    Fairey huntsman
    11 Posts ยท 3 Followers ยท 10 Photos ยท 56 Likes
    Began 11 months ago by
    Midshipman
    Latest Post 11 months ago by
    Midshipman
    New Zealand
    IanL1
    Midshipman
    ๐Ÿ‡ณ๐Ÿ‡ฟ New Zealand
    ๐Ÿ“ Fairey huntsman
    29 Views ยท 2 Likes
    Country: ๐Ÿ‡ณ๐Ÿ‡ฟ New Zealand
    Online: 23 hours ago
    Hi Chris, Yes, on both parts. Then once you apply a little heat the solder will melt and run togther. In some cases you not need to add any more solder to the joint. Sorry if I didn't make myself clearer in the fist instance. Cheers Ian
    Ian Langley
    Wez
    Midshipman
    29 Views ยท 3 Likes
    Online: 8 months ago
    Thanks Chris thatโ€™s just what happened been on garden duties today so will have another go tomorrow been and got some 60/40 solder today so should it be better than what I got in kit
    ChrisF
    Vice Admiral
    35 Views ยท 5 Likes
    Online: 2 hours ago
    Yes, tinning is applying a thin coat of solder to the area which needs to be meticulously clean otherwise the solder won't take and the joint will pull apart.
    Wez
    Midshipman
    33 Views ยท 2 Likes
    Re to pre tining Ian do you mean little bit of solder on each part that Iโ€™m trying to solder together as went to pick the pulpit off today and not very good connection between each joints so need to re do them again
    jumpugly
    Admiral
    ๐Ÿ‡บ๐Ÿ‡ธ United States
    51 Views ยท 5 Likes
    Online: 4 hours ago
    I wake up screaming about rails. Does my heart good to see good ones!
    IanL1
    Midshipman
    56 Views ยท 6 Likes
    Looks great and fits the part well. With soldering I have learnt that pre-tinning the mating parts makes for the final solder job so much easier. As I said before make up some sort of support to hold it together so all you need to worry about is soldering the joint and not have it moving around. Good luck. Cheers Ian
    Ian Langley
    ChrisF
    Vice Admiral
    62 Views ยท 4 Likes
    Online: 2 hours ago
    I did the plumbing in the kitchen some years ago with a bigger one but when I did some more recently I chickened out and used compression fittings!
    The pulpit rails are something to do outside on a still day I think! ๐Ÿ˜
    Wez
    Midshipman
    66 Views ยท 4 Likes
    Ive not done too bad chrisf but I didnโ€™t trust myself with a blowtorch see how you get on
    DavidW1
    Able Seaman
    61 Views ยท 5 Likes
    Online: 5 months ago
    That's a nice job on the pulpit rail. Just the rear quarters and swim ladder, and you're good to go. Nice work ๐Ÿ‘๐Ÿ˜Š
    ChrisF
    Vice Admiral
    68 Views ยท 5 Likes
    Online: 2 hours ago
    Nice job. That's something I've got to do but I've got 4 to do! The only soldering I've done is to wiring so it's going to be a first for me as well. I bought a small gas torch and some brass rod etc. sometime ago in readiness!
    Show 1 More Posts
