Hi Les
Thank you.
There are three LEDS which change from red to green when fully charged. I can see no mention of setting a half charge. Haverlock was right in thinking each cell was charged by the balance lead so you will be protected from overcharging.
The solution is to buy a battery checker theirs is DYN4071 and I have one in my collection.
Using the checker involves plugging the battery via the balance lead into the balancer and each cell voltage is displayed sequentially. So you charge for half your normal length of time and check the voltage of each cell is about 3.7 to 3.8v.
Bit clunky but would work.
A better solution would be to invest in a balancer charger which will automatically charge to full voltage or the storage charge.
There are several available some with mains power supplies and others needing a DC power source.
Have a look at
https://www.componentshop.co.uk/catalogsearch/result/?q=balance+charger
I have a Giant Power G6AC but they all work just as well.
Please ask if you need more info
