JOINING BATTERY & RECEIVER CABLE
DON'T use this feature if you are using a LiPo battery!!
There are several other versions without this third plug available here
http://www.componentshop.co.uk/futaba-charging-switch-harness.html
I guess the RX battery is a fairly small NiMH and also has the JR type plug.
BTW: something to check before switching on-
Does your speed controller have a BEC circuit? if so it supplies the RX as well so you don't need an RX battery at all.
Or doesn't your yacht have any auxiliary motor and ESC?
Happy sailing, Cheers Doug 😎
Looking forward to the video of the insulting tape 😁😉 or is that what I keep seeing on the news with Mr T??
