speed controller
Followers (9)
- RNinMunichBronze
- Commodore-HGold
- stotty1111Gold
- GregHiltzGold
- Stephen TGold
speed controller
The maximum supply (battery or batteries) should be based on the specification for that particular ESC (which has not been identified).
Note that running two motors from the same ESC: Brushed motors typically don't run the same speed in either direction due to the alignment of the brushes (kind of like BTDC timing in engines). So if you are using counterrotating props one will probably turn a little slower than the other which is why two ESCs might be the better choice (and the two batteries will not conflict with each other).
speed controller
Also they should preferably be Schottky diodes.
Stephen; These have a much lower forward voltage drop, ca 150 - 450mV as opposed to 600-700mV for general purpose silicon p-n diodes. Such as the 1Nxxxx series.
The lower forward drop means, apart from saving energy, they can switch off much faster when presented with a reverse current flow, as in 'back charging' of one battery by the other.
Such 'back charging' can create high current which can cause wiring to overheat and maybe catch fire and the loss of the model.🔥😭 You have been warned!
To minimise this risk both batteries should be as identical as possible; same brand, type, voltage, capacity (mAh) and especially state of charge. If in doubt about the state of charge run them both through a discharge - charge cycle before sailing.
Stay safe Stephen and enjoy the fruits of your labours🤞
speed controller
speed controller
speed controller
Correct me if I am wrong please!
speed controller
speed controller
speed controller
speed controller
speed controller
speed controller
speed controller
As far as the batteries go, wiring two (similar) batteries in parallel will effectively double the amperage (current) and the voltage will remain the same. Connecting two batteries in series will double the voltage while the amperage will remain the same.
speed controller
Liked by
Loading…
