tvr steam engine
Started by Newby7
4 replies 1 like 0 followers Last activity: 8 years ago
tvr steam engine
Hi Gary my e-mail is rgroff7@cogeco.ca you can e-mail me and we can figure out .
Rick
tvr steam engine
Hi Rick I am having a few problems here trying to manipulate this website, I have read your message asking about an engine flywheel, and I will make one for you as I have the necessary diameter brass bar. your problem is figuring out how I get it to you, let me know how we can accomplish this problem. Regards, Gary.
tvr steam engine
Inspiration, a beautiful thing almost a work of art.
tvr steam engine
Hi Rick, and I am hoping this helps, the inlet and exhaust manifolds on the engine have no fittings included for you to screw onto, the connecting end is just a plain 1/8" brass pipe, so you need to silver-solder your fitting to suit. I have included a photo which hopefully will help. you are going to need some elbows (90* bends) and maybe a Tee piece or two, globe valves and the pipe fittings to put it all together, plus a condenser to collect and separate the exhaust waste steam. My condenser is simply a piece of 2" brass pipe, I can do you some piping diagrams for you if this helps, or send me a plan of how you are going to connect it all together. The end result will be worth it I promise. Regards, Gary. Hang on in there I have every confidence.
Liked by Joe727
tvr steam engine
Hello all and to Gary
I' m looking for the tread size for the ports of the TVR steam engine are they 1/4 32 or 1/4 40 as I want to order fittings in advance of my building the engine .
Rick
