258
11
ยฃ10
ยฃ15
ยฃ50
ยฃ5
ยฃ10
ยฃ15
ยฃ20
    Save £50 when you join Bulb
    Page 1 of 118
    Night Watch
    Happy Birthday Doug - hope there are many more - spring chicken you are still ..... That is compared to some of us...........
    28 minutes ago by ๐Ÿ‡ฟ๐Ÿ‡ฆ redpmg ( Warrant Officer)
    28 minutes ago
    Movies.
    How about "The Eye of The Needle" - Where the "Nadel" is landed by an Eboat in the Essex? marshes - the Eboat looked suspiciously like 102...... Brilliant acting by Donald Sutherland as usual - but the fake start rather spoilt it for me .......... Bit like seeing a pair of machine guns being fired by a Piper Cherokee 180 pretending to be a Messerschmidt 108 Taifun.
    31 minutes ago by ๐Ÿ‡ฟ๐Ÿ‡ฆ redpmg ( Warrant Officer)
    31 minutes ago
    Happy birthday Admiral
    Happy birthday Doug ,raise a glass or two of the Amber nectar all the best .๐Ÿฅƒ๐Ÿฅƒ Cheers Marky
    2 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง marky ( Lieutenant)
    4 hours ago
    by Colin H
    2 hours ago
    by marky
    Chris Craft Cobra by Dumas
    Nice work, keep it up. Martin555.
    4 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Commander)
    by JackJustis
    4 hours ago
    More boat chat
    Drone Martin,!? can you put that in the aircraft section please๐Ÿ˜๐Ÿ˜Š?
    10 hours ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Lieutenant)
    10 hours ago
    Workshop
    Absolutely Nerys๐Ÿ‘ many of my (former) customers wanted to use these things on HF, mostly from aesthetics or stealth (๐Ÿ™„) aspects. Er! Efficiency? Wossat? ๐Ÿ˜‰ They're not actually designed for transmission! Unless the circumference is a significant proportion (>30%) of the wavelength to be transmitted. Even then, put significant power into it and you risk burning anyone near it! Put just a few watts RF power into a small loop antenna and you get kilovolts on the antenna terminals, that's cos the TX current in the antenna is so high. So it needs a large expensive resonating capacitor with a very high breakdown voltage and low dielectric loss. What you have there looks more like a DF receiving antenna to me. I trust it is rotatable cos it's propagation/reception characteristic will be two main lobes 180ยฐ apart on the axis through the centre of of the circle. You mention "frequencies it's designed for", what frequencies are you using it for? I assume shortwave. Surprised that you have interference from ASDL! Although I realise that ASDL uses frequencies from 26.075 Megs upwards to 137Megs for the Upstream communication ASDL connections are usually screened underground cables which shouldn't bother you!? Unless there's a fault in the cable or your local distribution box๐Ÿ˜  I only came across such loops (or more usually rectangular frame antennas) on board ships as an attempt to reduce the radar signature. Unfortunately at the expense of COMMS efficiency. โ˜น๏ธ Cheers,Doug ๐Ÿ˜Ž
    12 hours ago by ๐Ÿ‡ฉ๐Ÿ‡ช RNinMunich ( Fleet Admiral)
    12 hours ago
    Glasgow transport museum
    Just spent a brilliant day at the Glasgow transport museum and kelvin grove art gallery,the ship models are incredible,difficult to take pictures through glass will try to make them better with photo shop .one of the magnificent models was of the Imperial Russian yacht Lavadia built by John Elder &Co at Fairfield shipyard.these models need to be seen to be believed if you need insperation and your near Glasgow pop in you won't be disappointed.
    16 hours ago by ๐Ÿ‡ฌ๐Ÿ‡ง marky ( Lieutenant)
    16 hours ago
    by marky
    Fishtailing
    Hi Doug, I found that when I went to play it windows media player says it's got an extension (.mpg4) which it doesn't recognize but will still play it. Probably a basic or older version of WMP although I've found that problem now and again for years. My TV satellite receiver records in an odd format (TS) so I had to get a converter app for that (along with an FLV converter) My new-ish HP Pavilion 23 -Windows 8.2- converted all my MPG movies from my 2TB external HD- previously from Vista, into FLV format without being asked to, when I first plugged it in๐Ÿ˜ ๐Ÿ˜ ??). Pain in the butt having to convert things, don't know why the world doesn't standardize, would make life simpler!
    20 hours ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Lieutenant)
    30 days ago
    20 hours ago
    Low pressure multi angle clamp
    Hi Guys, Many times I have had to clamp something but unable to get the angle I wanted. So I have come up with this idea. I don't know if it Will work as I have not got anything to make it with at the moment. The idea is you make a frame around the object using different length pieces of frame at different angles and tighten the frame using bolts and wing nuts tightly. Then use a long bolt to clamp the object. Using a combination of lengths , bolt holes ,and angles it should be possible to clamp most things. Hopefully. Martin555.
    2 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Commander)
    Posting updates on Model Boat Clubs and lakes
    Thanks for your help - it is much appreciated
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง ads90 ( Chief Petty Officer 2nd Class)
    by ads90
    by ads90
    Hints and Tips.
    Very good tips Fred, thank you. Martin555.
    4 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Commander)
    3 months ago
    Plans for Mississippi paddle Steamer
    Hi Nod, Welcome aboard ๐Ÿ˜Š You can buy a set (10 sheets) here, ain't cheap though ๐Ÿค” https://www.modelerscentral.com/plans/mantua-ship-plans/ship-model-plans-mississippi/ But probably worth it to get a โ‚ฌ473 kit right! https://www.modelerscentral.com/ship-model-kits/mantua/mississippi-river-steamboat/ Good luck, Doug ๐Ÿ˜Ž
    by Nod
    46" RAF Crash Tender
    Looks very good, and it's 'authentically positioned' too. I'm sure that the 'why is it offset' question will crop up from time to time from admirers so be prepared to tell them the reasons ๐Ÿ˜€. Keep up the great work. Robbob.
    5 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง robbob ( Captain)
    2 months ago
    by MaggieM
    by robbob
    EeZeBilts From Keil Kraft
    Here is a Shapeoko 2 - my eShapeoko is a similar machine - cutting steel. You will see that you need a decent spindle motor, which is not surprising. But the framework is adequately rigid. I have over-specced what I have to allow for expanding for future use. I would not be surprised to find that a machine which was limited to cutting balsa, plastics, obeche and light ply (which would cover the vast majority of marine modelling) could be sold for less than ยฃ100. Unfortunately, there are too few customers to make it worth designing such an item.
    5 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง DodgyGeezer ( Sub-Lieutenant)
    25 days ago
    HMCS Rainboiw
    "but am still surprised at wooden doors" Well Norm, I guess this was around the period of transition from the Ironclads; black / white with yellow funnels (๐Ÿ˜ฎ) and brass and wood all over the place! Cheers, Doug ๐Ÿ˜Ž
    by Gdaynorm
    Water Jets
    With my luck the self learning bit will team up with the wife and I will still get caught LOL! Martin555.
    7 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Commander)
    Martin Westquay's Piper Cub ;-)
    Found a muffler locally and have fitted it. Put a carb full of fuel down its little gob , flicked it and Gor Blimey it ran for 5 seconds at least. Hasn't turned in donkey's years! So IC it is. Just started covering it in Solartex. An ancient roll I've had for years too. Bought originally to cover the cockpit area on my model of Miss Britain III, so almost none missing from the roll. Had trouble with wrinkles, but then found I was using the iron too cool. Turned it up and last night it all went well. Martin
    7 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Westquay ( Commander)
    by Westquay
    Jotika
    Last year I ordered the decking for my Sea Queen from Jotika. I have tried contacting them about this shipment which was Posted International tracked and signed for. I can't get a positive response on this All I need is the tracking number but it looks as it was never posted! I have been trying to get answers from Jotika with no luck at all. This is very poor service. I don't know what to do from South Africa.
    7 days ago by ๐Ÿ‡ฟ๐Ÿ‡ฆ Ianh ( Petty Officer 2nd Class)
    by Ianh
    Resurrection could be possible.
    Hi Colin, how about your local school, must be a keen lad or ladette -(have to be pc) who would be happy to take it? John B
    8 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Lieutenant)
    by Colin H
    Casting a lead bulb keel
    Mine were left in the workshop for about a month, possibly longer, before being put in the oven for a couple of hours. The problem with the last casting was that the Plaster of Paris was too old.
    9 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง cenbeth ( Chief Petty Officer 1st Class)
    by cenbeth
    by cenbeth
    New member - Boiler ID needed
    That looks like a complicated set up. I'm just about to start making a simple boiler to power a small twin V, so sorry I can't help with any identification. but its an interesting project.
    11 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง mturpin013 ( Lieutenant)
    24 days ago
    by tiger1john
    by mturpin013
    boat building jig
    Hello, i am new to the forum and stumbled upon your post for the building jig... Is it still available? cheers chris
    11 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง oscartrain ( Able Seaman)
    4 months ago
    by oscartrain
    Handy tip. Simple balsa moulding tool
    Great tool and simple too, I had an old pasta roller that was good for shaping soft wood. I used to soak the wood in watered down pva glue before rolling, and lay it on greaseproof paper to fully dry. Cheers Colin.
    12 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Colin H ( Lieutenant Commander)
    by Colin H
    Advice please
    Thank you very much for your help. I really appreciate it ๐Ÿ‘
    12 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง rodrigues ( Recruit)
    by rodrigues
    by rodrigues
    What connector to use?
    I used a set of car points hooked to a servo for the 450 motor in the first tug I built (just on-off). You could use a similar system (tandem operated +- contacts) to switch on your power by TX and forget about plugs. Copper contacts on the cabin could be sprung. or if using car points the spring is on the pivoting contact, and the cabin contacts could be brass or copper strip. I use a similar method on my HSL for the riding light which has 2 sprung wires epoxied to the removable wheelhouse roof and 2 contacts on the top frame of the wheelhouse. Magnets hold the roof on and pull it down on the contacts. Works fine.
    12 days ago by ๐Ÿ‡ณ๐Ÿ‡ฟ jbkiwi ( Lieutenant)
    GLUE FOR ABS
    No problem if I can help I will. Martin555.
    13 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Martin555 ( Commander)
    by sybercottage
    scale of model
    jacko and Brianaro, Thanks for the info re the scale of my Huntsman, many years ago a work mate told me how to do the maths to work out the scale of a model, at the time I was building a Boulton Paul Defiant at 1/6 scale, but my memory is like a sieve and age doesn't help, so all that info drifted away into the ether, the boat building is new to me, the Huntsman was given to me, and now I've ordered a Vosper MTB379 to build, looking forward to it. Cheers gents.๐Ÿ‘๐Ÿ‘
    14 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง Graybo ( Recruit)
    by Graybo
    by Graybo
    LESRO odette
    Hi Mate, contact Lesro direct, they are very helpful when it comes to old models regards Mark
    15 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง jarvo ( Lieutenant)
    16 days ago
    by sigfortunata
    by jarvo
    Bring and Buy
    Dear editor Would please place our Bring and Buy Notice in your next issue of Model Boats Best Regards Colin Travis 29th September 2019 Mutual Model Boat Society Grand Modellers Bring & Buy Sale Crimble croft Community Centre Aspinal Street, Heywood, Manchester OL10 4HL Come along and enjoy this famous event, Either to sell or purchase your supplies There are always lots of unusual bargains to be had Opening time for sales 09.30am Opening time for traders 08.30am Food available from 09.00am Closing time 1.00pm The whole site is wheel chair friendly Admission ยฃ1.50 includes a raffle ticket To Reserve a sellers Table, 6ft x 2ft =ยฃ10.00 Please contact Kevan Winward 07803 975089 or Colin Travis 07905028298
    17 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง ColinT ( Master Seaman)
    Sep
    29
    2019
    1 Day Only!
    17 days ago
    by ColinT
    Hidden switches.
    Ah...now we're back on track with this thread ๐Ÿ˜ That's an ideal place for a hidden switch on a Crash Tender Graham ๐Ÿ‘๐Ÿ‘ Robbob.
    17 days ago by ๐Ÿ‡ฌ๐Ÿ‡ง robbob ( Captain)
    27 days ago
    17 days ago
    by robbob
    Page 1 of 118
