264
10
Β£10
Β£15
Β£25
Β£50
Β£5
Β£10
Β£15
Β£20
    Page 1 of 103
    EeZeBilt RAF Crash Tender trial video
    Hi Red, You are thinking of the Wilhelm Gustloff. Sunk by the Russian submarine S-13 while evacuating civilians and wounded soldiers from in front of the Russian advance on East Prussia. https://ww2db.com/ship_spec.php?ship_id=504 This is certainly not forgotten here (Germany) and often features in TV documentaries. Titanic is probably so remembered because of all the hype around her and the fact that it was the first time radio was significant in the rescue of survivors. It also led to the first drafting of the obligatory SOLAS regulations including constant manning of radio stations on board - Safety Of Life At Sea. Now incorporated into the GMDSS regulations for carriage of safety equipment on board (including radio requirements) - Global Maritime Distress and Safety System. Whereas the Gustloff 'incident' was 'just' one more ghastly event in a ghastly war. Cheers, Doug 😎
    55 minutes ago by πŸ‡©πŸ‡ͺ RNinMunich ( Fleet Admiral)
    7 hours ago
    55 minutes ago
    Upload problem
    Thanks for that
    2 hours ago by πŸ‡³πŸ‡Ώ jbkiwi ( Chief Petty Officer 2nd Class)
    2 hours ago
    Humbrol paint colours for smit zweden tug
    My apologies I don’t think I wrote the post right in the first instance I was wondering if any one had built one and had the colours that it should be yeah I appreciate I can just pick the colour from the chart which I don’t mind doing myself just wondering if anyone had the right colour.
    6 hours ago by πŸ‡¬πŸ‡§ georgeo5664 ( Petty Officer 1st Class)
    7 hours ago
    by georgeo5664
    6 hours ago
    by georgeo5664
    LiPo batteries
    It is almost 9 months since I charged the new LiPo batteries for storage. Unfortunately I still have not used the 4s 4500 batteries since then but I do check them every 4 months to see how they are. They have been good so I have not had to do anything with them. I decided on this visit to replenish the storage charge on all of the batteries. I was shocked to find out that all of the batteries were almost perfect with only a few minutes of charging required, but the two 4s batteries, the oldest, did not take a charge at all. They are still very good. I will use them when I return here in August.
    19 hours ago by πŸ‡¬πŸ‡§ MouldBuilder ( Chief Petty Officer 1st Class)
    1 year ago
    19 hours ago
    Tug towing
    Hi George, Yes. I ran mine on 12V without problems but not all day long at full bore!πŸ’₯ Remember, even if the batt attached to the ESC is 12V you are not always applying the full 12 to the motor. (Or are you?πŸ˜‰ A 'pedal to metal' kinda guy?) Even at full bore the supply voltage to the motor is pulsed by the ESC so the average V applied is less than 12V. Just in case start with a 7.2 / 7.4V accu (NiMh 6 cell / LiPo 2S). You should be able to go to 9.6V (8 cell NiMh) without problems. Check the motor temp with your finger tips on testing. If you can keep your digits on the motor without screaming you're OK😊 As said by others as well; I'd take a long hard look at the prop and shaft alignment as well. Dodgy's tip with the spring balance pull testing is good too. I've been doing that using a redundant fish scale. Gives a good (if relative) indication of push and pull. I also use a little Wattmeter as well. Useful for initial shaft alignment. Twiddle things around until the motor runs sweetly and the Wattmeter shows the minimum current. Before each test use a little accu capacity meter to make sure the accus are up to scratch and the playing field even for each test. Pics show the ones I use. Available all over the shop, e.g. FleaBayπŸ˜‰, for peanuts. Black one is checking an NiMh, white one a LiPo. Happy tugging. Doug 😎
    19 hours ago by πŸ‡©πŸ‡ͺ RNinMunich ( Fleet Admiral)
    by georgeo5664
    19 hours ago
    Motor, speed controller
    Hi Dodgy, "P.P.S. You might want to consider a clover-leaf aerial. That enables what they call 'circular polarity' transmission, which is really useful for drones when the transmitting aerial is performing contortions in the air. For boats, a vertical aerial pumping out vertically-polarised waves may suffer from 'bounce' off the water surface, which turns the reflected waves horizontal. But these are very cheap anyway, and can be experimented with" Yes I'd noticed the clover leaf. Not the most efficient antenna but agree it's a nice compact design. Agreed the reflections can cause some polarisation distortion. A vertical antenna (properly earthed) also produces a ground wave propagation which travels especially well over water, but admittedly not so long range at 5.8Gigs. Works best at lower frequencies where the absorbtion rate in water is lower. Those operating in salt water lakes on the coast are better off in this respect than us fresh water sailors! So I was thinking of using antenna diversity, one vertical and one horizontal. Just like most 2.4Gig TX/RX sets already do. A vertical stub antenna at the top of the TX case and a horizontal antenna in the handle usually. Of course if you hold the TX flat on it's back then you are relying on the horizontal antenna component!! At the RX end two 12,5cm wires, one vertical, one horizontal is the counter part. Works well in my Sea Scout. For 5.8 Gigs the wavelength is a little less than half that at 5.1688cm so the clover leaf is a reasonable compromise. Didn't spend my professional life working on all types of radio systems, from VLF/HF through personal mobile and cellular systems up to full COMMS suites with datalinks on naval vessels for nuffink. Some of it stuck! πŸ˜‰ Having successfully hijacked Ken's thread (Sorry Ken😭) I guess we should continue this discussion (if required) in a new thread! Cheers, Doug 😎
    21 hours ago by πŸ‡©πŸ‡ͺ RNinMunich ( Fleet Admiral)
    by KenThompson
    21 hours ago
    CNC boat kits...?
    Sounds like you might not have been waiting long enough for the Arduino to boot and load GRBL, so the port refused to connect, and then just stayed 'busy'.... If it happens again, try opening and closing another port, and then going back to 8. That seems to reset the flag...
    24 hours ago by πŸ‡¬πŸ‡§ DodgyGeezer ( Chief Petty Officer 1st Class)
    4 months ago
    24 hours ago
    Unsubscribe
    In your My Account page you can turn off all notifications. If you want to close your account completely, please use the support page. Thanks
    1 day ago by πŸ‡¬πŸ‡§ Fireboat ( Warrant Officer)
    by oldaljones
    by Fireboat
    Fatal Error - Half my Profile is missing! ;-/
    Muchas graciasπŸ‘ Hope you managed to enjoy the Bank Holiday and could let the grey cells cool down a bitπŸ˜‰ BTW: Dodgy's query reiterates the need for the Forum Categories! Keep on coding man😁 All the best, Doug 😎
    1 day ago by πŸ‡©πŸ‡ͺ RNinMunich ( Fleet Admiral)
    RC Model Shark
    The fin does submerge due to the fact that it's hollow and there is a square cut out near the top that is camouflaged with screen painted at the same time as the fin.
    2 days ago by πŸ‡¨πŸ‡¦ Alex ( Able Seaman)
    5 years ago
    by CraigRobotham
    by Alex
    Look for a simple balsa build
    "..... EezEbilts are all relatively easy to make even if there are a few minor errors which are so easily correctable......." Since they are intended for beginners, ANY problem needs to be looked at. If it's a problem with the plan then I need to correct it - if it's a problem with the user not understanding something or getting it wrong, then I need to change the instructions or some other aspect of the plan to avoid the problem in the future. The boats are intended to encourage modellers by helping them get a boat right first time. It says a lot for GMan's perseverance that he is still looking for a model to build after some initial frustration, no matter how it was caused...
    by gman3000
    Happy Easter Everyone! 🐣
    Thank you and to you too
    3 days ago by πŸ‡ΊπŸ‡Έ Puddle-pirate ( Leading Seaman)
    by Fireboat
    by Puddle-pirate
    3000mah 6 cell lipo's
    Selling as part of estate, These are Turnigy 3000mah 20-30c discharge 6 cell packs.. All are in storage mode and have been well cared for. Β£15 each is a bargain, there is one with damaged heatshrink, cells are fine, no puffing, but that is Β£10 due to damage, or Β£60 for all of them in one go! posting lipos is very difficult, if you want them posting I will do it at cost, but if the package is opened, and they are destroyed, its your risk, no refunds, collection preferred. If you are going to Hooton show, Im not far away north Wirral
    3 days ago by πŸ‡¬πŸ‡§ pmdevlin ( Sub-Lieutenant)
    8000mah 6 cell lipo as new
    Selling as part of estate,. This is a 6 cell Turnigy Nano-tech massive 8000mah! 25 to 50c discharge. As you can see, the tag is still on the leads, its well cared for, no puffing, and is in storage mode, The plane this was for was never flown and was unfinished, so I doubt this has ever been used. These are very expensive, well over Β£60 each plus postage, Ill offer this for Β£30 ono. Posting lipos is very difficult, I can use my hermes at cost which would be confirmed but its approx Β£6.00 due to weight, but it the package is opened, and the lipo is destroyed its your risk, as you are not supposed to post lipos, so collection is preferred.
    boat building jig
    Hi all, for the second time, Im disposing of a deceased estate. The chap was rc planes and helis, but, he was also building a boat for his wife as a present. I have taken on finishing the boat, but this appeared, I found the details here https://www.alwayshobbies.com/tools/workshop-organisers/hobbyzone-professional-building-slip-for-model-ships So based on the price of Β£50 plus postage new, I would offer this for Β£20. Its a very comprehensive jig, so must be worth that, and I need to sell it quick. Proceeds are returned to the widow. I live North Wirral, so if you are going to the Hooton show its not far to pick up. I can post at cost, but the base board is heavy so collection is preferred. Cash or paypal, but if you want it saving for a few weeks then I must ask for payment in full immediately.
    Plan Sources
    There are few of us prepared to put that amount of work in. Well done!
    Seaplane tender
    bits of information coming in now, excellent.
    4 days ago by πŸ‡¬πŸ‡§ SelwynWilliams ( Chief Petty Officer 2nd Class)
    by SelwynWilliams
    by SelwynWilliams
    Model Boat kits
    The post above is there actual website. This is for you RC's. Ahhoy
    4 days ago by πŸ‡ΊπŸ‡Έ retirement-hobby ( Petty Officer 1st Class)
    by retirement-hobby
    by retirement-hobby
    Noodle Jet Boat
    "........there isn’t a huge amount of swivel on the buckets, was thinking of putting a mixer in rather than a rudder?, I suppose it’s just trial and error.... ...." If you put a small 'dagger plate' on the keel, like the power racers do, that will improve the turning no end....
    4 days ago by πŸ‡¬πŸ‡§ DodgyGeezer ( Chief Petty Officer 1st Class)
    by Shopper
    Editing photos
    7 days ago by πŸ‡¬πŸ‡§ DodgyGeezer ( Chief Petty Officer 1st Class)
    Big Blue (test facility)
    Thats slick!πŸ‘
    7 days ago by πŸ‡ΊπŸ‡Έ Cashrc ( Leading Seaman)
    by Cashrc
    Propellors
    9 days ago by πŸ‡¬πŸ‡§ John2 ( Chief Petty Officer 1st Class)
    by Alan999
    by John2
    Swordsman or Huntsman?
    9 days ago by πŸ‡¬πŸ‡§ ChrisF ( Petty Officer 2nd Class)
    by billhook301
    by ChrisF
    posting problems
    Me too😭
    9 days ago by πŸ‡©πŸ‡ͺ RNinMunich ( Fleet Admiral)
    POSTING PROBLEM!
    10 days ago by πŸ‡¬πŸ‡§ Brianaro ( Master Seaman)
    by figtree7nts
    Ballcap!
    11 days ago by πŸ‡ΊπŸ‡Έ figtree7nts ( Commodore)
    by figtree7nts
    Thames Barge Plan Kitty
    11 days ago by πŸ‡¬πŸ‡§ TOWN3810 ( Leading Seaman)
    by wmbc40
    by TOWN3810
    Veronica
    12 days ago by πŸ‡¬πŸ‡§ Shopper ( Master Seaman)
    by KenThompson
    by Shopper
    Model boat w gas motor/nitro
    12 days ago by πŸ‡¬πŸ‡§ Haverlock ( Sub-Lieutenant)
    by Aekaraaek
    by Haverlock
    13 days ago by πŸ‡ΊπŸ‡Έ retirement-hobby ( Petty Officer 1st Class)
    18 days ago
    by retirement-hobby
    by retirement-hobby
    Page 1 of 103
