Dumas dauntless
The boat will require considerable power to get a reasonable & realistic performance. I would definitely recommend a brushless set up. So here is my set up :-
Motors: 2xTornado Thumpers V3 3548/05 900kv (sku2980) by Overlander
ESC: 2x Shark Marine 60amp (sku ZTW9060201) water cool to be ultra safe.
Batteries: 2x 3s 3200mAh min lipos .
Props: 3 blade 35 to 55 mm ,all perform well.
You can see my boat called Gaby C on YouTube and as you will see ,I didn't bother with the Venturi or the canopies to enable better visibility .
Hope this helps but beware that many brushed recommendations are underpowered and overheat.
