Sourcing timber
Followers (5)
- mturpin013Bronze
- TonyAshSilver
- zoomaBronze
Sourcing timber
Sourcing timber
The power loss from driving the fan should be quite minimal and it would be nice to find a use for all those prop adapters that do not get used.
Where do you buy a fan like that?
Sourcing timber
Sourcing timber
"I have now been advised (thanks Doug) that "lime" wood is actually "pear"."
DOUGS QUOTE :-
Er no!
I said that basswood (as it's mostly known in the US) is called lime in the UK.
Main thing is - that your boat doesn't go pear shaped!
As our antipodean friends might say 😉
Very confusing...and not helped by that gin and "lime"!
- so "pear wood" is known as "pear wood" and "bass wood" is known as "lime wood" - unless it is known as "Linden wood".
I will try to remember that 🤣
Sourcing timber
Er no!
Sourcing timber
The distance between these slots is 16", so I can make one long strip of wood from each side of every slat, and end-up with a lot of 16" lengths from the middle that will be approximately 1" wide .
These 16" lengths could be cut or stripped as required for future projects.
Sourcing timber
They won't be a flexible or as easy to work with as obechie as it is a harder wood, but it would probably be really good for planking larger hulls like Tony is using it for on his dragon yacht.👍
Sourcing timber
Maybe I could run them through the bandsaw to make long strips from both sides?
Most of the wood (from the middle of the slates) would then convert itself into shorter lengths as I hit the regular string slots.
Its a shame to waste so much of the wood - but I should get plenty of 1/4" wide strips and lots of short lengths to make other things from in the future!
Sourcing timber
Sourcing timber
The only problem that restrict their use is the slots that are cut at regular intervals for the various supporting chords.
To my shame I have only used a couple for paint mixing (after chopping them down at each slot).
Sourcing timber
Now that’s an interesting thought….No never thought of that one.
Can you post some pictures of your work please.
I am intrigued,as I am sure will be others.
Regards Bill.
Sourcing timber
I have added a few photos of my boat build. The hull is 1m long. The plan is to make two different superstructures for it, one a cabin cruiser (Fairey-Marine style), the other a pilot boat. The motor is a Turnigy 4240 740Kv which will run on 5S. Whilst the Hobbyking ESC is water cooled, I have added a cooling fan to the motor. With plenty of air volume/circulation within the boat I am hoping this will be OK.
Liked by
Loading…
