adding strakes to existing hull
Started by octman
1 reply 4 likes Last activity: 5 years ago
Given the small size of strakes I doubt they will do much for combating roll. They won't hurt to fit though if it's a planing hull but they are usually fitted on a model for the look rather than any performance benefit. Chine rails on the other hand are very important as they dig in on turns and towards the bow they act as spray rails and keep the deck dry.
As for layout it depends on the size and shape of the hull. Back from the bow it's best if they run parallel to the keel and can be run all the way to the stern or stop short. At the bow they can be positioned as you say to look right.
Couple of shots of my Faireys. One with the strakes full length and the other one stopping short as per the full-sized boat. I prefer them full length for the look and have done that on all my other builds.
Having Googled the Aeronaut Jenny I see that the beam is quite narrow relative to the length which is likely part of the problem.
Liked by Madwelshman and Redpopman and
I have an Aeronaut Jenny which rolls a bit on tight turns, and I feel the need to add some strakes to the hull to reduce the roll.
What I need advise on is the design of these. I am thinking of 2 either side of the keel, but at what distances from the keel, and what point on the hull do the radiate from? Or are there no specifics for any of these, and they can go anywhere, so long as it looks right?
Liked by Mike Stoney
