Current Website Support
91
Contributors
29
Subscribers
You are Not Registered
Subscribe for your gold medal ๐Ÿ…
Until Cancelled
ยฃ1
ยฃ2
ยฃ3
ยฃ5
Donate for your silver medal ๐Ÿ…
12 Months
ยฃ10
ยฃ15
ยฃ50
    Login to Remove Ads
    Followers
    Brushless motor couling
    by stevecw ๐Ÿ‡ฌ๐Ÿ‡ง ( Able Seaman)
    ๐Ÿ“ฃ
    Click To
    Follow
    15 Posts 14 Replies 5 Photos 12 Likes
    RNinMunich
    Fleet Admiral
    ๐Ÿ“ Brushless motor couling
    Country: ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    Online: 3 days ago
    Steve,
    An alternative to sawing off the threaded part of the shaft at the coupling end.
    Buy the spiral coupling with a 3mm I/D at the output end.
    Drill it out with a 4mm tap drill, = 3.4mm and tap a 4mm thread 0.75 (normal) or 0.76 pitch to match your shaft end. (๐Ÿ™„)
    Bingo. Bob's yer Uncle and Fanny's yer Aunt. Job done๐Ÿ‘๐Ÿ˜Š
    Cheers, Doug ๐Ÿ˜Ž
    https://www.boltdepot.com/fastener-information/metric-tap-dr...
    https://www.boltdepot.com/fastener-information/metric-tap-drill-size.aspx
    ๐Ÿ”—
    RNinMunich
    Fleet Admiral
    Online: 3 days ago
    Thanks Rowen๐Ÿ‘
    Forgot that older shafts were like that.๐Ÿ˜”
    Since I got my mini lathe and milling machine I've got used to making my own!
    Cheers, Doug๐Ÿ˜Ž
    Rowen
    Commander
    Country: ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    Online: 8 hours ago
    Not unusual. Some shafts fit both screwed propeller and a screwed coupling, thus threaded at both ends.
    If you want to use a coupling with flats and grub screws, just cut the thread off. May have to shorten the outer tube to compensate.
    1
    stevecw
    Able Seaman
    Online: 9 months ago
    Thanks again. Strangely enough the prop shaft is threaded on both ends. The same thread on each end.
    Cheers.
    RNinMunich
    Fleet Admiral
    Online: 3 days ago
    Hi Steve,
    The inserts of the spiral coupling are not threaded.
    They are secured with grub screws.
    That's why I milled depressions in the shaft to prevent any slippage.
    See my 2nd pic below with the shaft and coupling on the mini milling machine.
    Use a flat ended mill bit to prevent it skidding off the shaft - like spiral drills would๐Ÿ˜
    I also fitted a collet in the same way, visible to the right of the pic.
    I then fitted spacer washers between the collet and the end of the shaft tube.
    Prevents the shaft and prop exiting stage backwards if the coupling should come loose.๐Ÿ˜ญ
    Which mine never has ๐Ÿคž๐Ÿคž
    3.94mm I would say is well within the tolerance of a 4mm drawn rod, especially those produced for the model market, and not for a NASA rocket ๐Ÿ˜‰
    I assume that your prop shaft is only threaded at one end.
    That's where you screw the prop on. DON'T forget a lock nut and a thrust washer๐Ÿ‘
    The plain end goes into the coupling. If you can't mill a depression into the shaft for the grub screw just file a flat. Secure the grub screw with Loctite or similar.
    Hope this helps.
    Any doubts just YELL.
    Cheers, Doug ๐Ÿ˜Ž
    PS Just added two pics re milling the prop shaft๐Ÿ‘
    RNinMunich
    Fleet Admiral
    Online: 3 days ago
    "The centre of the sleeve can as also be filled with grease or oil to maintain lubrication "
    That's a neat idea Rowen๐Ÿ‘
    Could give my old couplings a new lease of life.
    Cheers, Doug ๐Ÿ˜Ž
    stevecw
    Able Seaman
    Many thanks gents (I'm assuming gents, sorry if not), all very useful information for the novice!
    Next question if I may - my prop shaft was bought about 20 years ago and when I use my digital calipers the plain bit of the shaft is 3.94mm dia. How do I know what the thread is to order the correct threaded insert for the coupling? Can I somehow convert the number of threads per mm? 13 revolutions of the nut on the prop shaft moves the nut 10mm so i'm assuming that 10/13=0.76 means that it should be an M4. Is this correct?
    Thanks again in anticipation.
    Rowen
    Commander
    Online: 8 hours ago
    Agree with the clackety clack noise. I slide a length of plastic tube over the coupling once all is lined up.
    This sleeve reduces backlash in the coupling and quietens it down.
    2
    RNinMunich
    Fleet Admiral
    Online: 3 days ago
    Hi again Joe,
    It was Krick!
    You can order them with a variety of input / output diameters.
    Cheers, Doug ๐Ÿ˜Ž
    https://www.krickshop.de/e-vendo.php?shop=krick_e&SessionId=...
    https://www.krickshop.de/e-vendo.php?shop=krick_e&SessionId=&a=search&SearchStr=searchfield_technic_0%3Astegkupplungen
    ๐Ÿ”—
    2
    RNinMunich
    Fleet Admiral
    Online: 3 days ago
    Hi Joe,
    I like the spiral coupling a lot. Takes the full power of my 1000kV motor running on a 3S LiPo without a whimper.๐Ÿ˜Š You have to be careful with the initial alignment though as it won't flex as far as UJs. personally I didn't consider that a drawback๐Ÿ˜‰ Being compressible it also absorbs any forward thrust on the shaft๐Ÿ‘
    This was my first BL setup and I had read / heard of them ripping the inserts out of the conventional plastic / brass UJ couplings. Had used those for years on my brushed motors.
    But I learned to avoid the ones made of metal only. Too much clackity clack!
    Sometimes the metal to metal contact seemed to create RF interference๐Ÿค”
    I think my coupling was from Krick, was a few years ago now, I'll check.
    Maybe Cornwall Model Boats can help you with 3/16" stuff?
    https://www.cornwallmodelboats.co.uk/
    My Sea Scout originally had a 3/16" shaft. I swapped it for a 4mm one. The original was worn anyway.
    If all else fails you could always re-thread the old props!?
    Cheers, Doug ๐Ÿ˜Ž
    ๐Ÿ”—
    1
    Show 5 More Posts
