lifeboat
HI Matt
Yes I have a Solent very similar to yours based on the Aerokits design. There are pictures in this sites photo gallery. I am also rebuilding a 1/12 scale Metcalf mouldings model of an Arun. The Joy and John Wade based at Yarmouth. I am documenting on the Boat Build Blogs part of this site. Work stalled at present as I ran into paint difficulties requiring a complete strip down of the hull. All my own fault - I used some primer that I had obtained from a show or car boot sale. it appears that over time aerosols can deteriorate with the propellant affecting the paint. in future I will only buy from my regular supplier in Nantwich Market, Cheshire. He currently sells cans at A£2.50 so is much cheaper than elsewhere and I have never had any problems with his cans.
I have provided detailed photos of my Solent to another member and will email these to you if required. I use a couple of Bhuler motors driving 55mm props using a large 12v SLA battery. As I hardly ever sail this model I use a Bobs board speed controller but the model would benefit from a 15amp ESC on each motor as this would aid turning. I have Improvised and use a microswitch activated by the rudder to stop the inner motor on full rudder, necessary because the large keel on the model overcomes the rudder. Two independant motors would allow you to stop or even reverse on motor when turning. Model Slipway do railings and other fitting in 1/12 scale at reasonable prices but there are other suppliers. I used 4mm brass tube for mine with holes drilled for the rails where I used brass chain.
Please let me know if you would like to receive the pictures.
