Icebreaker build materials
Started by Seaspray
10 replies 12 likes Last activity: 5 years ago
Martin555 Kinda seen that it was needed a good looked into it. Wanted to drill the hole in the keel for the rudder post, before I assembled it on to the frames. Making sure it was square and vertical. Should be ready for a restart on the build at the weekend Will go thru all procedures right from the very start of the build 👍
Liked by Martin555
Hi Seaspray,
It looks like you will have to do a slightly different rudder setup as the pivot point could clash with the frame.
You will probably have to cut some of the wood away near the frame so that you could fit the rudder linkage.
Liked by Seaspray
Frames Little problem with rudder configuration before I glue the keel to the frames . Frames cleaned up, slots for keel made good for a nice fit ever thing went back together like a jigsaw, even the right height of the frames on the keel. Take a break now.
Liked by Martin555
Hi Seaspray,
I think i know were you went wrong.
You say you used a mouse for sanding down!
Maybe you should of used something rougher to start with like a Rat LOL!!
You are certainly having a rough time with this hull.
In the past i have also had boats that did not want to be built so i know what you are going through.
The only advice i can offer at the moment is keep trying, just do a little bit at a time and when you are happy with that then do another little bit and so on and soon the worst bit will be over and you can start on the best bits.
Remember if i can help just shout.
Liked by Seaspray
Hi Martin555 nice to hear from you. Got a rebuild going to the stage of fully planked. Put a thin layer of filler not P38 on planks to smooth the hull surface . Over night in the shed and in the morning the filler had went funny on the surface looking like a rough sea. Tried to smooth it with the mouse which was not powerful enough. Got the rotary sander on the go. Even that was bouncing of the filler. Now after a half hour of sanding gave up.. Only one thing remove planks which ended up as scrap. Today busy in shed removed from the keel, salvaging the frames and have 8 of the 10 cleaned up pins removed ready to fit to the building board. Will do the rest tomorrow and put them back on the building board then as the keel isn't damaged fit it to the frames. Ordered more 6mm ply and obeche
strips from SLEC. I don't look at myself as a modeller just a reworker. Well I can polish a turd and make it look good. Great to see you back.
Liked by Martin555
Hi Seaspray,
I am looking forward to your Build log.
Remember just shout if you need any help.
Liked by Seaspray
scout13 Hi yes I have used SLEC many times over the years. There good suppliers I get my ply there but it cost £9 in postage. although it is usually here next day and well packed Many thanks.
Liked by Martin555
ToraDog Thats a wood a never thought of using as I said I am not too keen on balsa. it sounds a better wood to use and thanks for the info on the glass cloth. Unfortunately these days buying from USA with customs and import tax makes it out of the question. That looks like a half decent site. They'll be places here U.K. that I can obtain the Bass wood. Many thanks
Liked by Martin555
Hi Seaspray,
On my Eastwind build I use blocks of Bass wood rather than Balsa. Reasons were, a firmer backing, less likely to sand too much away, holds onto resin better than balsa( balsa absorbs it so much that the surface loses volume and the glass tears away easily). I ordered mine from Midwest: https://midwestproducts.com/pages/wood
As for glass cloth, I used a fine, weave, I think around 5 oz. Easy to fill the texture with two coats of resin.
Liked by Martin555 and Seaspray
Stephen has taken it off the site as I intend to start from scratch and starting to order necessary item for the build. Balsa never used it seems to burst with me. I think you have to cut it with the grain. Now I believe there is 3 types of balsa soft, medium and hard. which type would be best for sanding and shaping the bow and stern. I would have like to use planks all the way from bow to stern but using a simple mock up the bend was too much breaking the planking, even soaking and heating planks. It would be balsa blocks to be used. Huh.. nearest model shop is 60 miles away and not all stock wood. Lastly what would be the best fiberglass matting to cover the hull. A type that is not too hard to work with.
