Planet 5 receiver
Started by kmbcsecretary
11 replies 4 likes 0 followers Last activity: 9 years ago
Planet 5 receiver
its listed else were witch means i cant list it but on that site
Planet 5 receiver
Hi Smudger
I suggest you re list this in the FOR Sale section in the forum. it helps if you can add a price.
Planet 5 receiver
unfortunately i cant let that go you could do what i did and remove the one on the opposite stick and use it as your template and make one from plastic mine works a treat
Liked by onetenor
Planet 5 receiver
That might be a stroke of look as I'm also looking for one for my turnigy 9x, is it for sale or do you know where to get one from?
Thanks for all your help
Planet 5 receiver
i have had a look this morning Dave and its the one that came out of my Turnigy 9x it is bigger than the planet 5 one im afraid but if i do come across one i will let you know
cheers
Liked by onetenor
Planet 5 receiver
if you can'nt get a spring & lever, why don't take one off a channel you're not using. Hope this helps. Regards Dave.
Planet 5 receiver
How much do you want for the return throttle? Willing to give it a go and see if it fits!
Planet 5 receiver
hi Dave there is a bind button on the side of the receiver just press that and turn on transmitter.
i know i have a spring return in the workshop but unsure if for planet radio
Planet 5 receiver
How easy are these to bind?
i dont suppose you have a throttle return spring for a Planet T5 transmitter do you?
thanks
Planet 5 receiver
have found this tucked away in a draw in workshop no longer have radio to test it but light comes on when battery connected looks almost as good as new no damage to case or pins
£5 posted
THIS HAS NOW SOLD THANK YOU
