Β£2.50
Β£4.50
Β£6.50
Valid 12 Months
Β£25
Β£45
Β£65
    FIRE TENDER POWER
    13 Posts Β· 9 Followers Β· 3 Photos Β· 12 Likes
    Began 6 months ago by
    Recruit
    Latest Post 5 months ago by
    Recruit
    Moormedic01
    Recruit
    πŸ‡¬πŸ‡§ United Kingdom
    πŸ“ FIRE TENDER POWER
    Online: 5 months ago
    😊 View Profile
    πŸ’¬ Send PM
    πŸ’΅ Gift Membership
    Sorry for delayed reply.
    It's not a kit, I built it from a set of plans I bought off EBay about five years ago.
    Sadly that vendor no longer seems to be there.
    Sorry cant be more help.
    J
    Biggles1
    Recruit
    Online: 7 days ago
    😊 View Profile
    πŸ’¬ Send PM
    Hi I have a 52 inch fire tender as well do you know who made the kit or plans by any chance as I picked this up to restore ?
    Schmango
    Able Seaman
    πŸ‡¦πŸ‡Ί Australia
    86 Views Β· 2 Likes
    Country: πŸ‡¦πŸ‡Ί Australia
    Online: 14 days ago
    😊 View Profile
    πŸ’¬ Send PM
    I restored the same boat recently and installed two mabuchi 775 brushed motors via a single cheap eBay 480esc and 12v lead acid battery. Props are 50mm and it really moves however I had to add water cooling as I over heated one of the motors. Run time isnt that great though - maybe 10 mins . If you understand brushless and have the budget then that is the way to go I think. I didn’t want to spend much and don’t use it enough to justify the cost of brushless. I pulled the motors from an old hitachi drill!
    Moormedic01
    Recruit
    😊 View Profile
    πŸ’¬ Send PM
    Thanks
    Moormedic01
    Recruit
    😊 View Profile
    πŸ’¬ Send PM
    Many thanks to all for the replies.
    I have had loads and have lots of food for thought.
    J.J
    Moormedic01
    Recruit
    😊 View Profile
    πŸ’¬ Send PM
    Thanks again to all who sent me info
    J.J
    Commander
    105 Views Β· 1 Like
    Online: 16 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    Hi J.J.
    I see you are not far from me at S.O.T., I'm in Sandbach and sail with CreweMBC, are you with the Potteries Club at Westport Park? You are welcome to come and visit any Monday or Wednesday afternoon, details are in the Boat Clubs and Lakes section on this site.
    There have been several replies so far and I prefer the last para of CB90's post:
    "My own fast patrol boat is 52in long and 12 in wide currently uses 2x 2826 brushless outrunners (fan cooled) 900kv 60A max at 3S (11.1v) with 2xwater cooled 90A Flycolor ESCs.
    The motor run a little hot so need to reduce the size of the propellers from 45mm." with 35/40mm props your model will fly and expect 40min plus per run.
    LiPo's do need to be handled correctly and you need a LiPo charger using a balanced connector to avoid overcharging and an ESC that will cut the power when the voltage drops below 3.5v. If you are not using the battery for some time then you need to store it at 3.7v per cell and a good charger will have a setting to enable this. I use the Giant Power Intelligent Balance Charger G6AC 50W 6A 12/220V.
    Keep your build light and be prepared to add some ballast when testing.
    Good building and please post details when more advanced
    mturpin013
    Vice Admiral
    127 Views Β· 3 Likes
    Online: 10 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    I have the 47" with a single prop - Turnigy 5045 - 660 KV turning a 40mm twin blade prop, power is Turnigy High Capacity 5200mAh 4S 12C LiHV Pack
    ESC - Hobbywing Seaking 120A-V3 Speed Controller
    It planes easily and last for 20 -30 minutes dependant on how you sail it
    check out my build blog
    blogs/37275
    pressonreguardless
    Commodore
    πŸ‡ΊπŸ‡Έ United States
    122 Views Β· 1 Like
    Country: πŸ‡ΊπŸ‡Έ United States
    Online: 11 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    Good Advice, Roy
    Obtaining the right power train can be daunting and expensive.
    Trev
    Colin H
    Admiral
    Online: 9 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    Well JJ, your boat is looking good, but 60mm props seems a bit to big, I would expect either 40 or 45mm to be plenty big enough.
    As for motor the majority of modellers use brushless and lipos these days.
    But I'm still old school, brushed motors and lifepo batteries.
    My choice would be a pair of 600 motors and a 12v 7ah battery.
    But as I said, that's just my opinion.
    Fair winds and calm waters, COLIN.
    Show 3 More Posts
