Jet Pump Thrusters
Started by Spence
5 replies 12 likes Last activity: 3 years ago
Jet Pump Thrusters
Thanks everyone for the important knowledge you have given me. Cheers Spence.
Jet Pump Thrusters
Great start can't wait to see what comes next ,I bet you have learnt some new skill 👍
Phil
Jet Pump Thrusters
Hi Spence:
Although I have no experience with jet thrusters, I do sweat the paint issues all the time.
You can always use an oil base paint over water based paints. You just can't do the reverse without priming the oil based paint with a decent flat oil based or alkyd primer.
However, should you apply a water based paint finish coat that you cannot part with, you can always seal it with an exterior clear spar varnish.
The trick to this whole situation is to do duplicate tests on scrap wood. I've always found the test work is the best way to go and worth the extra effort. It'll save you any disastrous mistakes where you have to strip off a whole hull of mistakes.😉
Liked by Spence and AlessandroSPQR and
Jet Pump Thrusters
Have used several of the smaller ones. They work well and have never had a debris ingress issue.
Liked by Spence
Jet Pump Thrusters
I assume you are talking about a water jet? They can suck debris in if the lake has plenty of weed etc. but you'd usually have a grille on the water inlet and avoid waters like that anyway even if using a model with a prop.
I've painted the house with oil and water based paints with no problem after thorough preparation and using primer and undercoat. Preference is for oil based if you want a good gloss.
Expensive but I use International Yacht Paint - if it's good enough for the real thing it's good enough for my models!
You can get solvent based household gloss paint e.g. Dulux Trade from Dulux Decorator Centres but that's expensive as well and the smallest tin size is 1 litre which is too much for most models.
Liked by Spence and Scamp and
Jet Pump Thrusters
Hi Guys and a Happy New Year to all. I am using an ordinary electric motor on my current project but I, at one time considered a Jet Pump Thruster. Wondered if anyone has any experience of them as I heard they can suck debris. I said in an earlier post I was using oil based paint but had found it difficult to source amongst all the water based paint, which apparently you can't paint over oil based and vice versa, or so I've read. Interested to hear any views the forum has. Cheers Spence.
Liked by jumpugly and Peejay and
