Programmable Tx
Started by NickW
8 replies 3 likes 0 followers Last activity: 9 years ago
Programmable Tx
Doug after the problems with the electrics that you helped me with I moved entirely over to Turnigy, bought the programmable Tx, spent a lot of time 'in conference' with the tech guys at HobbyKing, so i'm now confident I have a great set up. The only thing letting me down were the instructions how to set up the Tx. I'd have been better off using the instructions for my electric kettle!!!! Until I found the 'how to' uploads on YouTube.....i'm now cooking with gas and the future is orange :-) have a good weekend my friend and happy boating
Nick
Liked by RNinMunich and rolfman2000
Programmable Tx
Always assuming that the set actually transmits during programming!
I'm not convinced of that so will test with my Reely/Turnigy and Spektrum sets. Watch this space!! 😉
Programmable Tx
As stated, the results are saved in the TX. From experience with R/C aircraft you would get positive results by disconnecting motors and switching on both units(unless you need various throttle settings)in which case make sure the props are clear of anything. That way you can see the results before saving.
Programmable Tx
Shame, the ones for my Reely/Turnigy are pretty good.
For my Spektrum - so much it gets confusing 🤔 or you forget where you are! Bon chance mon ami! 😎
Programmable Tx
Hi Doug.....just getting used to reading the instructions which are sketchy at best.....
Nick
Programmable Tx
Hi Nick, was a simple answer to a simple question!
The model / RX does not need to be connected and should not be switched on. You are saving in the TX not the RX.
Could lead to some unpleasant results if you are fiddling with the throttle settings! 😡
Possible exception, setting rudder limits and trim BUT disconnect the motors just in case!!
Cheers Doug 😎
PS I don't think that most sets will transmit when in Programming mode anyway. Haven't tried it! 😉
Programmable Tx
could you be more specific 👍
Programmable Tx
It's said the only stupid question is the one that wasn't asked.....okay here's an intelligent question then :-) When you have a Tx that can be programmed (facility for up to 20 models on the same Tx) does the boat you want to program in have to be connected/switched on etc for it to save into the Tx?
