Lighting
Started by Nickthesteam
4 replies 29 likes Last activity: 3 years ago
Lighting
Success! (After a fashion). I fed the main feed wires up a groove milled in the mast, these were soldered to two strips of self adnesive copper foil, one either side to act as 'bus bars'. The tails from the grain of wheat bulbs were then soldered to the copper foil. Insulstion was achieved by painting the mast. Not the neatest of work but the best I can do with banana fingers....
Liked by Commodore-H and Trident73 and
Lighting
In the past I have used a slitting saw in the milling machine and then run 2 enamel copper wires to the light, the reason I used enamel copper wire is that it is much thinner than plastic insulated wire of the same size.
Ed
Liked by Len1 and Scratchbuilder and
Lighting
My first attempt tapering and grooving the mast failed miserably. I made the groove on the mill with a 1/16 round nosed endmill, but pushed my luck an went too deep. When transferred to the lathe for tapering it shattered, and I only had 2 inches projecting from the collet.
Plan B. 6mm dowel is to thin to groove, even to just half it's diameter. Hunting round I found a piece of 8mm dowel just long enough for the job. This time grooving and tapering was much easier, and at the end of the day, only I (and you guys) will know I cheated a little and made a slightly fatter mast. I have set two feed wires into the groove and will now bury them in filler. I will 3d print a mast foot to ease fixing the mast in place and possibly a tiny junction box for wiring the actual lights to.
Liked by Len1 and dave976 and
Lighting
Hi Nick, As the original had wooden masts I suspect any electric lights fitted would have had insulated cables running up the mast supported by some form of pin attached to the mast. I have used insulated copper wire used in transformers etc as this can be obtained in thin grades. As it's insulated you can run the wires together and just scape off the coating when soldering to the Led. If you use a bit of heatsink over the joint this will simulate the waterproof seals used. I did buy (from Component Shop) at one of the shows some very fine insulated wire. When I say fine I mean its not much thicker than a human hair. Worked fine for Leds but not sure it would be OK with grain of wheat bulbs due to the current drawn. I usually paint my wires white to simulate the fire retardant wiring used on naval ships. You can get 2mm Leds as well as surface mount types which work well in restricted spaces. You can solder your feed wire to the small tab at each side but test that you get the polarity correct.
hope tis helps but please let us know how you manage to proceed
Liked by hermank and Len1 and
Lighting
Good morning all. My 105ft MMS is nearing completion and I have decided to fit lights. Now, the superstructure and nav lights are easy peasy, but the mast is a different story. In all the years I have been building model ships I have never fitted lighting, no problem working the sparky side out but how do folk approach getting power up the mast for the the lights that sit there? The mast is only 1/4" in diameter and it tapers to around 3/32". I can mill a groove so far without weakening the top but there will be exposed 'visible' wiring for a couple of inches. As an alternative I was thinking of telescoping brass tube to fit inside one another to make a hollow tapering mast, but that would make extra work sorting out insulation problems. Plastic tube would be an alternative but the mast on the original was wooden so I would prefer to keep the model mast so. I have 3mm grain of wheat bulbs and 3mm leds, I am guessing grain of wheat tor the masthead lights (x3) and leds for the nav lights as I think leds will fit better into the nav light boxes. What do you folks do?
Liked by Doogle and Scratchbuilder and
