Other Functions for Model Boats
Started by LewZ
20 replies 88 likes Last activity: 4 years ago
My HENG LONG 25" tug rolled in a crosswind & sank on its maiden last summer. Fortunately I was sailing with several members of MMM (Metro Marine Modellers in Toronto) who had experience with such events.
The hulk was in abt 6' of clear water very close to the vertical walls of the launch ramps. They grabbed the closest light aluminum "J" poles from lifesaving stations & manhandled her ashore. Fortunately she weighed considerably less submerged as she displaced several pounds of water.
The design uses a waterballast chamber open to the sea thru grilles in the bottom of the hull; it floods in the 30sec right after launch. For this season I have removed the fire pump & sealed the flood grilles with ShoeGoo.
Ballast is now a 6V 4AHr SLA (I cut off the lid of the ballast tank using my Dremel, the battery fits perfectly, almost filling the former ballast tank) & some lead shot rather than a few cu. in. of water. I am also adding a bulb keel, sailboat-style.
Battery & all electronics replaced.
VA3ROD
Liked by Colin H and RNinMunich and
Hi RN
You are quite right to identify the likely friction points. I had to go through the process myself.
Initially I tried a fishing float but this did not have sufficient buoyancy. After drinking (most of) a bottle of bubbly the answer came to me - use the cork. It was easily fashioned with sandpaper whilst mounted in the chuck of a drill. A flotation test was carried out along with a sensitive weigh scale to determine the 'pull' it would have on a line.
It took two or three attempts with the drum to get it running easily, and the size of the eyes on the mast that hold the float had to be increased to allow the buoy to freely float free.
I have not tried sinking the yacht to see whether it will all work as and when required so I just hope the buoy will not be required.
After a number of sailings I managed to reduce water intake to a minimum, maybe just 20cc, even after many minutes of sailing with the lee rail completely under water. This is not even sufficient to reach the electrics, let alone cause any trouble or possible sinking. The volume of water intake required to sink the boat is around 2000cc, so I don't anticipate sinking any time soon ! 😉
Liked by RNinMunich and hermank and
Hi flaxby,
"At deck level the line runs to a bobbin (or drum)."
Your solution certainly looks good in the photos but the one factor that's been bugging me since my first tentative 'thunks' on the subject has been friction! How to ensure that the whole shebang is a friction free as possible and that it actually releases in case of a 'disastrickle'!😮😭 Have you tested your setup for free running?
Your solution appears to have three potential friction points-
The loops that both tether and spike pass through,
The 90° turn through the ring at the mast foot,
The cable drum; bearings, potential line tangling.
Do you know if your bubbly cork has enough buoyancy to overcome all this?
For my sub, type 1A U25, I was thinking in terms of using the aft torpedo loading hatch with the float and the flat-coiled tether in a compartment within the flooded hull section.
Flip the hatch and away she goes. It's the flipping that's the tricky bit🙄
The float could be a Minion body😁 e.g. a yellow Surprise Egg case.
Liked by Colin H
Having seen my friend's schooner sink I needed no further encouragement before making the buoy pictured below.
Having espoused the need of such a 'simple extra' I am all the more surprised that fellow LBMBC members have not adopted it. !!😉
Liked by Colin H
flaxbybuck,
I love the idea!
I nearly lost my Robbe Paula III last year in our pond.
A float disguised as a buoy, and attached to a bobbin is ingenious.
I will have to try adding a feature something like yours.
Thanks for the great idea.
Liked by Scratchbuilder and Colin H
I indeed encouraged Flaxbybuck to add such a device to his newly- built schooner. This was after my scale motor sailer "Lockdown Dream" actually sank on another club's lake while leading a race!
Scale-Sailing models are at most risk here as their sail areas are proportionately far larger than on full size craft. What is more when water gets during gusts "over the side" it stays in and sinking becomes ever more likely.
My pride and joy was only saved at all because the lake was 18 inches less deep than normal - so just one inch of mast was out of the rather dirty water.
Quick-release bouys are therefore quite vital for such models. What is more they at are least desirable for power boats with insufficient built-in buoyancy to still float when totally waterlogged.
By collisions or from "towering seas"; I have seen actually other boats sink without trace.
For the sake of one cork and some fishing line, a securely tethered marker bouy is one simple extra feature that can indeed save your treasured model!!
Dr John. F Leeds and Bradford. MBC. 😮😮😴
Liked by Colin H and dave976 and
Have seen models with a floatation marker attached and wish I had one on my schooner when it sank. Recovered thanks to a friendly swimmer diver with a full size dinghy but would certainly of helped.
Not sure about using the marker cord to lift the model unless it is very light.
Nice bit of engineering there flaxbybuck! Never thought of using the mast to run the line through. I don't think it takes away from the model either. Very well done! I hope you never need it... RR 👍👍👍
Liked by Scratchbuilder and DWBrinkman and
I once read an article where a buoyant object was tied to the boat with string and then stuck to the deck of a boat with soap. Don't know whether it would work or not. I'm sure there are stickier things around than soap which are also water soluble but it seemed like a good idea at the time.
Best wishes to all, Tim
Liked by Scratchbuilder and Len1 and
No good for your submarine ,but I made a float for my schooner that will act as a marker should it sink. I did this soon after seeing a friend's schooner sink. Fortunately it was in shallow water and we were able to spot the tip of the mast just below the surface. But it so easily could have happened in deeper water and not been spotted.
I made a float from a cork (from a bottle of bubbly, of course) and kebab skewer attached to a line that is a couple of meters longer than the known maximum depth of our sailing water. At deck level the line runs to a bobbin (or drum). I had to make all the elements of this strong enough to be able to lift the boat off the bottom by pulling on the line.
Thankfully I have not had to use it , yet !😉
Liked by ChrisG and Scratchbuilder and
One of the neatest (🙄) fun add-ons I've seen here in Germany many years ago was on a tug boat.
The wheelhouse door opens, the Cap'n comes out ...
and PEES OVER THE SIDE!!😮🙈 Brilliant.
Somewhere, in deep dark and dusty depths of my archive I must still have a German ship model magazine (Schiffs Modell or Modell Werft) with an article describing how it works and was built. The great rummage starts😁
Liked by Rookysailor and DWBrinkman and
Hi Dave RR
"I think it would be nice to have some sort of tethered marker that pops out and floats in the unfortunate circumstance of sinking"
This is something I've been pondering for a while as well.
Not necessarily in case of a sinking😭 but originally for use in my subs,
a) To know where they are,
b) To send up an antenna buoy, the thought triggered by some work I did on full size submarines when such buoys started to appear.
Still at the idea/sketch on a fag packet stage. If you are any further I'd like to hear👍 For a sinking marker buoy you'd need to know the max depth of your pond/lake of course and then some. The buoy would then of course need enough buoyancy to lift the weight of the necessary length of line. I was thinking of using the finest (lightest) fishing line I could find.
The release mechanism could be automatic, triggered by pressure switch (for subs) or a water detection switch mounted above deck on a surface ship, like the auto release on EPIRBs (emergency signal beacons) on real ships. Or by RC channel - before it's too late!!
Liked by Len1 and dave976 and
Hi Herman,
Ref your Harro Koebke illuminated heli-deck-
Looks really great 👍 but a word to the wise!😉
On all the heli-decks I've stood on, and there's been a few over 35 years working in Marine COMMS -
from a Nigerian Shell offshore oil rig (in the middle of a tropical storm, very exciting😮, I said to the pilot "What! You want to land on THAT! That postage stamp down there!") to various corvettes, frigates and even a light aircraft carrier and an LPD Heli-carrier.),
they all had the actual lights set down into the deck and were protected with very thick toughened glass domes which barely protruded above the deck. Yours look kinda vulnerable to damage from the chopper or even heavy sea boots!
Some great "accessories" out there people!
Dave, I thought about having a marker/float on the deck, that had either a light tension retractable line spooled inside the hull or perhaps the line coiled up on the deck with a thin water soluble cement holding it in place. However, never had a boat completely sink. My 47 ft USCG almost did, 98% under water.
Liked by Len1 and Colin H and
My Perkasa has rotating radar, Oerliken and Bofors. There’s also a sound module and speaker.
Only have an early video before I got to grips with changing the sound files via the Tx
Liked by Colin H
Hey Lew, I have had many of the listed items on various builds but nothing new 😔. I think it would be nice to have some sort of tethered marker that pops out and floats in the unfortunate circumstance of sinking 😱. I had this happen and never recovered the boat. I still think about it 20 years later now. Fun topic! Thanks, Dave RR
How about a video flaxbybuck, sounds really cool. RR
Hi Lew
this is a subject that I would like to get more involved with. I have the usual things on boats, viz. lights, radar, horn etc but want to bring a bit more interest and/or amusement to them with animated figures. On my Sea Queen I have a dog that turns its head. This often brings smiles to members of the public who pass by and see it.
On a boat currently being built I am arranging for the driver and co pilot to turn their heads (independently), for the driver's hands/arms to move when the steering wheel moves, and for the co pilot to wave. This will be done using a 6 channel Flysky transmitter. It might be a few months before this boat is on the water but I will send pics when it is.😉
Liked by dave976 and DuncanP and
I also have the Dusseldorf FLB that someone else built. I completely disassembled it to build it to the current real boat. Had to stop to get some tank stuff done.
Liked by RodC and hermank
Lew à good day
The First Boat i Made when i was 16 was the Graupner Kit Constellation
2 functions. After came quite à few then i builded the Dusseldorf fire fighting model with waterguns and turning 180 degrees. Then i builded the Lifeboat Trent with searchlights à turning radar and Gully luminated mast with blindlings Blue light
And the one i m Building know is the german rescue boat Harro Koebke scale1:32
Full Lightning of the mast
Watergun,luminated heli pad and a small rescue Boat that can navigate and come back to the mothership
Liked by MouldBuilder and Colin H and
When I first started in RC scale model boats the only functions that the boats had was steering and speed control (probably like most new to the hobby). Gradually, some of my boats had additional functions, sound, smoke, lights, radar, and more.
My question is what unusual functions do others have in there models? (Perhaps some photos. )
Liked by Colin H and RodC and
