbles as this reduces infestations and oxygenates the water. Regards, Tall Paul.
    2 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Tall Paul ( Petty Officer 2nd Class)
    30 days ago
    by Tall Paul
    by Tall Paul
    Help identifying this model boat
    Hi Norm, being as how you're in the US and I'm in Oz I reckon it is not much use me recommending a local Oz sail-maker. From what I can gather from other fora (like that? My high school Latin does get some use) in the US a pretty good maker seems to be Carr Sails http://www.carrsails.com/ I am guessing that the cost of a set of sails for your yacht would be similar to those quoted for the Bearospace 'ANNIE'. $225 may sound like a lot but, from what I can gather, his sails are pretty well at the top of the pile. Check with a local sailing club, there are heaps of people around that make their own sails as well as lesser known sail-makers. The club may be able to point you in the right direction. Unashamed plug for the Bearospace range of boats - I have no financial interest. There is a lot of info in these blogs to assist in building and making parts for semi-scale sailers : https://www.rcgroups.com/forums/showthread.php?2990671-Bearospace-Sloop-EMMA https://www.rcgroups.com/forums/showthread.php?2550991-Bearospace-schooner-Irene https://www.rcgroups.com/forums/showthread.php?3294855-Bearospace-Schooner-Annie I hope this can help you. Cheers from Down Under, Terry
    3 days ago by ๐Ÿ‡ฆ๐Ÿ‡บ terrymiff ( Able Seaman)
    by ginkgo
    by terrymiff
    Propeller direction.
    "Trading in pork bellies futures began in 1961 on the Chicago Mercantile Exchange (CME) and allowed meat packers to hedge the volatile pig market." https://www.investopedia.com/terms/p/porkbellies.asp Place your bets here Gents๐Ÿ˜‰ https://www.barchart.com/futures/quotes/PBY00/overview Pass the pork belly slices and black eye peas please๐Ÿ˜› Eggs and bacon anybody? ๐Ÿ˜‹
    3 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    Martin Westquay's Piper Cub ;-)
    Now you tell me - thought floats were more prevalent from what my pal said. He used a Beaver mostly though, DH of course - not the dam builder with big teeth ..........
    3 days ago by ๐Ÿ‡ฟ๐Ÿ‡ฆ redpmg ( Chief Petty Officer 2nd Class)
    What could this Hull be for?
    Picked up his kit same place as I did - fellow who made them was not intending to sell them - reluctant in fact . Mine is his 3rd attempt I believe - cant check now as he is no longer with us . Think his wife persuaded him to sell them. He was experimenting with molding hulls etc. Think the last one was the one he used for himself. We do some forming with 2mm Perspex - failure rate is about 10% no matter how careful you are so understand why he made a few. The hull is about 2 mm finished size - the superstructure a lot thinner and styrene - not certain but think the hull is ABS. Very few Breede kits around - not sure you can even get a hull anymore - and the plans are no longer available from RNLI.
    3 months ago
    by jelley_baby
    USCG Sprinkles in Action
    Hi Commodore, As already posted in response to your Media Gallery post- "Sorry Commodore (!) That won't work ๐Ÿค” You have to put the video up on YouTube first and then post the link here. Doug ๐Ÿ˜Ž " You can't upload video here directly. This is to prevent the site server getting swamped with GBs / TBs of video data. Doug
    by Commodore-H
    PS Waverley info...
    Thanks, Marky, I'll have a butcher's at the website when I start to finish the model. Cheers, Martin
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Westquay ( Commander)
    by Westquay
    by Westquay
    Skipper and mate.
    We'll expect a full report of proceedings Ken ๐Ÿ‘๐Ÿ˜‰
    5 days ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    by KenThompson
    Batteries in a DX5e
    No worries mate !
    5 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Midshipman)
    by Westquay
    Hope this posting works. It's a short video. Too hot to go out today Rotating beacon is R/C car accessory. Radar is modified servo. Water monitor is scratch built with cheap pump from ebay. Draws water from outside boat . Turns with servo. Searchlight scratch built with ultra bright led.
    6 days ago by ๐Ÿ‡บ๐Ÿ‡ธ Commodore-H ( Petty Officer 2nd Class)
    by Commodore-H
    Video chat / Roving Reporter - "Does the site have a Youtube Channel?"
    Hi Folks, As a spin off following on from the hijacked ๐Ÿ˜Œ Batteries for DX5e thread from Martin W! If anyone has any further thoughts for a possible Video Chat link up and/or Roving Reporting from Club Events etc please feel free ("If you want to go any further it'll cost you"๐Ÿ˜‰ as the actress said to the bishop๐Ÿ˜) to add them here. Thanks. Cheers, Doug ๐Ÿ˜Ž
    Turnigy A-6-10 200W Balance charger & discharger
    Not surprised Michael. Like I said I only bought it cos I have a large collection of batteries of all sorts of types and sizes and I wanted to be able to take better care of them. The Polaron stores parameters for the various types and has a USB data port to export the results to the PC. Still learning how to use that to create a Battery Data Log ๐Ÿ˜‰ You should be able to find one of the little Robbe or Graupner jobs on the Fleabay, or there's always Turnigy & C. Happy charging, cheers, Doug ๐Ÿ˜Ž
    by mturpin013
    Model boat show
    Hi all, just to let you know,, Saturday 13th July. At the Cold Knap in Barry, Glamorgan,South Wales. If your in the area, drop in and have a look, bring a boat, have a sail. Runs from 10am till about 4pm. The weather looks good too.
    7 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง KenThompson ( Chief Petty Officer 1st Class)
    by KenThompson
    Moronic Hydra 50 speed controller
    Iโ€™m very pleased, and grateful
    7 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Brianaro ( Petty Officer 1st Class)
    Sailing, model or the real thing.
    Very light gopro copy from Aldi. Slowed it only a little.
    8 days ago by ๐Ÿ‡ฆ๐Ÿ‡บ juskiddin ( Leading Seaman)
    by Nerys
    by juskiddin
    Alwyn Vintcent Steam Tug
    Brilliant work!
    8 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Midshipman)
    2 months ago
    Caldercraft Clyde Puffer Motor and Prop - Help Needed
    After doing a bit more searching found this. Would it work? https://www.ebay.com.au/itm/1pc-R385-DC-6-12V-6500RPM-Long-Life-Carbon-Brush-High-Torque-Motor-for-DIY-Model/223269629521?hash=item33fbe82e51:g:GtsAAOSwsGpb91Nx
    9 days ago by ๐Ÿ‡ฆ๐Ÿ‡บ juskiddin ( Leading Seaman)
    by juskiddin
    by juskiddin
    Help identifying
    Finally got the boat going and learnt a big lesson. I was using a prop shaft the telescopes and it did. With the motor running hard I think I hit some weed which caused the prop to have extra pressure on it. The shaft then collapsed in from the added pressure and I lost all propeller thrust. Could hear the motor revving and no motion. Had to be rescued by a model sailing boat!
    4 months ago
    by juskiddin
    by juskiddin
    Where did this photo come from?
    thanks all working good for me
    10 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง jacko ( Chief Petty Officer 2nd Class)
    by rossiter
    by jacko
    Plan For Princess Elizabeth Paddler
    Hi Doug, unfortunately even Barry the last editor of MMI could not help - not one of their plans - only available from Richard direct . Family did not seem to value his stuff too much.
    10 days ago by ๐Ÿ‡ฟ๐Ÿ‡ฆ redpmg ( Chief Petty Officer 2nd Class)
    Page 1 of 117
